VNF Image Versions
This topic lists the VNF types and versions that have been verified and tested by Equinix for Network Edge. The tables show which versions are available for new device deployments (Deployable Versions), the latest versions introduced with their release numbers, and any versions scheduled for retirement.
Equinix only supports deployment issues with these tested versions and not VNF feature-specific issues.
:::note Once the VNF image is verified with a specific version, Equinix releases those version codes for the Network Edge portal. Customers are advised to review the versions listed below. Unverified versions are either not tested or have been found to have compatibility issues during the pre-release testing process. Equinix will not support any troubleshooting efforts or provide root causes for untested versions. Customers need to work with the VNF vendor support teams to troubleshoot in such cases. For more information, see Shared Support Model :::
Retirement of the version is posted in this document 60 days prior. Removal of the version is upon a release date. (Release number is noted in the retirement date column.) In case of emergency (PSIRT or critical defect), Equinix reserves the right to remove the version from the portal for deployment. It is solely the responsibility of the customer to upgrade or downgrade VNF versions to mitigate security or other risks.
:::note Additionally, Equinix has ended its sale of Cisco CSR1000V VNF offering based on the CSR1000V End-of-Sales (EOS) announcement by Cisco. :::
6WIND
Product NameDeployable VersionsLatest Version Introduced (Release)Version Retirement Date
VSR3.10.83.10.8 (2026.5)
Arista
CloudEOS4.31.1F
4.32.0.1F
4.32.2F
4.31.1F (2024.2)
4.32.0.1F (2024.8)
4.32.2F (2024.9)
4.29.0 (2024.10)
VeloCloud SD-WAN Edge6.4.1.06.4.1.0 (2026.3)
Aruba
Edge Connect9.3.8.1
9.4.3.7
9.4.4.1
9.4.6.2
9.5.3.4
9.5.6.1
9.3.8.1 (2025.8)
9.4.3.7 (2025.8)
9.5.3.4 (2025.8)
8.3.7.0 (2023.10)
9.1.4.2* (2025.8)
9.2.4* (2025.8)
9.2.5* (2025.8)
9.2.9* (2025.8)
9.3.2* (2025.8)
9.4.2.3* (2025.8)
* Existing Aruba devices operating with this version continue to function, however they can't be upgraded to any of the currently available versions. To upgrade to any version introduced in 2025.8, you must delete your old device and deploy a new device. Deploying a new device with a newer version does not impact billing.
Aviatrix
Spoke Edge6.9*
7.1.g
7.2.c
8.1.0
Transit Edge7.2.c
8.1.0
* Aviatrix version 6.9 is limited with up to 3 interfaces and requires an additional supporting device for Layer 3 routing functionality. This means that if you select version 6.9, you need to have an additional support device (such as a router), connected through a DLG, to connect to the CSP. This requirement is removed when the 7.1 version is used. Version 7.1 release supports multiple virtual connections with up to 10 interfaces, BGP support on the WAN interface to support CSP private circuits connectivity. This version requires the 7.1 controller.
BlueCat
DNS and DHCP Server9.6.09.6.0 (2024.3)
Edge Service Point4.7.14.7.1 (2024.11)4.6.3 (2024.11)
4.7.0 (2424.11)
Check Point
CloudGuardR81.20
R82
R81.20 (2023.8)
R82 (2025.4)
R80.40 (2025.4) EOL*
*Read the Check Point blog for EOL information.
Cisco
Catalyst 8000V (Autonomous Mode)17.6.6a (BYOL only)
17.9.4a (BYOL only)
17.11.1a*
17.12.2
17.14.1a
17.15.1a
17.18.1a
17.6.6a (2024.2)
17.9.5a (2024.6)
17.11.1a *(2023.5)
17.12.2 (2024.2)
17.14.1a (2024.6)
17.15.1a (2024.10)
17.18.1a (2025.10)
17.6.1a (2023.7)
17.6.5 (2024.2)
17.9.4 (2023.12)
17.9.5a (2024.11)
17.12.1a (2024.2)
17.13.1a (2024.11)
Catalyst 8000V (Controller Mode)17.11.1a*
17.12.2
17.14.1a
17.15.1a
17.11.1a* (2023.5)
17.12.2 (2024.2)
17.14.1a (2024.6)
17.15.1a (2024.10)
17.9.4 (2024.2)
17.9.5a (2024.11)
17.12.1a (2024.2)
17.13.1a (2024.11)
ASAv9.20.2.2
9.20.2.10
9.20.2.2 (2024.2)
9.20.2.10 (2024.6)
9.16.1 (2024.4)
FTDv7.0.0.94
7.0.4.55
7.2.0.82
7.3.0.69
7.2.5.208
7.2.8-25
7.0.0.94 (2021.3)
7.0.4.55 (2022.6)
7.2.0.82 (2022.4)
7.3.0.69 (2023.2)
7.2.5-208 (2023.12)
7.2.8-25 (2024.8)
Meraki vMX (Beta)20.1.2-v620.1.2-v6 (2026.4)
* The subscription license for the Cisco Catalyst 8000V is only available for 17.11.1a or above. Additionally, the 16 Core size of the Catalyst 8000V is only supported with IOX-XE 17.11.1a or above.
F5
NGINX PlusR26 R26 (2022.3)
Distributed Cloud - Customer Edge (CE)9.2025.179.2025.17 (2025.7)
Fortinet
FortiGate VM7.0.17
7.4.4
7.4.7
7.6.1
7.6.2
7.0.17 (2025.3)
7.4.4 (2024.7)
7.4.7 (2025.3)
7.6.1 (2025.3)
7.6.2 (2025.3)
6.4.6 (2023.2)
6.4.11 (2025.5)
7.0.5 (2023.2)
7.0.8 (2023.2)
7.0.9 (2023.10)
7.0.11 (2023.10)
7.0.12 (2025.5)
7.0.13 (2025.5)
7.0.14 (2025.5)
7.0.15 (2025.5)
FortiGate SD-WAN7.0.17
7.4.7
7.6.2
7.0.17 (2025.3)
7.4.7 (2025.3)
7.6.2 (2025.3)
6.4.0 (2024.2)
6.4.6 (2023.2)
6.4.11 (2025.5)
6.4.13 (2025.5)
7.0.5 (2023.2)
7.0.8 (2023.2)
7.0.9 (2023.10)
7.0.11 (2023.10)
7.0.12 (2025.5)
7.0.13 (2025.5)
7.0.14 (2025.5)
Infoblox
NIOS DDI9.0.5 (DDI member)
9.0.7 (DDI manager and DDI member)
9.0.5 (2025.3)
9.0.7 (2025.12)
NIOS-X4.04.0 (2026.5)
Juniper
vSRX21.2R3-S2.9
22.4R2-S1.6
23.2R1.13
23.4R1.9
23.4R2-S2.1
24.2R1.17
21.2R3-S2.9 (2022.6)
22.4R2-S1.6 (2023.10)
23.2R1.13 (2023.10)
23.4R1.9 (2024.4)
23.4R2-S2.1 (2024.11)
24.2R1.17 (2024.11)
19.2R2.7 (2024.4)
19.4R3-S1.3 (2024.4)
20.2R3-S2.5 (2023.12)
vSRX SD-WAN19.3R2-S3.419.3R2.S3.4 (2021.1)
Netskope
Universal Zero Trust Network AccessR138R138 (2026.7)
Palo Alto Networks
VM-Series FW10.1.14-h6
10.1.14-h8 (except small)
10.2.10-h9
10.2.10-h12
10.2.10-h14
11.0.4-h6
11.1.4-h7
11.1.4-h13
11.2.3-h3
11.2.5
10.1.14-h6 (2024.12)
10.1.14-h8 (2025.2)
10.2.10-h9 (2024.12)
10.2.10-h12 (2025.2)
10.2.10-h14 (2025.4)
11.0.4-h6 (2024.12)
11.1.4-h7 (2024.12)
11.1.4-h13 (2025.4)
11.2.3-h3 (2024.12)
11.2.5 (2025.4)
9.1.12-h3 (2023.10)
10.1.3 (2024.2)
10.1.6-h6 (2024.2)
10.1.9-h1 (2024.2)
10.2.3 (2024.2)
10.1.10 (2024.12)*
10.1.12 (2024.12)*
10.2.4 (2024.12)*
10.2.6 (2024.12)*
10.2.9-h1 (2024.12)*
10.2.11-h1 (2024.12)*
11.0.2 (2024.12)*
11.0.4-h1 (2024.12)*
11.1.3 (2024.12)*
11.2.0 (2024.12)*
Prisma5.5.3-b2 (2022.1)
6.0.1-b70 (2023.2)
6.1.4-b2 (2023.12)
6.2.1-b3 (2023.12)
6.3.1-b6 (2024.5)
5.5.3-b2 (2022.1)
6.0.1-b70 (2023.2)
6.1.4-b2 (2023.12)
6.2.1-b3 (2023.12)
6.3.1-b6 (2024.5)
* Read the (CVE-2024-3400) and (CVE-2024-0012) Security Advisories from Palo Alto Networks.
Versa Networks
VOS (aka FlexVNF)20.2.4
21.2.3
22.1.1
22.1.2
22.1.4
20.2.4 (2022.2)
21.2.3 (2023.2)
22.1.1 (2023.8)
22.1.2 (2023.10)
22.1.4 (2025.4)
16.1R2S8 (2023.10)
VyOs
VyOS Universal Router1.3.2-2303
1.3.3-2302
1.3.5
1.4.0-2401
1.4.1-2501
1.4.2-2502
1.3.2-2303 (2023.6)
1.3.3-2302 (2023.10)
1.3.5 (2024.4)
1.4.1-2401 (2024.10)
1.4.1-2501 (2025.2)
1.4.2-2502 (2025.5)
1.3.2-2303 (2025.7) EOL*
1.3.3-2302 (2025.7) EOL*
1.3.5 (2025.7) EOL*
*Read the VyOS Networks Blog for EOL information.
