# Technician Messaging When work is being done on your order, this Smart Hands feature allows you to send and receive messages with the technician. > **Note** > > Only the ordering contact or Technical Contact can use this feature to exchange messages with the technician while work is being done. ## Enable the Messaging Option[​](#enable-the-messaging-option "Direct link to Enable the Messaging Option") To enable the Messaging option when you [place an order](https://docs.equinix.com/smart-hands/ordering/sh-how-to-order.md) in the [Customer Portal](https://portal.equinix.com/): 1. Under *Scope of Work*, select *Enable messaging with technician when work is in progress*. ![](https://docs.equinix.com/assets/images/sh-text-messaging-enable-4dca332d303e2ae8f253ab3e228b1227.png) 2. Under *Contact Info*, select at least one Technical Contact. ![](https://docs.equinix.com/assets/images/sh-text-messaging-contact-info-29b3791b6598c20a74459343f9e0ee60.png) 3. For the chosen Technical Contact(s), select *Include mobile phone number*. 4. Click the pencil and specify the mobile phone number, country code, and the hours of contact availability. 5. Continue with the ordering process. For more information, see [Submit a Smart Hands Order](https://docs.equinix.com/smart-hands/ordering/sh-how-to-order.md). ## Send a Message to the Technician[​](#send-a-message-to-the-technician "Direct link to Send a Message to the Technician") When work begins on your order and its *Status* is `In Progress`, an automated SMS message is sent to all Technical Contacts on the order, excluding any Unlisted contacts. The message contains a link for you to reply to the technician through the Customer Portal. 1. To send a message to the Equinix technician while work is being done on your order, either: * Click the link in the SMS message you received. * In your *Orders and Tickets History* , hover over the `In Progress` status of your order until it changes to a button, then click **Send Message**. ![](https://docs.equinix.com/assets/images/sh-order-history-dasboard-message-popup-f8d5e97d2493270f631a206618563a61.png) * In your *Orders and Tickets History*, click your order number to view the *Activity Timeline*. > **Note** > > The order status must be `In Progress`. 2. Enter your message for the technician: ![](https://docs.equinix.com/assets/images/sh-text-messaging-box-f0068931cc3c054cccf55463cb1dfa5e.png) 3. Click **Upload File(s)** to add attachments. 4. Click **Submit**. ## Technician-initiated Messaging[​](#technician-initiated-messaging "Direct link to Technician-initiated Messaging") For orders with the Text (SMS) technical contact option enabled, Equinix might initiate messaging with you when your order is in progress. If the technician sends you a message, you’ll see an orange message icon in the *Status* column in your *Orders and Tickets History*. ![](https://docs.equinix.com/assets/images/sh-orders-tickets-history-orange-message-icon-example-6fe464bc8f1ef62ef4dab4efcd40026e.png) Hover over it and click **View New Message** to read the message in the *Activity Timeline* and send a reply, if required.
