Standard Order Processing
If you choose the Standard scheduling option for your Smart Hands order, the order is processed as follows:
Process flow for a standard scheduling order with notification points
Order Notifications​
These steps describe how you are notified of the progress of your order.
  1. Once your request is received by the system, an Order Received email is sent to you. It indicates that your order is in the queue for review by the IBX.
    Order received email for a standard order
  2. If the IBX determines that there is insufficient information to process your order, an Order On-Hold email is sent to you. The email describes how to provide the necessary information for the order to proceed.
    Order on hold follow-up email for a standard order
  3. Scheduling:
    1. If the IBX determines that your request cannot be completed by the original assigned date and time, you are sent an Order Modification email with the new date and time of completion.
      Order modification email for a standard order
    2. If the IBX determines that your request can be completed by the original assigned date and time, the IBX assigns the earliest available date for its completion. You are sent an Order Scheduled notification with the scheduled date details.
      Order scheduled email for a standard order
  4. If you requested photos or documentation as part of the ticket, you can access the information from links on the Information Provided notification:
    Order completed information provided email for a standard order
  5. Once the request is completed, the ticket is closed, and an Order Completed email is sent to you.
    Order completed email for a standard order
tip
Many of these order notifications can also be viewed in the portal's Notification Center.
