Create a Subscription
Once you have set up and configured your data collector, create a subscription to stream your colocation data to it.
You can use only one communication channel type in your organization. For example, if you create a subscription with the AWS IoT Core channel, you won't be able to create another subscription using a different channel type.
Only one channel is allowed for a single subscription.
Prerequisites
Before calling the Subscription Management APIs, refer to Integrating with a Collector to set up and configure the destination for your data.
Submit your user credentials, Client ID, and Client Secret for OAuth2 authentication. Refer to API Authentication for more information on how to authenticate your requests to the Equinix API.
AWS IoT Core
To create a subscription to send data to Amazon IoT Core, send a POST request to the /smartview/v2/streaming/subscriptions endpoint. In the body of the request, specify the channelType as AWS_IOT_CORE and its URL in awsIotCoreChannelConfiguration. Specify which data it should receive in the messageType object.
Sample cURL Request:
curl -X
POST 'https://api.equinix.com/smartview/v2/streaming/subscriptions'
"messageType": {
"asset": [],
"environmental": [
"accountNumber": "116710",
"ibx": [
"LD9"
"level": [
"CAGE"
"power": [],
"meteredPower": [],
"systemAlert": [],
"customAlert": []
"channel": {
"channelType": "AWS_IOT_CORE",
"awsIotCoreChannelConfiguration": {
"url": "https://<awsIotCoreuri>.amazonaws.com"
For a complete listing of available options for messageType, see the API Reference.
Webhook
To create a subscription to send data to a webhook, send a POST request to the /smartview/v2/streaming/subscriptions endpoint. In the body of the request, specify the channelType as WEBHOOK and its configuration in webhookChannelConfiguration. Specify which data it should receive in the messageType object.
curl -X
"messageType": {
"asset": [],
"environmental": [
"ibx": [
"LD9"
"level": [
"CAGE"
"power": [],
"meteredPower": [],
"systemAlert": [],
"customAlert": []
"channel": {
"channelType": "WEBHOOK",
"webhookChannelConfiguration": {
"sslCertificate": "ZkFzZLY1IGRpY31kZXI=...",
"url": "https://<webhook-uri>.com",
"numberOfRetries": 1,
"numberOfConcurrentCalls": 20,
"batchSize": 5
For a list of webhook configuration options and available options for messageType, see the API Reference.
Equinix Rest API
To create a subscription to make your data available from the Equinix API, send a POST request to the /smartview/v2/streaming/subscriptions endpoint. In the body of the request, specify the channelType as REST. Specify which data it should receive in the messageType object.
curl -X
"messageType": {
"asset": [],
"environmental": [
"ibx": [
"LD9"
"level": [
"CAGE"
"power": [],
"meteredPower": [],
"systemAlert": [],
"customAlert": []
channel": {
"channelType": "REST",
"restChannelConfiguration": {
Sample Response:
HTTP/1.1 201 Created
Location: /smartview/v2/streaming/subscriptions/0f6bdb36-e130-4924-b038-ee1785fad999
The Location header in the response contains the subscription ID required to consume the real-time feed.
