Network Edge License Types
There are two license options available for Network Edge virtual devices: Bring Your Own License (BYOL) and Subscription License (currently limited to a few vendors). Availability of the license type varies by vendor, model, and deployment type. This document describes each license type and the considerations for each.
Support for vendor software and vendor software configuration is offered by the vendors.
License Option Summary
- Available for all VNF types (where supported by the vendor).
- License purchased directly from vendor or vendor reseller.
- Separate support contract required from each vendor.
- Equinix supports VNF infrastructure. VNF-specific issues need to be supported by VNF vendor through a separate support contract. See Device Configuration Responsibilities for more information.
- Suited for customers who need all VNF functions and flexibility in VNF management.
The BYOL license type is available for all VNFs (where supported by the vendor). Purchase a separate license and support contract from a vendor or vendor reseller. This option provides flexibility for enterprise customers if they already have a preferred network equipment reseller. A separate support contract provides direct access to the vendor support team.
- Currently available for limited VNF vendors.
- License subscriptions available from the Equinix Customer portal.
- For F5 devices, F5 requires a support account to access F5 support directly.
- For VyOS, Equinix offers a package that includes support.
- The Catalyst 8000V Autonomous mode subscription option allows you to troubleshoot Cisco 8000V software or configuration issues with the Cisco Technical Assistance Center (TAC). Equinix opens a TAC case for you, then you engage with Cisco TAC directly. For Equinix Network Edge infrastructure-related issues, Equinix will engage in the troubleshooting. Equinix will not engage in Cisco 8000V software or configuration issues and troubleshooting.
License Availability
The following tables illustrate the license type supported by each VNF vendor and product.
6WIND
| Device Type | Product Name | Deployment Types | License Types |
| Router | VSR | Single Redundant Cluster option not available | BYOL |
Arista
| Router | CloudEOS | Single Redundant Cluster option not available | BYOL |
| SD-WAN | VeloCloud SD-WAN Edge | Single Redundant Cluster option not available | BYOL |
Aruba
| SD-WAN | EdgeConnect | Single Redundant Cluster option not available | BYOL |
Aviatrix
| Cloud Networking | Aviatrix Spoke Edge | Single Redundant Cluster option not available | BYOL |
| Cloud Networking | Aviatrix Transit Edge | Single Redundant Cluster option not available | BYOL |
BlueCat
| Server | DNS and DHCP Server | Single Redundant Cluster option not available | BYOL |
| Server | Edge Service Point | Single Single Redundant Cluster option not available | BYOL |
Check Point
| Firewall | CloudGuard | Single Redundant Cluster option not available | BYOL |
Cisco
| Router | Catalyst 8000V | Single Redundant Cluster option not available | BYOL Subscription |
| SD-WAN | Catalyst 8000V | Single Redundant Cluster option not available | BYOL |
| Firewall | ASAv | Single Redundant Cluster option not supported | BYOL |
| Firewall | Threat Defense Virtual | Single Redundant Cluster option not supported | BYOL |
F5
| Load Balancer | NGINX | Single Redundant Cluster | Subscription |
| Cloud Networking | Distributed Cloud - Customer Edge (CE) | Single | BYOL |
Fortinet
| Firewall | FortiGate VM | Single Redundant Cluster | BYOL using supported Fortinet VM license entitlements, including FortiFlex token-based licensing. |
| SD-WAN | FortiGate VM | Single Redundant Cluster option not available | BYOL using supported Fortinet VM license entitlements, including FortiFlex token-based licensing. |
Fortinet legacy V-Series VM licensing models are deprecated and no longer recommended for new deployments. Customers should use current FortiGate VM licensing models supported by Fortinet, including FortiFlex token-based entitlements.
Infoblox
| Server | DNS and DHCP Server | Single Redundant Cluster | BYOL |
| Server | NIOS-X | Single Redundant | BYOL |
Juniper
| Firewall | vSRX | Single Redundant Cluster | BYOL |
| SD-WAN | vSRX | Single Redundant Cluster | BYOL |
Palo Alto Networks
| Firewall | VM-Series | Single Redundant Cluster | BYOL |
| SD-WAN | Prisma | Single Redundant Cluster option not available | BYOL |
Versa Networks
| SD-WAN | FlexVNF | Single Redundant Cluster option not available | BYOL |
VyOS
| Router | VyOS Universal Router | Single Redundant Cluster option not available | Subscription |
