# Escalation Management Follow these guidelines and escalation paths for any issue that requires escalation. When to escalate: * In the event of a process or incident failure, if required. To ensure effective escalation: * Escalate in sequence, one level at a time, allowing enough time to deliver sufficient results before engaging the next level. * For all escalations past Level 2, if no email response is received, you must make a phone call. When to expect a response: * The relevant escalation contact sets clear expectations about escalation updates and action plans. * If you feel that an escalation is not receiving the appropriate focus, request escalation to the next level. | Level | Escalation (all regions) | | ----- | -------------------------------------------------------------------------------------------------------------------------------------------------------------- | | 1 | Log in to the [Equinix Customer Portal](https://portal.equinix.com/) or contact the [Global Service Desk](https://www.equinix.com/contact-us/customer-support) | | 2 | [GSD Recovery Team](mailto:GSDServiceRecovery@equinix.com) | | 3 | Regional Lead | | 4 | Global Functional Leads | | 5 | Global Lead |
