# Ordering Patch Cable Installation ![](https://docs.equinix.com/assets/images/OrderPatchCableInstallation-289ea089add22752d178a0c30fe2ee6f.png) ## Prerequisites[​](#prerequisites "Direct link to Prerequisites") 1. Authenticate - Submit your user credentials, Client ID, and Client Secret for OAuth2 authentication. Refer to [API Authentication](https://docs.equinix.com/equinix-api/api-authentication.md) for instructions on how to call the OAuth API to validate and authenticate your credentials. 2. Retrieve the serial number of the Cross Connect - Send a `POST` request to the [`/v1/assets/search`](https://docs.equinix.com/api-catalog/assetsv1/assets/searchassets.md) endpoint to search for the correct Cross Connect serial number. You may skip this step if you already have the serial number. If you cannot find the serial number of the cross connect, you should use `"Serial # Not Found"` as your serial number. 3. To get Smart Hands details, you must have `Smart Hands` ordering permission. 4. Get Smart Hands Types - Send a `GET` request to the [`/v1/orders/smarthands/types`](https://docs.equinix.com/api-catalog/smarthandsv1/smarthands/smarthandtypes.md) endpoint to get all Smart Hands order types. You may skip this step if you already know the Smart Hands order type. 5. Get Location Information - Send a `GET` request to the [`/v1/orders/smarthands/locations`](https://docs.equinix.com/api-catalog/smarthandsv1/smarthands/getlocation.md) endpoint to retrieve available IBX locations that you have access to. You may skip this step if you already know the location information. ## Order Patch Cable Installation[​](#order-patch-cable-installation "Direct link to Order Patch Cable Installation") To order patch cable installations by an Equinix IBX Technician, send a `POST` request to the [`/smarthands/patchCableInstall`](https://docs.equinix.com/api-catalog/smarthandsv1/smarthands/handlesmarthandpatchcableinstallorder.md) endpoint. Specify your installation instructions in the body of the request. > **Note** > > Before creating an order with attachment, call the [`Attachments File`](https://docs.equinix.com/api-catalog/attachmentsv1/attachments/createattachment.md) endpoint. ``` curl -X POST "https://api.equinix.com/v1/orders/smarthands/patchCableInstall" -H "content-type: application/json" -H "authorization: Bearer " -d '{     "ibxLocation": {     "ibx": "AM1",     "cages": [       {         "cage": "AM1:0J:00JD11",         "cabinets": [           "AM1:0J:00JD11:0001"         ],         "accountNumber": "126854"       }     ]   },   "serviceDetails": {     "crossConnects": [       {         "serialNumber": "123456789",         "deviceCabinet": "501",         "deviceConnectorType": "FC",         "deviceDetails": "Router1",         "devicePort": "Next Available",         "scopeOfWork": "Refer to attachment for further instruction.",         "lightLinkVerification": true,         "needSupportFromASubmarineCableStationEngineer": true       }     ]   },   "attachments": [     {       "id": "fcb4a673-6308-456e-8f83-f745501d60ba",       "name": "PatchCabelInstallationInstruction.docx"     }   ],   "schedule": {     "scheduleType": "SCHEDULED_MAINTENANCE",     "requestedStartDate": "2019-08-30T22:00:49.776Z",     "requestedCompletionDate": "2019-08-31T22:00:49.776Z"   },   "customerReferenceNumber": "EQX-PO2019-08-001",   "purchaseOrder": {     "purchaseOrderType": "EXEMPTED",     "attachment": {       "id": "abc1fd2e-345f-67g4-hi89-01jk234l5m6n",       "name": "PurchaseOrderExemptionForm123.docx"     }   },   "contacts": [     {       "contactType": "ORDERING",       "userName": "johndoe"     },     {       "contactType": "TECHNICAL",       "name": "Jane Smith",       "email": "janesmith@corporation.com",       "workPhoneCountryCode": "+44",       "workPhone": "0148211111",       "workPhonePrefToCall": "MY_BUSINESS_HOURS",       "workPhoneTimeZone": "Europe/London",       "mobilePhoneCountryCode": "+44",       "mobilePhone": "0123456789",       "mobilePhonePrefToCall": "MY_BUSINESS_HOURS",       "mobilePhoneTimeZone": "Europe/London"     },     {       "contactType": "NOTIFICATION",       "userName": "johndoe"     },     {       "contactType": "NOTIFICATION",       "userName": "janesmith"     }   ] }' ``` For a complete list of body parameters and descriptions, see [the API Reference](https://docs.equinix.com/api-catalog/smarthandsv1/smarthands/handlesmarthandpatchcableinstallorder.md). Sample Response: ``` {   "OrderNumber": "1-457809872838" } ``` The response indicates the order was successful and returns the order number.
