Ir para o conteúdo principal
Cisco Threat Defense Virtual Firewall
Licensing Options
Deployment Types
  • Single Device
  • Redundant Devices
  • Cluster
Connectivity Options
  • With a Public IP Address
  • Without a Public IP Address
Device Details​
4 Cores8 Cores12 Cores
Memory8 GB16 GB24 GB
Software PackageFTDv5
FTDv10
FTDv20
FTDv30FTDv50
Virtual Data Interfaces Supported (Default/Max)10 / 10
System Reserved InterfacesWeb-based Management (FMC, FDM or CDO)
Access MethodsSSH (CLI)
HTTPS (Web Console)
Restricted CLI CommandsNone
When configuring your device details, specify the following:
  • Cluster Name - If you are creating a cluster, give your cluster a name.
  • Device Name – Enter a name for the device. If you are creating more than a single device, -Node 0 is appended to the primary node and -Node 1 is appended to the secondary node after the device name.
  • Device Management – Select your device management type from the following:
    • Firewall Management Center (FMC) – Enter the FMC’s IP Address as the Controller IP Address, and the Registration Key. The registration key is used to register the device to the FMC.
    • Firepower Device Manager (FDM)
    • Cisco Defense Orchestrator (CDO)
  • SSH Access - Unlike the other VNF types, we do not provide username and RSA Public Key configuration settings for SSH access during the device creation workflow. Use console access from the device details page.
Deploying Without IP Address​
  • When the connectivity type Without Equinix Public IP Address is selected, the VNF is provisioned without a public IP Address on the WAN or Management interface. You are responsible for configuring the license registration, overlay network configuration, and clustering (optional).
    The following is an example (reference only) command for management interface setup.
  • Clustering - The option to deploy a cluster is not available if you are not using public IP addresses. You must configure cluster devices manually.
Bring Your Own License​
  • You can enter your License Token during the device creation process. Once you enter the license token, your virtual device will be provisioned with the license based on the token provided. If you do not provide token information, your virtual device will still be provisioned but you will need to manually register your license with the smart server using your license token after the virtual device is provisioned.
  • Alternatively, you can enter your Smart License URL. You must have a valid Cisco account to complete this process. To get a Cisco Smart License token, follow the instructions in the Cisco documentation.
    • Sign in to the Cisco Smart Software Manager (CSSM) with your Cisco.com account credentials.
    • Locate the Virtual Accounts > Inventory section to create a new token.
    • Your newly created token will appear in the token list. Click the token to see the details and copy the token string.
    show license status
    If you encounter any issues or need more detailed steps, see Cisco DNA Center Administrator Guide or contact Cisco support.
  • You are responsible for obtaining support from Cisco or their partners. If you are subscribing with a license from Equinix Network Edge, you can open a support case with Cisco Technical Assistant Center (TAC) to troubleshoot Cisco IOX-XE software issues or ask Cisco IOX-XE configuration questions from the Network Edge portal. See Cisco Catalyst 8000V Subscriptions for more information.
