Maintenance
Maintenance is critical to a healthy data center to ensure that assets operate correctly. Maintenance activities can trigger Smart View alerts.
You can view System Alerts that were triggered during maintenance in the Alerts Center. The Maintenance column shows if the asset was undergoing maintenance work when the alert triggered.
Screenshot of the Maintenance Column
You can also click Maintenance to sort your alerts by Maintenance status.
Sorting the Table by Maintenance
Maintenance Alert Notifications​
You can adjust whether System Alert notifications are sent during maintenance from the Notification Settings.
Maintenance Notification Setting
Check or clear the Notify During Maintenance checkbox to enable or suppress notifications that occur during maintenance work.
Viewing Maintenance Activity​
All maintenance, change, and Method of Procedure (MOP) activity is available from Service Insight on the Changes tab.
Screenshot of the Changes Menu in Service Insight
Service Insight provides calendar and list views of IBX-related changes that may affect you or trigger an alert, as well as all MOPs associated with the change.
