跳到主要内容
订购设备安装
先决条件​
  1. 您必须具有权限才能获取Smart Hands详细信息Smart Hands。
  2. 验证-提交您的用户凭据,客户端ID和客户端机密以进行OAuth2验证。有关如何致电OAuth API以验证和验证您的凭据的说明,请参阅API验证。
  3. 获取Smart Hands类型-向端点发送GET获取所有Smart Hands订单类型的请求/v1/orders/smarthands/types。如果您已经知道Smart Hands订单类型,可以跳过此步骤。
  4. 获取位置信息-向端点发送GET请求/v1/orders/smarthands/locations,以检索您有权访问的可用IBX位置。如果您已知道网点信息,可以跳过此步骤。
订购设备安装 - 最小示例​
由Equinix IBX技术人员订购设备安装,请向端点发送POST请求/v1/orders/smarthands/equipmentInstall。在请求正文中指定安装要求。
cURL 请求示例:
curl -X
POST "https://api.equinix.com/v1/orders/smarthands/equipmentInstall"
    "ibxLocation": {
    "ibx": "AM1",
    "cages": [
        "cage": "AM1:0J:00JD11",
        "accountNumber": "126854"
  "serviceDetails": {
    "deviceLocation": "DHL tracking no. 1039 5739 92",
    "elevationDrawingAttached": false,
    "installationPoint": "Front and center.",
    "patchDevices": true,
    "patchingInfo": "When patching use the next available port, but maintain a symmetrical appearance.",
    "powerItOn": true,
    "mountHardwareIncluded": true,
    "installedEquipmentPhotoRequired": true,
    "scopeOfWork": "When installing make sure wires are all labeled."
  "schedule": {
  "contacts": [
        "contactType": "ORDERING",
        "userName": "johndoe"
        "contactType": "TECHNICAL",
        "userName": "johndoe",
示例回答:
"OrderNumber": "1-190986534844"
响应表明订单已成功,并返回订单号。
订购设备安装 - 扩展示例​
由Equinix IBX技术人员订购设备安装,请向端点发送POST请求/v1/orders/smarthands/equipmentInstall。在请求正文中指定安装要求。使用attachments对象包括技术人员的其他详细信息。
注意
创建带有附件的订单之前,请致电Attachments File端点。
curl -X
    "ibxLocation": {
    "ibx": "AM1",
    "cages": [
        "cabinets": [
            "AM1:0J:00JD11:0001"
  "serviceDetails": {
    "elevationDrawingAttached": true,
    "powerItOn": true,
    "scopeOfWork": "When installing make sure wires are all labeled.",
  "attachments": [
        "name": "Elevation drawing.docx"
  "schedule": {
  "purchaseOrder": {
    "attachment": {
  "contacts": [
        "name": "Jane Smith",
        "workPhone": "0148211111",
        "mobilePhone": "0123456789",
        "userName": "janesmith"
有关主体参数和描述的完整列表,请参阅API参考手册。
