Migrate From Alarms To System Alerts
Migrate your API requests that use a deprecated /alarms endpoint to the new /systemAlerts endpoint.
Old /alarms request:
GET /alarms/v1/smartview/alarms
New /systemAlerts request:
POST /smartview/v2/systemAlerts/search
Get Alarms is a simple GET request that supports a very limited number of input parameters, passed in the query. Retrieve System Alerts is a POST request with input parameters passed in the payload. It supports a larger number of parameters, enabling you to retrieve much finer datasets. The Alarms data model structure is flat and provides limited information on active alarms only. The System Alerts data model provides a more detailed insight into alerts and their processing.
Sample Requests
Sample curl request for /alarms:
curl -X GET 'https://api.equinix.com/alarm/v1/smartview/alarms?accountNo=1&limit=10' \
Sample curl request for /systemAlerts:
curl -X POST 'https://api.equinix.com/smartview/v2/systemAlerts/search' \
"filter": {
"and": [
"property": "/status",
"operator": "=",
"values": [
"ACTIVE"
"pagination": {
"offset": 0,
"limit": 10
Sample Responses
Sample response from /alarms:
"alarms": [
"ibx": "DC5",
"accountNo": "1",
"assetId": "DC5.UPS-R1",
"assetType": "UPS",
"assetClassification": "Electrical",
"conditionName": "Alarm",
"status": true,
"tagId": "DC5.UPS-R1:alarm",
"timeProcessed": 1550519327497,
"timeTrigerred": 1546510663707,
"timeNormalProcessed": 0
"groupedAlarms": null,
"totalCount": 1
Sample response from /systemAlerts:
"data": [
"id": 1931,
"alertUid": "LD9.Generator-DH09-PG2:gensetavailableinauto#DIGITAL:ALARM",
"traceUid": "1687495706640/LD9.Generator-DH09-PG2:gensetavailableinauto#DIGITAL:ALARM",
"assetTagUid": "LD9.Generator-DH09-PG2:gensetavailableinauto",
"assetTagDisplayName": "Genset Available In Auto",
"status": "ACTIVE",
"value": {
"alertTagValue": "true",
"alertTagValueDisplayName": "OPEN",
"activeAlertTagValueDisplayName": "OPEN",
"currentTagValue": "CLOSED"
"asset": {
"ibx": "LD9",
"assetUid": "LD9.Generator-DH09-PG2",
"assetType": "Generator",
"assetRegion": null,
"assetUnderMaintenance": false
"configuration": {
"thresholdValue": "1",
"thresholdValueDisplayName": "OPEN",
"unitOfMeasurement": "&",
"thresholdType": "DIGITAL",
"conditionName": "ALARM",
"configurationVersion": "1.0"
"activeProcessing": {
"edgeCollectedOn": "2023-06-23T04:48:26.640Z",
"tagCalculationJobProcessedOn": "2023-06-23T04:48:26.840Z",
"processingStartOn": "2023-06-23T04:49:01.182223Z",
"processingEndOn": "2023-06-23T04:49:01.282301Z",
"publishedOn": "2023-06-23T04:49:01.282301Z"
"inactiveProcessing": {
"edgeCollectedOn": null,
"tagCalculationJobProcessedOn": null,
"processingStartOn": null,
"processingEndOn": null,
"publishedOn": null
"pagination": {
"offset": 20,
"limit": 10,
"total": 1
