# 连接到Fabric服务提供商 从您的Network Edge设备连接到云,网络及其他服务提供商。 信息 本主题涵盖从Network Edge连接到服务提供商的一般信息。有关连接到特定服务提供商的说明和示例,请参阅[连接到服务提供商](https://docs.equinix.com/zh-Hans/fabric-marketplace.md)部分。包括: * [阿里巴巴云](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/fabric-alibaba-cloudexpress.md) * [AWS Direct Connect](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/aws/direct-connect-overview.md) * [思科](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/fabric-connect-cisco-webex.md) * [Colt](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/fabric-connect-colt.md) * [Five9](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/fabric-connect-five9-redundant.md) * [GCP](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/gcp/ne-gcp-connect.md) * [IBM云](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/ibm/fabric-ibm-cloud-2_0.md) * [流明](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/fabric-connect-lumen.md) * [Microsoft Azure](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/microsoft/ne-azure-expressroute.md) * [NTT数据](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/fabric-ntt-data-connect.md) * [Oracle云](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/oracle/fabric-oracle-quick-connect.md) * [Salesforce](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/fabric-salesforce-hyperforce.md) * [Unitas Global](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/fabric-unitas-connect-port.md) * [Verizon](https://docs.equinix.com/zh-Hans/fabric-marketplace/connecting-to-service-provider/verizon/ne-verizon-sdi.md) ## 先决条件 * 已分配以下[角色的](https://docs.equinix.com/zh-Hans/iam/roles-permissions/iam-roles-permission-reference.md)Equinix Customer Portal账户:`Fabric Connections Manager`和`Network Edge Connections Manager`。 * Network Edge虚拟设备。 - Portal - API - Terraform 1. 登录[Equinix Customer Portal](https://portal.equinix.com/)并导航至\_Network Edge控制面板\_。 2. 使用“*项目选择器*”下拉菜单选择要在其下创建连接的项目。有关项目的更多信息,请参阅[管理项目](https://docs.equinix.com/zh-Hans/iam/resources/projects-manage.md)。 1) 验证-提交您的用户凭据,客户端ID和OAuth2客户端机密 验证。有关如何致电OAuth API以验证和验证您的凭据的说明,请参阅[API验证](https://docs.equinix.com/zh-Hans/equinix-api/api-authentication.md)。 2) 使用或[`/ne/v1/devices/{uuid}`](https://docs.equinix.com/zh-Hans/api-catalog/network-edgev1.md#tag/Virtual-Device/operation/getVirtualDevices)端点确定您的Network Edge设备信息[`/ne/v1/devices`](https://docs.equinix.com/zh-Hans/api-catalog/network-edgev1.md#tag/Virtual-Device/operation/getVirtualDeviceByUuid)。您可以在设备上选择任何可用接口进行连接。如果您未指定接口,Equinix将选择接口。 3) 确定服务提供商的服务配置文件信息。使用[`/fabric/v4/serviceProfiles/search`](https://docs.equinix.com/zh-Hans/api-catalog/fabricv4.md#tag/Service-Profiles/operation/searchServiceProfiles)端点搜索特定服务配置文件,或使用[`/fabric/v4/serviceProfiles`](https://docs.equinix.com/zh-Hans/api-catalog/fabricv4.md#tag/Service-Profiles/operation/listServiceProfiles)端点列出所有可用的服务配置文件,并确定要连接的配置文件。您需要提供服务提供商的配置文件UUID。 1. 确定您的Network Edge设备信息。使用数据源检查可用设备[`equinix_network_device`](https://docs.equinix.com/zh-Hans/terraform/data-sources/network_device.md)。 2. 确定服务提供商的服务配置文件信息。使用[`equinix_fabric_service_profiles`](https://docs.equinix.com/zh-Hans/terraform/data-sources/fabric_service_profiles.md)数据源搜索特定的服务配置文件。您需要提供服务提供商的配置文件UUID。 ## 建立连接 * Portal * API * Terraform 1. 在\_Network Edge控制面板\_中,单击**创建连接**。 ![](https://docs.equinix.com/zh-Hans/assets/images/service-provider-create-connection-49f02d48309fc652e6b31fbd69a326fd.png) 2. 在“*常用连接*”部分中,选择要连接的服务提供商。或单击\_服务提供商\_,然后搜索该服务提供商。 ![](https://docs.equinix.com/zh-Hans/assets/images/serivce-provider-cards-e80561faaf2e366e03bfc30d2a44dd77.png) 3. 单击服务提供商的卡,然后单击**创建连接(Network Edge设备)**。 ![](https://docs.equinix.com/zh-Hans/assets/images/service-provider-card-colt-8ff205019a7283613feabbf1861d3a62.png) **选择网点** 在\_选择网点\_页面上: 1. 在\_“源”\_部分的“*连接方式*”下,单击**虚拟设备**。 2. 选择设备和连接源位置。 3. 在\_选择虚拟设备类型\_部分中,选择设备类型:虚拟设备,冗余设备或集群。 4. 选择\_连接类型\_。如果您选择了单个虚拟设备,则会自动选择“*单一连接*”。要连接到集群或冗余设备,可以选择\_从\_冗余对或集群中的\_单个设备\_创建\_冗余连接\_或\_单一连接\_。 5. 选择您正在用于此连接的设备。 6. “*目标*”部分将填充您正在连接的服务提供商提供的位置选项。选择您要连接的服务提供商网点。 ![](https://docs.equinix.com/zh-Hans/assets/images/service-provider-select-locations-02d1834374fc90626c90f6c12222255d.png) 单击**下一步**。 **连接详情** 在\_连接详情\_页面上: 1. 在\_连接信息\_部分中,输入连接名称。对于冗余连接,请在“*连接信息*”字段中输入主要连接的名称,在“*冗余连接信息*”字段中输入次要连接的名称。 2. 在\_接口选择\_部分中,选择: * 如果要在下一个可用接口上创建连接,**请自动选择我的设备上的下一个可用接口**。 * 如果要指定连接的接口,**我将选择一个接口**。从下拉菜单中选择接口。 3. 如果服务提供商需要账户ID,配对密钥或其他身份信息,请在提供的字段中输入您的信息。“*附加买家选项*”部分包含特定于您要连接的服务提供商的选项。其中一些设备可能需要进行连接。 4. \_(可选)\_输入购买订单编号。 5. 选择主要设备的\_连接速度\_。对于冗余连接,还要选择辅助设备的连接速度。 ![](https://docs.equinix.com/zh-Hans/assets/images/service-provider-connection-details-52ff1c1159610a24dcb56100cbd4afc8.png) 点击“**下一步”** **查看并提交** 在\_审核\_页面上: 1. 查看\_连接概要\_和\_定价概览\_中的信息。 2. 在\_通知\_部分中,添加所有应接收有关此连接通知的用户的电子邮件地址。 3. 准备就绪后,单击**提交订单**。 ![](https://docs.equinix.com/zh-Hans/assets/images/service-provider-review-844551c2486a4ed12aa20f2a1e000143.png) 要建立从Network Edge设备到服务提供商的连接,请向端点发送`POST`请求[`/fabric/v4/connections`](https://docs.equinix.com/zh-Hans/api-catalog/fabricv4.md#tag/Connections/operation/createConnection)。 * 在对象中指定虚拟设备详情`aSide.accessPoint`。 * 在对象中指定服务提供商信息`zSide.accessPoint`。所需参数因服务提供商而异,请参阅[连接到服务提供商](https://docs.equinix.com/zh-Hans/fabric-marketplace.md)文档了解具体示例。 cURL 请求示例: ``` curl -X POST 'https://api.equinix.com/fabric/v4/connections' \ -H 'content-type: application/json' \ -H 'authorization: Bearer ' \ -d '{ "type": "EVPL_VC", "name": "", "bandwidth": 1000, "aSide": { "accessPoint": { "type": "VD", "virtualDevice": { "type": "EDGE", "uuid": "" } } }, "zSide": { "accessPoint": { "type": "SP", "profile": { "type": "L2_PROFILE", "uuid": "" }, "location": { "metroCode": "" } } }, "project": { "projectId": "" }, "notifications": [ { "type": "ALL", "emails": [ "" ] } ] }' ``` 使用资源创建连接[`equinix_fabric_connection`](https://docs.equinix.com/zh-Hans/terraform/resources/fabric_connection.md)。 * 在`a_side`:`access_point`对象中指定虚拟设备详情。 * 在`z_side`:`access_point`对象中指定服务提供商信息。所需参数因服务提供商而异,请参阅[连接到服务提供商](https://docs.equinix.com/zh-Hans/fabric-marketplace.md)文档了解具体示例。 ``` resource "equinix_fabric_connection" "vd2csp" { name = "" type = "IP_VC" notifications { type = "ALL" emails = ["", ""] } bandwidth = a_side { access_point { type = "VD" virtual_device { type = "EDGE" uuid = "" } } } z_side { access_point { type = "SP" profile { type = "L2_PROFILE" uuid = "" } location { metro_code = "" } } } } ``` 订单提交后,将向通知联系人发送订单的电子邮件验证。连接配置完毕后,联系人还会收到确认电子邮件。 ## 监控连接状态 * Portal * API * Terraform 在客户门户网站中创建连接后,请从“[*连接清单”*](https://docs.equinix.com/zh-Hans/fabric/managing-connections/fabric-new-connections-inventory.md)中监控其状态。 要检查连接状态,请向端点发送`GET`请求[`/fabric/v4/connections/{connectionId}`](https://docs.equinix.com/zh-Hans/api-catalog/fabricv4.md#tag/Connections/operation/getConnectionByUuid)。 获取数据源的连接状态[`equinix_fabric_connections`](https://docs.equinix.com/zh-Hans/terraform/data-sources/fabric_connections.md)。 | Equinix 状态 | 提供商状态 | **描述** | | -------------- | -------------- | ------------------------------ | | `PROVISIONING` | `PROVISIONING` | 连接请求尚未发送给服务提供商。 | | `PROVISIONED` | `PROVISIONING` | 连接正在建立中。 | | `PROVISIONED` | `PROVISIONED` | 连接已建立。 |
