Maintenance History
The Maintenance History section shows the history of maintenance completed on electrical and mechanical assets. Here, you can see the asset equipment information and their geographical details. You can filter these assets to see how often they have undergone routine maintenance, with dates showing when their past maintenance started and ended.
View the details of all the completed maintenance events conducted on the assets in your data center. You can filter these assets to see how often they have undergone routine maintenance in the past. A smart data grid displays the asset equipment information and their geographical details. This section shows the last start and end dates of maintenance performed on the assets.
tip
The smart data grid allows you to search, sort, and filter the columns. You can also click the gear to select columns to hide/show, or to rearrange the columns.
Data Columns​
These columns are displayed in the grid:
NameDescription
AssetUnique identifier for each asset.
Asset TypeType of asset (for example, Chiller, ATS).
IBXAll data centers that have undergone maintenance. (This only shows data centers for which you have a subscription to Smart View.)
Date StartedDate and time maintenance started.
Date EndedDate and time maintenance ended.
User StartedUser who started the maintenance.
User EndedUser who ended the maintenance.
ManufacturerManufacturer of the asset.
Equipment ModelModel number of the asset equipment.
Equipment Serial NumberSerial number of asset equipment.
Affected AssetsNumber of cages or circuits supported by the asset under maintenance.
Affected AccountsNumber of accounts affected by the maintenance event.
Asset ClassificationCategory of the asset (for example, Electrical, Mechanical).
MetroMetropolitan area where the asset resides.
CountryCountry where the asset resides.
RegionRegion where the asset resides.
Note:
  • You cannot hide the IBX, Asset/Location, and Data Points columns.
  • You can filter and sort all columns except Affected Assets.
View Details for a Row​
Click an asset in the data grid for a condensed view of its maintenance event.
This panel displays the specific IBX where the asset resides and shows the asset's equipment information. It also shows when maintenance on this asset started and completed.
Export Data to a File​
To save the data to a CSV file:
  1. Arrange the data you want to export.
    tip
    You can set filters, use the search box, choose a sort column, hide columns, and rearrange columns.
  2. Click the download icon.
The system downloads a .csv file to your device.
Create a Trouble Ticket​
To submit a trouble ticket to Equinix, click Trouble Ticket at the top right corner (above the data grid). See also the Support page.
