# Cisco Catalyst 8000V SD-WAN Device Recovery Process Cisco Catalyst 8000V SD-WAN device requires a manual recovery process in cases where the Virtual Network Function (VNF) goes into an unrecoverable state. This topic provides vendor-specific instructions for the recovery of Cisco Catalyst 8000V SD-WAN VNF. The recovery process steps include: 1. Generate a new bootstrap file. 2. Download the new bootstrap file. 3. Back up the Device Configuration from the failed device. 4. Restore the configuration to the new device. Create and deploy a new Cisco Catalyst 8000V SD-WAN VNF device using the following: * A unique system IP * The same site ID as the failed device * A new bootstrap file note For the most up-to-date documentation on the bootstrap generation, see [Bootstrap Process for Cisco SD-WAN Cloud-Hosted Devices](https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/sdwan-xe-gs-book/install-upgrade-17-2-later.html#bootstrap-process-sd-wan-cloud-hosted-devices). ## Re-Instantiate Catalyst 8000V SD-WAN Device 1. Sign in to the [Equinix Customer Portal](https://portal.equinix.com/ne/new-virtual-device) and navigate to Network Edge. 2. On the **Network Edge** menu, select **Virtual Device Inventory**. 3. Use the search filters to locate the impacted Cisco Catalyst 8000V SD-WAN device. Make sure you select the correct replacement device. 4. Click the device name, and then click **Tools**. ![](https://docs.equinix.com/assets/images/NE-Cisco-CVIM-tools-b011facc8f21bd10f25e130df52a1008.png) 5. In the **Replace Virtual Device** section, click **Replace Virtual Device**. ![](https://docs.equinix.com/assets/images/NE-Cisco-CVIM-replace-device-318dabfdaac49869c6d040961d78150c.png) Click **Request Replacement**. ![](https://docs.equinix.com/assets/images/NE-cvim-request-replace-2f525172c9053e2ae0d2479a855b2119.png) 6. In the **Request** box, enter the **Site ID**, **System IP**, and click **Upload File** to upload your Bootstrap file. info The **System IP** must be different from the IP for the failed device. However, it is highly recommended you use the same Site ID as the one used for the device you are replacing. note The Bootstrap file extension must be **.cfg** and the file size can’t be larger than 2 MB. ![](https://docs.equinix.com/assets/images/NE-cvim-Cisco-8KV-request-ee6add9956effe2958aa5573108e827c.png) 7. Click **Request**. 8. In the **Confirm Request** box, click **Submit Request**. ![](https://docs.equinix.com/assets/images/NE-Cisco-CVIM-submit-request-487cef7d9a4986538f7c38585a922798.png) warning Once the request has been submitted, this process can’t be canceled. While the device recovery request is in progress, the device status will change to **Provisioning**. Once the process is done, the status changes to **Completed** and includes a timestamp. The **Device Provisioning Status** changes to **Provisioned**. If any issues prevent the process from completing successfully, the status will read **Failed**. If a failure occurs, open a support case. For information about opening a case, see [Support](https://docs.equinix.com/en-us/Content/Interconnection/NE/user-guide/NE-Support.htm). 14. After the recovery process is completed, log into Cisco vManage and verify that your new virtual devices are discovered by the vManage. ## Back Up Device Configuration from Failed Device Re-apply the configuration and license to the newly created virtual device so that the edge device can be completely recovered from the failure. To do this, you must first back up the current configuration in the device template. 1. In the Cisco vManage SD-WAN Controller, go to **vManage** > **Configuration** > **Templates** > **Device Templates** and click the options menu, then click **Export CSV** to back up the configuration in CSV format. 2. Confirm that the failed device is reachable from vManage. * If the failed device is reachable, remove the failed device from the **Device Template Attached** by going to **vManage** > **Configuration** > **Templates** > **Device Templates**, clicking the options menu, and selecting **Detach Devices**. * Invalidate the failed device by going to **vManage** > **Configuration** > **Certificates** > **WAN Edge List**and clicking **Invalid**. note After the device template removal, all the variable values from the templates are lost. It is not possible to detach a device template if the Edge router is in an unreachable state. The message **Please fix DTLS, NETCONF connectivity between device and vManage before template attempt workflow.** displays in the vManage GUI. 3. Go to **vManage** > **Configuration** > **Certificates** and click **Send to Controllers** to send the change to the controller. ## Restore Configuration to the New Device The final step is restoring the configuration to newly created Edge device. 1. Restore the values from CSV to the template by going to **vManage** > **Configuration** > **Templates** > **Device Templates** and clicking the options menu. 2. Click the options menu again and then click **Edit** to restore the value from CSV file. 3. After restoring the value, attach the device to the new template by going to **vManage** > **Configuration** > **Templates** > **Device Templates** and clicking the options menu. 4. Click the options menu again and then click **Attach Devices** to attach the new device to the same template. 5. Verify the configuration before committing the change.
