Cisco Adaptive Security Virtual Appliance
Licensing Options
Deployment Types
  • Single Device
  • Redundant Devices
Connectivity Options
  • With a Public IP Address
Cisco Adaptive Security Virtual Appliance Specifications​
Device Resources2 Cores - 4 GB
4 Cores - 8 GB
8 Cores - 16 GB
Software PackageStandard
Interfaces Supported (default/max)10/10
System Reserved InterfacesManagement 0/0 (MGMT)
GigabitEthernet 0/1 (WAN)
Available License TypeBYOL
Access MethodsSSH (CLI)
HTTPS (Web Console)
ConnectivityWith Equinix Public IP Address
RMASupported
SnapshotSupported
ResizeSupported
Bring Your Own License​
  • You can enter your License Token during the device creation process. Once you enter the license token, your virtual device will be provisioned with the license based on the token provided. If you do not provide token information, your virtual device will still be provisioned but you will need to manually register your license with the smart server using your license token after the virtual device is provisioned.
  • Alternatively, you can enter your Smart License URL. You must have a valid Cisco account to complete this process. To get a Cisco Smart License token, follow the instructions in the Cisco documentation.
    • Sign in to the Cisco Smart Software Manager (CSSM) with your Cisco.com account credentials.
    • Locate the Virtual Accounts > Inventory section to create a new token.
    • Your newly created token will appear in the token list. Click the token to see the details and copy the token string.
    show license status
    If you encounter any issues or need more detailed steps, see Cisco DNA Center Administrator Guide or contact Cisco support.
