# Cisco Meraki vMX SD-WAN (Beta)
* [Getting Started with Meraki](https://documentation.meraki.com/Getting_Started_with_Meraki)
* [vMX Comparison Datasheet](https://documentation.meraki.com/SASE_and_SD-WAN/MX/Install_and_Get_Started/Installation_Guides/vMX_Comparison_Datasheet)
* [Meraki Security and SD-WAN Licensing](https://documentation.meraki.com/Platform_Management/Product_Information/Licensing/Meraki_MX_Security_and_SD-WAN_Licensing)
**Licensing Options**
* [Bring Your Own License (BYOL)](#bring-your-own-license)
**Deployment Types**
* Single Device
* Redundant Devices
**Connectivity Options**
* With a Public IP Address
* Without a Public IP Address
## Device Details[​](#device-details "Link direto para Device Details")
|                                             | 2 Cores                       | 4 Cores |
| Memory                                      | 4 GB                          | 16 GB   |
| Software Package                            | vMX - Medium<br />vMX - Large |         |
| Virtual Data Interfaces Supported (Default) | 2                             |         |
| System Reserved Interfaces                  |                               |         |
\| Access Methods | SSH (CLI)<br />HTTPS (Web Console) | | | Image Version | See [Available Image Versions](/pt-BR/network-edge/vendors-devices/ne-certified-vnfs.md#cisco) | | | Restricted CLI Commands | None | |
## Prerequisites[​](#prerequisites "Link direto para Prerequisites")
Before beginning the device deployment process in Network Edge:
1. Create an account in the [Meraki Dashboard](https://account.meraki.com/login).
2. Sign in to the dashboard and create a new Organization and Network, selecting **Security appliance** as the network type.
3. Choose the required Meraki vMX device size.
4. On the device page, select **Generate authentication token** to create the Day-0 configuration file.
## Configuring a Cisco Meraki vMX Without an IP Address[​](#configuring-a-cisco-meraki-vmx-without-an-ip-address "Link direto para Configuring a Cisco Meraki vMX Without an IP Address")
If you create your Meraki vMX **Without an Equinix Public IP Address**, the VNF is provisioned without any public IP addresses on the WAN or Management interface.
![Connectivity Options](/pt-BR/assets/images/NE-without-EIP-234361a3b8c9d132698f02a45da958f3.png)
When entering the **Device Details**, select one of the following IP address options:
* DHCP - a network management protocol that automatically assigns IP addresses.
* Static IP Address - enter the IP address, subnet mask, and default gateway.
* NO IP Address - an IP address will not be assigned.
![IP Management Options](/pt-BR/assets/images/NE-IP-management-5c1e89398e202c6547242c0accb9deb7.png)
## Bring Your Own License[​](#bring-your-own-license "Link direto para Bring Your Own License")
* You can enter your License Token during the device creation process. Once you enter the license token, your virtual device will be provisioned with the license based on the token provided. If you do not provide token information, your virtual device will still be provisioned but you will need to manually register your license with the smart server using your license token after the virtual device is provisioned.
  ![](/pt-BR/assets/images/NE-Cisco-license-token-20f9d57ba8737b6103648219dfb5c451.png)
* Alternatively, you can enter your Smart License URL. You must have a valid Cisco account to complete this process. To get a Cisco Smart License token, follow the instructions in the [Cisco documentation](https://www.cisco.com/c/en/us/support/docs/licensing/common-licensing-issues/how-to/device-management/lic220943-how-can-i-create-a-token-to-register-my.html).
  * Sign in to the Cisco Smart Software Manager (CSSM) with your Cisco.com account credentials.
  * Locate the *Virtual Accounts* > *Inventory* section to create a new token.
  * Your newly created token will appear in the token list. Click the token to see the details and copy the token string.
  show license status
  If you encounter any issues or need more detailed steps, see [Cisco DNA Center Administrator Guide](https://www.cisco.com/c/en/us/support/cloud-systems-management/dna-center/products-maintenance-guides-list.html) or contact Cisco support.
* You are responsible for obtaining support from Cisco or their partners. If you are subscribing with a license from Equinix Network Edge, you can open a support case with Cisco Technical Assistant Center (TAC) to troubleshoot Cisco IOX-XE software issues or ask Cisco IOX-XE configuration questions from the Network Edge portal. See [Cisco Catalyst 8000V Subscriptions](/pt-BR/network-edge/vendors-devices/cisco/ne-cisco-8000v-specs.md#cisco-catalyst-8000v-subscriptions) for more information.
