Verizon Software-Defined Interconnect (SDI)
Create a virtual connection to Verizon’s Private IP (PIP), Ethernet, or IP networks over Equinix Fabric using Verizon SDI.
Two methods of access to the Verizon network are available:
Verizon-ordered access – Initiated through the Verizon portal, these are Equinix Fabric virtual connections that originate from the Verizon access points (Fabric ports) towards a CSP, a Customer Cage, Equinix Metal or Network Edge. These connections are created by obtaining an A-side token from Verizon that is emailed to the customer’s email address, then redeemed by the customer in the Equinix Fabric portal, allowing the customer to create a connection to almost any Equinix Fabric provider or other destination.
Tip: Refer to Create Connections with an A-Side Token for instructions on how to redeem an A-side token in the Fabric portal.
Note: For more information about ordering SDI from Verizon, contact your Verizon sales representative for ordering instructions.
Customer-ordered access – Use the Equinix Fabric portal to create a connection to a Verizon SDI service profile that describes any of the available Verizon network services to which you want to connect over Fabric.
Customer-ordered access requires a Verizon authentication key when completing the connect request in the Fabric portal. This authentication key is needed to complete the connection in the Verizon portal. The same authentication key can be used to create multiple connections over the same SDI. If you need to use a new or different authentication key, you must order a new SDI service instance from Verizon. The authentication key is shown in the success page as below:
Verizon-ordered Access
Prerequisites:
A-side service token authorizing you to use Verizon SDI port as the connection origin access point.
Tip: To get an A-side token, work with your Verizon sales representative. Once ready, you will receive an email from Equinix with the A-side token information.
Fabric portal account.
Equinix Metal account (applicable to Connect from Verizon SDI to Equinix Metal).
Network Edge service profile (applicable to Connect from Verizon SDI to Network Edge Virtual Devices ). For information on creating Network Edge service profiles, see Create a Network Edge Service Profile.
Fabric port (applicable to Connect from Verizon SDI to your cage/port). For information on ordering a Fabric port, see Order an Equinix Fabric Port.
To connect from Verizon SDI to Equinix Metal:
Log in to Equinix Metal Console and request a Metal billed Fabric virtual connection to procure a Z-side service token authorizing you to connect to Equinix Metal instance as a destination.
Important: Since you are using a Verizon A-side token, you will not be directly billed for this connection.
Log in to Equinix Fabric.
In the Frequent Connections section, click Enter Service Token.
Enter your Metal-provided Z-side token identifier and click Validate.
Verify token details and click Redeem to proceed with creating the connection.
In the Connect Using section, click Service Token.
Enter Verizon-provided A-side service token, verify port details and click Next.
In the Connection Information section, enter a connection name.
Enter the purchase order number.
Click Next.
Review your order and click Submit Order.
For instructions on how to connect from Verizon SDI to a Network Edge virtual device, see Connect to a Private Network Edge Service Profile.
Important: Private IP Multi-VRF on the same PIP port is not supported due to Network Edge only allowing Dot1q encapsulation.
Multiple connections to Network Edge can be supported using multiple A-side tokens representing multiple PIP ports.
For instructions on how to connect from Verizon SDI to your colocation cage, see Connect My Assets Using E-Line.
Tip: Make sure you select Service Token as the origin access point and enter your Verizon provided A-side service token.
Connect from Verizon SDI to a CSP
To connect to from Verizon SDI to a CSP:
In the Create a Connection to section click Connect to a Service Provider.
Locate the service provider you want to connect to and click Select Service on their card.
Choose the service profile and click Create Connection.
In the Origin section, select Service Token and enter your Verizon provided A-side service token.
In the Destination section, select your preferred location and click Next.
In the Connection Information section:
Virtual Connection Name – Enter a name for the connection.
Enter service provider specific information.
Enter your purchase order number.
In the Connection Speed section, select a Billing Tier and Speed combination and click Next.
Review your order and verify that the details are correct.
Tip: Click Design Summary to download your order details in PDF format.
In the Notifications section, enter any additional email address(es) that should receive notifications about this subscription.
Click Submit Order.
Customer-ordered Verizon SDI Access
Create a connection from your Fabric Port or Network Edge virtual device to Verizon SDI.
Connect to Verizon SDI from a Fabric Port or Network Edge Virtual Device
On the A Service Provider card, click Connect to a Service Provider.
Enter Verizon in the search field.
On the Verizon card, click Select.
Choose service profile and click Create Connection.
Tip: Choose Verizon Software Defined Interconnect - High BW service profile for connection speeds over 1 Gbps. Otherwise, select Verizon Software Defined Interconnect.
In the Connect Using section, select how you want to connect to Verizon SDI.
Port – Select if you want to connect using a port.
Virtual Device – Select if you want to connect using a Network Edge virtual device.
Select a location and choose your port or Network Edge virtual device instance.
Select a connection destination and click Next.
VLAN ID – Enter the VLAN ID.
In the Peering Type Selection, enter the Z-side inner tag or the C-tag.
In the Connection Speed section, select a Billing Tier and Speed combination and Click Next.
Click Submit Order.
Share the Authentication Key displayed on the order confirmation page with your Verizon sales representative.
Note: Once Verizon has accepted your connection, your Equinix Fabric connection will automatically be provisioned and you will receive an email notification about connection's status change.
Authentication Keys
The confirmation message provides your Authentication Key. This Authentication Key can be used again for additional connections from a Fabric port, or you can choose to create a new Authentication Key for each subsequent connection.
The Authentication Key is also available on the connection's details page in the Order Details section.
To access connection details page:
From the Connections menu, select Connections Inventory.
Locate your Verizon SDI connection and click it.
Click Order Details to expand the section.
Multi-VRF Configurations
Verizon customers can connect to the PIP network in both Single and Multi-VRF configurations from their Fabric ports. However, this option is not available when connecting from a Network Edge virtual device. The PIP Network is available through customer or Verizon-ordered SDI (through the Equinix Fabric portal) with either single (Dot1q) or double (QinQ) tagging.
