跳至内容
快照和恢复 - 下一代技术栈
本主题介绍快照和恢复功能,该功能允许您对设备映像进行快照,然后通过使用备份重新配置映像来恢复 VNF。每个 VNF 最多允许 3 个快照。备份映像无法下载,只能在Network Edge基础架构中进行恢复。
图像快照和还原
成功创建快照和恢复系统需满足以下条件:
  • 每个 VNF 只能保存 3 个快照作为备份。如果达到限制,则需要先删除旧备份,然后才能创建新备份。
  • 对于集群部署,每个节点允许进行 3 次备份。两个节点需要同时进行备份。
  • 恢复功能需要删除当前 VNF。如果在拍摄图像快照后删除了任何资源(例如连接和设备链接组),则无法恢复设备。
功能可用性取决于 VNF 类型和配置 VNF 的 IBX。请参阅下表以了解您的 VNF 是否支持快照和恢复功能。对于某些 VNF,由于恢复过程中内部标识符发生变化,您需要禁用然后重新注册许可证。
VNF TypeSnapshot and Restore SupportRequired User Action
Any VNF provisioned in the AM4, FR6, LD6, CH1, DA1, DC11, SV5, SG3, SY4NoN/A
Aruba EdgeConnectYesNo action required
Arista CloudEOSYes (BYOL)No action required. VNF should retain the license after restoring
Arista VeloCloud SD-WAN EdgeYesNo action required
Aviatrix EdgeYesNo action required
BlueCatYesNo action required
Check Point FirewallYes (BYOL)No action required. VNF should retain the license after restoring
Cisco CSR1000vYes (BYOL)User should de-register and register with the smart license after restoring
Cisco CSR1000v SD-WANYes (BYOL)User should de-register and register with the smart license after restoring
Cisco Catalyst 8000V (Autonomous Mode)Yes (BYOL)User should de-register and register with the smart license after restoring
Cisco Catalyst 8000V (Controller Mode)Yes (BYOL)User should de-register and register with the smart license after restoring
Cisco FTDvYes (BYOL)User should de-register and register with the smart license after restoring
Cisco ASAvYes (BYOL)User should de-register and register with the smart license after restoring
F5YesNo action required
Fortinet FortiGate vFW / SD-WANYes (BYOL)No action required. VNF should retain the license after restoring
Infoblox NIOSYesNo action required
Infoblox Grid ManagerNoN/A
Gigamon V-SeriesNoN/A
Juniper vSRXYes (BYOL)No action required. VNF should retain the license after restoring
NGINX PlusYes (Subscription)No action required. VNF should retain the license after restoring
Palo Alto Networks VM-Series FirewallYes (BYOL)User should de-register and register their license after restoring
Palo Alto Networks Prisma SD-WANNoN/A
Prisma SD-WANNoN/A
VERSAYes (BYOL)No action required. VNF should retain the license after restoring
VyOSYes (Subscription)No action required. VNF should retain the license after restoring
ZscalerYesNo action required
创建 VNF 映像快照
  1. 从“网络边缘”菜单中,选择“虚拟设备清单”。
  2. 选择要为其创建快照的设备,然后单击工具
  3. 在“快照管理”卡片中,单击“创建快照”。
  4. 在“创建映像快照”提示符中,输入此备份映像的“名称”,并选择“我已知晓在此过程中设备操作将受到限制”。请注意,完成快照的预计时间可能因 VNF 的大小而异。
  5. 点击“提交”按钮开始快照过程。屏幕上会显示另一个提示,表明映像备份正在进行中。点击“返回设备详情”或 X 关闭此提示。
    在“工具”部分,“快照管理”卡片显示映像快照正在进行中,并显示预计完成时间。设备状态显示“映像快照正在进行中”。
  6. 在“快照管理”卡片中,单击“管理和从快照还原”来管理您的备份。
  7. 通过选择图像然后单击编辑图标进行选择来重命名或删除快照。
复原VNF
警告
恢复过程一旦开始,将无法撤消。我们建议您创建设备当前状态的备份,以便在需要保存 VNF 的任何更改时进行备份。
  2. 选择要为其创建映像备份的设备,然后单击工具
  3. 在“快照管理”卡片中,单击“管理和从快照还原”。所有快照都将显示出来。
  4. 选择要用于恢复的映像,然后单击从此快照恢复设备
  5. 在“恢复前创建快照(推荐)”提示中,单击“立即恢复”。
    恢复过程开始后,您的设备将无法使用 15 至 20 分钟。您的设备状态将显示恢复正在进行中。
此页面有帮助吗?
