# Maintenance Maintenance is critical to a healthy data center to ensure that assets operate correctly. Maintenance activities can trigger Smart View alerts. You can view System Alerts that were triggered during maintenance in the [Alerts Center](https://docs.equinix.com/smart-view/alerts/overview.md). The *Maintenance* column shows if the asset was undergoing maintenance work when the alert triggered. ![Screenshot of the Maintenance Column](https://docs.equinix.com/assets/images/maintenance-table-column-97260af2c967bcb9a8de67d07e0ef80d.png) You can also click **Maintenance** to sort your alerts by Maintenance status. ![Sorting the Table by Maintenance](https://docs.equinix.com/assets/images/maintenance-table-sorting-662b2012a54bfd15599de9f7148c77a0.png) ## Maintenance Alert Notifications[​](#maintenance-alert-notifications "Direct link to Maintenance Alert Notifications") You can adjust whether System Alert notifications are sent during maintenance from the [Notification Settings](https://docs.equinix.com/smart-view/alerts/system-alerts.md#system-alert-notification-settings). ![Maintenance Notification Setting](https://docs.equinix.com/assets/images/maintenance-alerts-notification-settings-1b3393e9a5898995d0f617dfb99bde34.png) Check or clear the *Notify During Maintenance* checkbox to enable or suppress notifications that occur during maintenance work. ## Viewing Maintenance Activity[​](#viewing-maintenance-activity "Direct link to Viewing Maintenance Activity") All maintenance, change, and Method of Procedure (MOP) activity is available from [Service Insight](https://docs.equinix.com/incidents-notifications/service-insight/esi.md) on the *Changes* tab. ![Screenshot of the Changes Menu in Service Insight](https://docs.equinix.com/assets/images/maintenance-service-insight-changes-4c83087fc466bb227a291c28df1b33d5.png) Service Insight provides [calendar and list views of IBX-related changes](https://docs.equinix.com/incidents-notifications/service-insight/change-list.md) that may affect you or trigger an alert, as well as all [MOPs](https://docs.equinix.com/incidents-notifications/service-insight/mop.md) associated with the change.
