# Stream Colocation Data from the Equinix API The Streaming API supports creating a subscription to enable retrieving your data from the Equinix API. ![](https://docs.equinix.com/assets/images/operating-info-power-rest-c2ec5d3408cb27ffba8e8079b62feff3.png) ## Prerequisites[​](#prerequisites "Direct link to Prerequisites") * Submit your user credentials, Client ID, and Client Secret for OAuth2 authentication. Refer to [API Authentication](https://docs.equinix.com/equinix-api/api-authentication.md) for more information on how to authenticate your requests to the Equinix API. * Create a Subscription. Send a `POST` request to the [`/smartview/v2/streaming/subscriptions`](https://docs.equinix.com/api-catalog/smartviewv2/streaming-subscription-api/createsubscription.md) endpoint and specify the `channelType` as `REST`. The `Location` header in the response contains the subscription ID required to consume the real-time feed. For more information, see [Creating a Subscription](https://docs.equinix.com/smart-view/sv-api/create-subscription.md#equinix-rest-api). ## Retrieving the Data[​](#retrieving-the-data "Direct link to Retrieving the Data") To retrieve your REST streaming channel messages, send a `GET` request to the [`smartview/v2/streaming/subscriptionData/{subscriptionId}`](https://docs.equinix.com/api-catalog/smartviewv2/streaming-subscription-api/getsubscriptiondata.md) endpoint. Sample cURL Request: ``` curl -X  GET 'https://api.equinix.com/smartview/v2/streaming/subscriptionData/0f6bdb36-e130-4924-b038-ee1785fad999' ``` Sample Response: ``` {     "alarmMessageData": [],     "alertMessageData": [],     "environmentMessageData": [],     "meteredPowerMessageData": [],     "powerMessageData": [         {             "type": "power",             "data": {                 "streamId": "20409808",                 "ibx": "LD9",                 "asset": {                     "id": "20409808",                     "type": "CIRCUIT"                 },                 "cage": "LD9:0G:0Z10BB",                 "cabinet": "LD9:0G:0Z10BB:0109",                 "accountNumber": "116710",                 "description": "32-amp 230v Single Phase Primary AC Power",                 "oid": "1.3.6.1.2.1.299.36.10.4442",                 "realPower": {                     "value": "0.000",                     "unit": "kW"                 },                 "apparentPower": {                     "value": "0.000",                     "unit": "kVA"                 },                 "current": {                     "value": "0.000",                     "unit": "A"                 },                 "powerFactor": {                     "value": "0.000",                     "unit": "pf"                 },                 "soldCurrent": {                     "value": "32.000",                     "unit": "A"                 },                 "soldPower": {                     "value": "7.360",                     "unit": "kVA"                 },                 "powerConsumptionToContractual": {                     "value": "0.000",                     "unit": "PERCENT"                 },                 "peakLastSevenDays": {                     "value": "0.000",                     "unit": "kVA"                 },                 "peakLastSevenDaysRatio": {                     "value": "0.000",                     "unit": "PERCENT"                 },                 "peakLastSevenDaysContractualPower": {                     "value": "7.360",                     "unit": "kVA"                 },                 "peakLastSevenDaysTime": "2023-12-06T05:45:00",                 "lastUpdated": "2023-12-07T15:49:00",                 "readingTime": "2023-12-07T15:45:00"             }         },         {             "type": "power",             "data": {                 "streamId": "20409809",                 "ibx": "LD9",                 "asset": {                     "id": "20409809",                     "type": "CIRCUIT"                 },                 "cage": "LD9:0G:0Z10BB",                 "cabinet": "LD9:0G:0Z10BB:0109",                 "accountNumber": "116710",                 "description": "32-amp 230v Single Phase Redundant AC Power",                 "oid": "1.3.6.1.2.1.299.36.10.4443",                 "realPower": {                     "value": "0.000",                     "unit": "kW"                 },                 "apparentPower": {                     "value": "0.000",                     "unit": "kVA"                 },                 "current": {                     "value": "0.000",                     "unit": "A"                 },                 "powerFactor": {                     "value": "0.000",                     "unit": "pf"                 },                 "soldCurrent": {                     "value": "32.000",                     "unit": "A"                 },                 "soldPower": {                     "value": "7.360",                     "unit": "kVA"                 },                 "powerConsumptionToContractual": {                     "value": "0.000",                     "unit": "PERCENT"                 },                 "peakLastSevenDays": {                     "value": "0.000",                     "unit": "kVA"                 },                 "peakLastSevenDaysRatio": {                     "value": "-1.000",                     "unit": "PERCENT"                 },                 "peakLastSevenDaysContractualPower": {                     "value": "0.000",                     "unit": "kVA"                 },                 "peakLastSevenDaysTime": "2023-12-06T22:15:00",                 "lastUpdated": "2023-12-07T15:49:00",                 "readingTime": "2023-12-07T15:45:00"             }         }     ],     "tagPointMessageData": [],     "pagination": {         "offset": 0,         "limit": 250,         "total": 46,         "next": null,         "previous": "?offset=0&limit=250"     } } ```
