Smart View Power Consumption Report Column Definitions
The data shown in the Smart View Power Consumption Report is aggregated to the selected Hierarchy level. For example, if you select Cage as the Hierarchy level, each row in the output report represents one day's data aggregated to the cage level. To see more granular data for each individual cabinet, circuit and meter, you must select those as the Hierarchy level for the report.
Cage Data Report​
  • Date – The date on which the readings are recorded. Each row of data corresponds to the daily values for each of the columns.
  • Cage Asset # – The number generated by Equinix back-office systems. It is a unique number assigned to a specific cage.
  • IBX – The data center in which the cage is located.
  • Cage – The ID of the physical location where the cage is located.
  • Cage Serial # – The unique identifier generated by Equinix back-office systems at the individual cage contract level. It is tied to the Draw Cap of that contract. A Cage can have multiple Cage Serial Numbers depending on the number of active contracts.
  • Usable kVA – The Usable kVA is the total maximum allowable draw of all installed primary circuits in the cage.
  • Draw Cap / PEC Cap – The Draw Cap is contractual kVA limit established per Cage Serial Number.
  • Primary Draw (kVA) – The average kVA collected throughout the day at the Cage Serial Number level. Data is aggregate from primary circuits and power meters.
  • Redundant Draw (kVA) – The Redundant Draw (kVA) is the average kVA collected throughout the day at the Cage Serial Number level. Data is aggregated from redundant circuits.
  • Average Draw (kVA) – The Average Draw (kVA) is the sum of the Primary Draw (kVA) and Redundant Draw (kVA) for each day.
  • Daily Peak Draw (kVA) – Daily Peak Draw (kVA) is determined in the following manner:
    • Sum the draw across all circuits/power meters for each recording interval throughout the day.
    • The interval with the highest draw is the Daily Peak Draw (kVA)
    Example: where there are 15-min readings collected throughout the day, there would be 96 readings in total for that day and the highest reading is captured as the Daily Peak Draw (kVA).
  • Average 30 day Peak Draw (kVA) – The average of the Daily Peak Draw (kVA) values over the past 30 days. For example, on May 30th, the Average 30 Day Peak Draw (kVA) value would be the average of the Daily Peak Draw (kVA) values from May 1st to 30th
  • Average 30 day Peak Draw kVA-to-Draw/PEC Cap % – The ratio of the Average 30 day Peak Draw (kVA) to Draw Cap for the given date expressed as a percentage.
  • Total kWh – The aggregated daily kWh of each primary/redundant circuit and power meter within the cage.
Cabinet Data Report​
  • IBX – The data center in which the zone is located.
  • Cabinet – The ID of the physical location where the cabinet is located.
  • Customer Cabinet Ref. No. – The Cabinet ID defined by the customer in Equinix back-office systems.
  • Usable kVA Installed – The total maximum allowable draw of all installed primary circuits in the cabinet
  • Primary Draw (kVA) – The average kVA collected throughout the day at the Cabinet level. Data is aggregated from primary circuits.
  • Redundant Draw (kVA) – The average kVA collected throughout the day at the Cage Serial Number level. Data is aggregrated from redundant circuits.
  • Average Draw (kVA) – The sum of the Primary Draw (kVA) and Redundant Draw (kVA) for each day.
  • Average Draw kVA-to-Usable kVA Installed % – The ratio of the Average Draw (kVA) to Usable kVA Installed for the given date expressed as a percentage.
    For example, where there are 15-min readings collected throughout the day, there would be 96 readings in total for that day and the highest reading is captured as the Daily Peak Draw (kVA).
  • Average 30 day Peak Draw kVA-to-Usable kVA Installed % – The ratio of the Average 30 day Peak Draw (kVA) to Usable kVA Installed for the given date expressed as a percentage.
Circuit Data Report​
  • Circuit Serial # – The unique identifier generated by Equinix back-office systems.
  • Electrical Panel – The point at which power is measured.
  • Circuit # – Indicates the circuit position on the Electrical Panel.
  • Pri / Red – Indicates whether the circuit is Primary or Redundant type.
  • Asset Description – Displays the amperage, voltage and phase of the circuit.
  • Sold Amp – Represents the amperage that is sold for each circuit.
  • Breaker Amp – Represents the maximum amperage the circuit is rated for.
  • Usable kVA – The total maximum allowable draw of each circuit based on the Sold Amp.
  • Breaker kVA – The total maximum draw of each circuit based on the Breaker Amp.
  • Draw Amp – The average amperage value collected throughout the day for each circuit or power meter.
  • Draw kVA – The average kVA collected throughout the day for each circuit or power meter.
  • Draw-to-Usable kVA % – The ratio of the Draw kVA to the Usable KVA for the given date expressed as a percentage.
  • Draw-to-Breaker kVA % – The ratio of the Draw KVA to the Breaker KVA for the given date expressed as a percentage.
  • kWh – The aggregated kWh collected throughout the day for each circuit or power meter.
Circuit and Meter Data Report​
  • Cabinet – The ID of the physical location where the cabinet is located. This column is not applicable for power meters.
  • Used for Billing – Indicates if the asset's power consumption data is used for billing. If a circuit is covered by an associated power meter that is used for billing instead, it will say "No" for the circuit. Filter for "Yes" in this column to see all relevant circuits and power meters used for billing.
  • Asset Type – Indicates the asset type.
  • Asset Serial # – The unique identifier generated by Equinix back-office systems.
  • Electrical Asset – The point at which power is measured.
  • Circuit # – Indicates the circuit position on the Electrical Panel. This column is not applicable for power meters.
  • Metered At – For a circuit that is covered by a power meter, "Metered At" indicates the Asset Serial Number of the associated power meter. This column is not applicable for power meters.
  • Pri / Red – Indicates whether the circuit is Primary or Redundant type. This column is not applicable for power meters.
  • Asset Description – Displays the amperage, voltage, and phase of the circuit. This column is not applicable for power meters.
  • Sold Amp – Represents the amperage that is sold for each circuit. This column is not applicable for power meters. Breaker Amp – Represents the maximum amperage the circuit is rated for.
  • Usable kVA – The total maximum allowable draw of each circuit based on the Sold Amp. This column is not applicable for power meters.
  • Breaker kVA – The total maximum draw of each circuit based on the Breaker Amp. Draw Amp – The average amperage value collected throughout the day for each circuit.
  • Draw kVA – The average kVA collected throughout the day for each circuit.
  • Draw-to-Usable kVA % – The ratio of the Draw kVA to the Usable KVA for the given date expressed as a percentage. This column is not applicable for power meters.
  • Draw-to-Breaker kVA % – The ratio of the Draw KVA to the Breaker KVA for the given date expressed as a percentage. This column is not applicable for power meters.
  • kWh – The aggregated kWh collected throughout the day for each circuit.
