# Conectando-se a um provedor de serviços Fabric Faça uma conexão de seus dispositivos Network Edge com clouds, redes e outros provedores de serviços. informações Este tópico aborda a conexão com provedores de serviços da Network Edge em geral. Para obter instruções e exemplos sobre como se conectar a um [provedor](https://docs.equinix.com/pt-BR/fabric-marketplace.md) de serviços específico, consulte a seção[Como se conectar a um provedor de serviços](https://docs.equinix.com/pt-BR/fabric-marketplace.md). Incluindo: * [Alibaba Cloud](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/fabric-alibaba-cloudexpress.md) * [AWS Direct Connect](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/aws/direct-connect-overview.md) * [Cisco](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/fabric-connect-cisco-webex.md) * [Colt](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/fabric-connect-colt.md) * [Five9](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/fabric-connect-five9-redundant.md) * [GCP](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/gcp/ne-gcp-connect.md) * [IBM Cloud](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/ibm/fabric-ibm-cloud-2_0.md) * [Lúmen](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/fabric-connect-lumen.md) * [Microsoft Azure](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/microsoft/ne-azure-expressroute.md) * [Dados da NTT](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/fabric-ntt-data-connect.md) * [Oracle Cloud](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/oracle/fabric-oracle-quick-connect.md) * [Salesforce](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/fabric-salesforce-hyperforce.md) * [Unitas Global](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/fabric-unitas-connect-port.md) * [Verizon](https://docs.equinix.com/pt-BR/fabric-marketplace/connecting-to-service-provider/verizon/ne-verizon-sdi.md) ## Pré-requisitos * Uma conta Equinix Customer Portal, com as seguintes [funções](https://docs.equinix.com/pt-BR/iam/roles-permissions/iam-roles-permission-reference.md) atribuídas: `Fabric Connections Manager` e `Network Edge Connections Manager`. * Um dispositivo virtual Network Edge. - Portal - API - Terraform 1. Faça login no [Equinix Customer Portal](https://portal.equinix.com/) e navegue até o *Painel do Network Edge* . 2. Use o menu suspenso *Seletor de projeto* para selecionar o projeto sob o qual você deseja criar a conexão. Para obter mais informações sobre projetos, consulte [Gerenciando projetos](https://docs.equinix.com/pt-BR/iam/resources/projects-manage.md). 1) Autenticar - Envie suas credenciais de usuário, ID do cliente e segredo do cliente para o OAuth2 autenticação. Consulte [Autenticação API](https://docs.equinix.com/pt-BR/equinix-api/api-authentication.md) para obter instruções sobre como chamar o OAuth API para validar e autenticar suas credenciais. 2) Determine as informações do seu dispositivo Network Edge usando os [`/ne/v1/devices`](https://docs.equinix.com/pt-BR/api-catalog/network-edgev1.md#tag/Virtual-Device/operation/getVirtualDevices)terminais ou[`/ne/v1/devices/{uuid}`](https://docs.equinix.com/pt-BR/api-catalog/network-edgev1.md#tag/Virtual-Device/operation/getVirtualDeviceByUuid). Você pode escolher qualquer interface disponível no dispositivo para sua conexão. A Equinix selecionará uma interface se você não especificar uma. 3) Determine as informações do perfil de serviço do provedor de serviços. Use o [`/fabric/v4/serviceProfiles/search`](https://docs.equinix.com/pt-BR/api-catalog/fabricv4.md#tag/Service-Profiles/operation/searchServiceProfiles) terminal para procurar um perfil de serviço específico ou use o [`/fabric/v4/serviceProfiles`](https://docs.equinix.com/pt-BR/api-catalog/fabricv4.md#tag/Service-Profiles/operation/listServiceProfiles) terminal para listar todos os perfis de serviço disponíveis e identificar o perfil ao qual você deseja se conectar. Você precisa do UUID do perfil do provedor de serviços. 1. Determine as informações do seu dispositivo Network Edge. Verifique seus dispositivos disponíveis usando a [`equinix_network_device`](https://docs.equinix.com/pt-BR/terraform/data-sources/network_device.md)fonte de dados. 2. Determine as informações do perfil de serviço do provedor de serviços. Use a [`equinix_fabric_service_profiles`](https://docs.equinix.com/pt-BR/terraform/data-sources/fabric_service_profiles.md)fonte de dados para procurar um perfil de serviço específico. Você precisa do UUID do perfil do provedor de serviços. ## Criando a conexão * Portal * API * Terraform 1. No *Painel do Network Edge* , clique em **Criar Conexão**. ![](https://docs.equinix.com/pt-BR/assets/images/service-provider-create-connection-49f02d48309fc652e6b31fbd69a326fd.png) 2. Na seção *Conexões frequentes*, selecione o provedor de serviços ao qual você está se conectando. Ou clique em *Um provedor de serviços* e procure o provedor de serviços. ![](https://docs.equinix.com/pt-BR/assets/images/serivce-provider-cards-e80561faaf2e366e03bfc30d2a44dd77.png) 3. Clique no cartão do provedor de serviços e clique em **Criar conexão (dispositivo Network Edge)**. ![](https://docs.equinix.com/pt-BR/assets/images/service-provider-card-colt-8ff205019a7283613feabbf1861d3a62.png) **Selecione os locais** Na página *Selecionar locais*: 1. Na seção *Origem* , em *Conectar usando*, clique em **Dispositivo Virtual** . 2. Selecione o dispositivo e o local de origem da conexão. 3. Na seção *Selecionar tipo de dispositivo virtual*, selecione um tipo de dispositivo: Dispositivos Virtuais, Dispositivos Redundantes ou Clusters. 4. Selecione o *Tipo de Conexão* . Se você selecionou um único dispositivo virtual, *Conexão única* será selecionada automaticamente. Se você estiver se conectando a um cluster ou dispositivos redundantes, poderá optar por criar uma *conexão redundante* ou uma *conexão única a partir de um único dispositivo* no par ou cluster redundante. 5. Selecione o(s) dispositivo(s) que você está usando para esta conexão. 6. A seção *Destino* é preenchida com suas opções de local da operadora à qual você está se conectando. Selecione o local do provedor de serviços ao qual você está se conectando. ![](https://docs.equinix.com/pt-BR/assets/images/service-provider-select-locations-02d1834374fc90626c90f6c12222255d.png) Clique em **Avançar**. **Detalhes da conexão** Na página *Detalhes da conexão*: 1. Na seção *Informações de conexão*, insira um nome de conexão. Para conexões redundantes, insira um nome para a conexão primária no campo *Informações da conexão* e um nome para a conexão secundária no campo *Informações da conexão redundante*. 2. Na seção *Seleção de interface*, selecione: * **Selecione automaticamente a próxima interface disponível no(s) meu(s) dispositivo(s)** se quiser criar a conexão na próxima interface disponível. * **Vou selecionar uma interface** se você quiser especificar a interface para a conexão. Selecione uma interface no menu suspenso. 3. Se o provedor de serviços exigir um ID de conta, chave de emparelhamento ou outra identificação, insira suas informações nos campos fornecidos. A seção *Opções Adicionais do Comprador* contém opções específicas para o provedor de serviços ao qual você está se conectando. Alguns deles podem ser necessários para se conectar. 4. *(Opcional)* Insira o número do pedido de compra. 5. Selecione a *Velocidade da conexão* para o dispositivo primário. Para conexões redundantes, selecione também a velocidade de conexão para o dispositivo secundário. ![](https://docs.equinix.com/pt-BR/assets/images/service-provider-connection-details-52ff1c1159610a24dcb56100cbd4afc8.png) Clique em **Avançar** **Revise e envie** Na página *Revisão*: 1. Consulte as informações no *Resumo da conexão* e *Visão geral de preços* . 2. Na seção *Notificações*, adicione os endereços de e-mail de todos os usuários que devem receber notificações sobre essa conexão. 3. Quando estiver pronto, clique em **Enviar seu pedido**. ![](https://docs.equinix.com/pt-BR/assets/images/service-provider-review-844551c2486a4ed12aa20f2a1e000143.png) Para criar uma conexão do seu dispositivo Network Edge com um provedor de serviços, envie uma `POST` solicitação para o [`/fabric/v4/connections`](https://docs.equinix.com/pt-BR/api-catalog/fabricv4.md#tag/Connections/operation/createConnection) terminal. * Especifique os detalhes do seu dispositivo virtual no `aSide.accessPoint` objeto. * Especifique as informações do provedor de serviços no `zSide.accessPoint`objeto. Os parâmetros necessários variam de acordo com o provedor de serviços. Consulte a documentação[Conexão com um provedor de serviços](https://docs.equinix.com/pt-BR/fabric-marketplace.md) para obter exemplos específicos. Exemplo de solicitação cURL: ``` curl -X POST 'https://api.equinix.com/fabric/v4/connections' \ -H 'content-type: application/json' \ -H 'authorization: Bearer ' \ -d '{ "type": "EVPL_VC", "name": "", "bandwidth": 1000, "aSide": { "accessPoint": { "type": "VD", "virtualDevice": { "type": "EDGE", "uuid": "" } } }, "zSide": { "accessPoint": { "type": "SP", "profile": { "type": "L2_PROFILE", "uuid": "" }, "location": { "metroCode": "" } } }, "project": { "projectId": "" }, "notifications": [ { "type": "ALL", "emails": [ "" ] } ] }' ``` Crie a conexão usando o [`equinix_fabric_connection`](https://docs.equinix.com/pt-BR/terraform/resources/fabric_connection.md) recurso. * Especifique os detalhes do seu dispositivo virtual no objeto`a_side` :`access_point`. * Especifique as informações do provedor de serviços no objeto`z_side` :`access_point`. Os parâmetros necessários variam de acordo com o provedor de serviços. Consulte a documentação[Conexão com um provedor de serviços](https://docs.equinix.com/pt-BR/fabric-marketplace.md) para obter exemplos específicos. ``` resource "equinix_fabric_connection" "vd2csp" { name = "" type = "IP_VC" notifications { type = "ALL" emails = ["", ""] } bandwidth = a_side { access_point { type = "VD" virtual_device { type = "EDGE" uuid = "" } } } z_side { access_point { type = "SP" profile { type = "L2_PROFILE" uuid = "" } location { metro_code = "" } } } } ``` Após enviar o pedido, um e-mail de verificação do pedido é enviado para os contatos de notificação. Quando a conexão é provisionada, os contatos também recebem um e-mail de confirmação. ## Monitoramento do status da conexão * Portal * API * Terraform Depois de criar uma conexão no Portal do Cliente, monitore seu status no [*Inventário de Conexões*](https://docs.equinix.com/pt-BR/fabric/managing-connections/fabric-new-connections-inventory.md) . Para verificar o status da conexão, envie uma `GET` solicitação para o [`/fabric/v4/connections/{connectionId}`](https://docs.equinix.com/pt-BR/api-catalog/fabricv4.md#tag/Connections/operation/getConnectionByUuid) terminal. Busque o status da conexão com a [`equinix_fabric_connections`](https://docs.equinix.com/pt-BR/terraform/data-sources/fabric_connections.md)fonte de dados. | Status do Equinix | Status do provedor | **Descrição** | | ----------------- | ------------------ | ----------------------------------------------------------------- | | `PROVISIONING` | `PROVISIONING` | A solicitação de conexão não foi enviada ao provedor de serviços. | | `PROVISIONED` | `PROVISIONING` | Estabelecimento de conexão em andamento. | | `PROVISIONED` | `PROVISIONED` | Conexão estabelecida. |
