# 订购设备安装 ![](https://docs.equinix.com/zh-Hans/assets/images/OrderEquipmentInstallation-cd03635f3bb234dd0b73c67a751046ad.png) ## 先决条件[​](#先决条件 "直接链接至先决条件") 1. 您必须具有权限才能获取Smart Hands详细信息`Smart Hands`。 2. 验证-提交您的用户凭据,客户端ID和客户端机密以进行OAuth2验证。有关如何致电OAuth API以验证和验证您的凭据的说明,请参阅[API验证](https://docs.equinix.com/zh-Hans/equinix-api/api-authentication.md)。 3. 获取Smart Hands类型-向端点发送`GET`获取所有Smart Hands订单类型的请求[`/v1/orders/smarthands/types`](https://docs.equinix.com/zh-Hans/api-catalog/smarthandsv1/smarthands/smarthandtypes.md)。如果您已经知道Smart Hands订单类型,可以跳过此步骤。 4. 获取位置信息-向端点发送`GET`请求[`/v1/orders/smarthands/locations`](https://docs.equinix.com/zh-Hans/api-catalog/smarthandsv1/smarthands/getlocation.md),以检索您有权访问的可用IBX位置。如果您已知道网点信息,可以跳过此步骤。 ## 订购设备安装 - 最小示例[​](#订购设备安装---最小示例 "直接链接至订购设备安装 - 最小示例") 由Equinix IBX技术人员订购设备安装,请向端点发送`POST`请求[`/v1/orders/smarthands/equipmentInstall`](https://docs.equinix.com/zh-Hans/api-catalog/smarthandsv1/smarthands/handlesmarthandorder.md)。在请求正文中指定安装要求。 cURL 请求示例: ``` curl -X POST "https://api.equinix.com/v1/orders/smarthands/equipmentInstall" -H "content-type: application/json" -H "authorization: Bearer " -d '{     "ibxLocation": {     "ibx": "AM1",     "cages": [       {         "cage": "AM1:0J:00JD11",         "accountNumber": "126854"       }     ]   },   "serviceDetails": {     "deviceLocation": "DHL tracking no. 1039 5739 92",     "elevationDrawingAttached": false,     "installationPoint": "Front and center.",     "patchDevices": true,     "patchingInfo": "When patching use the next available port, but maintain a symmetrical appearance.",     "powerItOn": true,     "mountHardwareIncluded": true,     "installedEquipmentPhotoRequired": true,     "scopeOfWork": "When installing make sure wires are all labeled."   },   "schedule": {     "scheduleType": "SCHEDULED_MAINTENANCE",     "requestedStartDate": "2019-08-30T22:00:49.776Z",     "requestedCompletionDate": "2019-08-31T22:00:49.776Z"   },   "contacts": [     {         "contactType": "ORDERING",         "userName": "johndoe"     },     {         "contactType": "TECHNICAL",         "userName": "johndoe",         "workPhonePrefToCall": "ANYTIME"     },     {         "contactType": "NOTIFICATION",         "userName": "johndoe"     }   ] }' ``` 示例回答: ``` { "OrderNumber": "1-190986534844" } ``` 响应表明订单已成功,并返回订单号。 ## 订购设备安装 - 扩展示例[​](#订购设备安装---扩展示例 "直接链接至订购设备安装 - 扩展示例") 由Equinix IBX技术人员订购设备安装,请向端点发送`POST`请求[`/v1/orders/smarthands/equipmentInstall`](https://docs.equinix.com/zh-Hans/api-catalog/smarthandsv1/smarthands/handlesmarthandorder.md)。在请求正文中指定安装要求。使用`attachments`对象包括技术人员的其他详细信息。 > **注意** > > 创建带有附件的订单之前,请致电[`Attachments File`](https://docs.equinix.com/zh-Hans/api-catalog/attachmentsv1/attachments/createattachment.md)端点。 ``` curl -X POST "https://api.equinix.com/v1/orders/smarthands/equipmentInstall" -H "content-type: application/json" -H "authorization: Bearer " -d '{     "ibxLocation": {     "ibx": "AM1",     "cages": [       {         "cage": "AM1:0J:00JD11",         "cabinets": [             "AM1:0J:00JD11:0001"         ],         "accountNumber": "126854"       }     ]   },   "serviceDetails": {     "deviceLocation": "DHL tracking no. 1039 5739 92",     "elevationDrawingAttached": true,     "installationPoint": "Front and center.",     "patchDevices": true,     "patchingInfo": "When patching use the next available port, but maintain a symmetrical appearance.",     "powerItOn": true,     "mountHardwareIncluded": true,     "installedEquipmentPhotoRequired": true,     "scopeOfWork": "When installing make sure wires are all labeled.",     "needSupportFromASubmarineCableStationEngineer": true   },   "attachments": [     {         "id": "fcb4a673-6308-456e-8f83-f745501d60ba",         "name": "Elevation drawing.docx"     }   ],   "schedule": {     "scheduleType": "SCHEDULED_MAINTENANCE",     "requestedStartDate": "2019-08-30T22:00:49.776Z",     "requestedCompletionDate": "2019-08-31T22:00:49.776Z"   },   "customerReferenceNumber": "EQX-PO2019-08-001",   "purchaseOrder": {     "purchaseOrderType": "EXEMPTED",     "attachment": {         "id": "abc1fd2e-345f-67g4-hi89-01jk234l5m6n",         "name": "PurchaseOrderExemptionForm123.docx"     }   },   "contacts": [     {         "contactType": "ORDERING",         "userName": "johndoe"     },     {         "contactType": "TECHNICAL",         "name": "Jane Smith",         "email": "janesmith@corporation.com",         "workPhoneCountryCode": "+44",         "workPhone": "0148211111",         "workPhonePrefToCall": "MY_BUSINESS_HOURS",         "workPhoneTimeZone": "Europe/London",         "mobilePhoneCountryCode": "+44",         "mobilePhone": "0123456789",         "mobilePhonePrefToCall": "MY_BUSINESS_HOURS",         "mobilePhoneTimeZone": "Europe/London"     },     {         "contactType": "NOTIFICATION",         "userName": "johndoe"     },     {         "contactType": "NOTIFICATION",         "userName": "janesmith"     }   ] }' ``` 有关主体参数和描述的完整列表,请参阅[API参考手册](https://docs.equinix.com/zh-Hans/api-catalog/smarthandsv1/smarthands/handlesmarthandorder.md)。
