Failure Scenarios for Network Edge Infrastructure
This topic shows examples of possible failures in Network Edge, and how Equinix responds.
This diagram shows the possible points of failure. The numbers correspond to the explanations below.
ECN Node or Link Failure:
  • Equinix automatically reroutes the traffic.
  • Equinix raises a Priority 2 incident.
  • You are notified of a loss of resiliency.
ECX Node or Link Failure:
  • Single and cluster Network Edge VNF connectivity will be disrupted. Redundant VNFs require redundant connectivity for higher resiliency.
  • Equinix raises a Priority 1 incident if single and cluster VNF services are disrupted. Equinix raises a Priority 2 incident if the redundant VNF provides redundant connectivity through secondary ECX Node.
SPINE node failure:
TOR Node or Link Failure:
COMPUTE Failure:
  • Equinix automatically redeploys environments on the same compute if the incident time is less than 30 minutes.
  • After 30 minutes, Equinix redeploys the device on a new compute.
  • You are sent a redeployment alert.
Network Edge Device Failure:
Compound ECX Node Failure:
  • Equinix raises Priority 1 incident.
  • You are notified of a loss of service.
Compound ECN Node Failure:
Compound TOR Failure:
Compound SPINE Failure:
