Cluster Node Failure
Each NE deployment has a hot standby node (N+1 redundancy) connected to the POD that can be deployed into any plane if needed. If the remaining active nodes can accommodate the NEDs on the failed node, we do not deploy the hot standby node. Equinix only deploys it if there is not enough capacity on the remaining nodes.
