# Global Network Optimization with SD-WAN and Equinix Fabric As SD-WAN networks span larger geographic distances, consideration needs to be given to how these countries and regions are connected. This topic describes an approach to optimizing global SD-WAN networks using Network Edge and Equinix Fabric. A standard way to optimize global SD-WAN networks is to create regional hubs (also referred to as on-ramps) that are connected to a common backbone. This model decouples the local and global networking components, providing flexibility and choice in how each hub will connect to local sites and users. The successful optimization of a global SD-WAN network is dependent on two things: 1. Highly interconnected hubs, providing access to networks, clouds and other business partners. 2. A high performing, cost-effective backbone for global connectivity and on-ramp resiliency. Network Edge, in combination with our global SDN offer, Equinix Fabric, meets these key criteria. Network Edge and Fabric provide a consistent platform for global connectivity to clouds, networks, or business partners. ## Architecture[​](#architecture "Direct link to Architecture") The global SD-WAN backbone deployment in this reference architecture utilizes SD-WAN virtual appliances deployed in different metros on the Network Edge infrastructure, connected together using the Equinix Fabric. These Network Edge deployments will act as the regional hubs. Being integrated directly into Equinix Fabric, Network Edge devices have the necessary interconnection to clouds and networks to make this architecture successful. Additionally, Equinix Fabric will be used to provide the underlay connectivity for the global SD-WAN overlay. When looking at Equinix Fabric for global connectivity between Network Edge devices, two main networking approaches are supported: * Virtual Circuit – This is the typical Equinix Fabric connectivity model in which a virtual circuit is created between two devices to create a point-to-point connection. * Device Link – This is a full-mesh globally available VPLS that will place all connected devices into a single broadcast domain. More information about device linking, see [Device Link](https://docs.equinix.com/network-edge/device-link/ne-device-link.md). it's also worth noting that each networking service (both point-to-point virtual circuits and device links) use one interface on the virtual appliance, making device link a lot more scalable across large deployments. However, if a semi-meshed network topology is desired, a combination of both of these services can be used. The diagram below assumes that device link is used to connect all of the virtual SD-WAN hubs across the different metros, as this provides the most scalable solution as additional metros are deployed in the future.
![](https://docs.equinix.com/assets/images/NE-ref-arch14-6005639208122fa638e086fb2af29cbd.png) ## Equinix Components[​](#equinix-components "Direct link to Equinix Components") * Equinix Fabric – Equinix Fabric is a switching platform that provides private connectivity to a wide selection of providers that are participants on the Fabric. Virtual circuits are provisioned on the Fabric using software-defined networking to establish connectivity to providers that are connected to the Fabric. Virtual connections can be created using the Customer Portal or APIs. * Equinix Network Edge – Network Edge is an ETSI-compliant NFV platform that hosts VNFs (routers, firewalls, and SD-WAN) from various vendors such as Cisco, Juniper, Palo Alto, Fortinet, Versa, Aruba, and Check Point. VNFs can be deployed in real-time and, once deployed, you can start building virtual connections to providers on the Fabric. * Equinix Device Link – A globally available VPLS service that is unique to the Equinix Network Edge offer. It allows for multiple devices to be put into a single, fully meshed, broadcast domain. ## Cloud Service Provider (CSP) Components[​](#cloud-service-provider-csp-components "Direct link to Cloud Service Provider (CSP) Components") * Private interconnection – Private interconnections from the CSP are Layer 2 partner or hosted connections that connect to the Equinix Fabric. Partner or hosted connections provide an intermediate switch between a device and the CSP router it peers with. Once the private Layer 2 interconnection has been established, you can set up Layer 3 peering with the CSP gateway. Private interconnections bypass the internet. * Cloud gateway – The cloud gateway is a software-defined router that is instantiated in the CSP network and connected to the virtual private cloud. The cloud gateway is used to establish BGP peering to the Network Edge device and is attached to the virtual private cloud (VPC) providing reachability between clouds. * Virtual private cloud – The VPC is a virtual network that serves as the container to deploy subnets and other networking constructs to instantiate compute and other application services. ## Network Service Provider[​](#network-service-provider "Direct link to Network Service Provider") * Private interconnection – Depending on the level of integration that a NSP has with Equinix Fabric, connectivity can either be through a software-defined interconnect (for select, pre-integrated providers) or the BYOC workflow (for service providers who are not integrated into Fabric). Customers are still required to maintain a contract/arrangement with the NSP for connectivity beyond the private interconnection facilitated by Equinix Fabric. ## Recommendations[​](#recommendations "Direct link to Recommendations") These recommendations provide a starting point. Customer requirements might differ from this list. ### Choice of Location[​](#choice-of-location "Direct link to Choice of Location") * One important key to interconnection is proximity to the resources that are being consumed. In relation to this architecture, this means the proximity of Network Edge infrastructure to the NSP and CSP edges. Not every CSP has an on-ramp in every location – the same applies for the edges of a NSP’s network and Network Edge infrastructure. * To keep the network latency as low as possible, it's recommended that you select a metro that has the best interconnection to the providers that you need. See the [Equinix Service Provider list](https://www.equinix.com.au/interconnection-services/equinix-fabric/provider-availability/) to learn more about which providers are local to which metros. * See the [Network Edge Data Sheet](https://www.equinix.com/resources/data-sheets/modernize-your-network/) for information about locations. ### High Availability[​](#high-availability "Direct link to High Availability") * This high-level design shows a single end-to-end connection from NSP, to virtual appliance, to cloud. * Some CSPs (such as Microsoft Azure ExpressRoute) mandate redundant private connectivity. This presents as two virtual circuits within the Equinix Fabric. While both circuits can be connected to a single virtual appliance, there are considerations around creating VNF-level diversity * Network Edge offers the ability for high availability and clustered (for select VNFs) appliance deployment models. * Careful consideration should be given to the design of solutions to ensure that service impacting events are minimized. ### Network CIDR Blocks[​](#network-cidr-blocks "Direct link to Network CIDR Blocks") To avoid requirements around NAT (network address translation) / PAT (port address translation), select CIDR blocks that don't overlap with any other network to which you intend to set up private connections. ## Considerations[​](#considerations "Direct link to Considerations") When implementing this architecture, consider the following factors: ### Performance[​](#performance "Direct link to Performance") In addition to latency, bandwidth between the components and device throughput must is important. The virtual circuits must be sized appropriately, and the devices must support the desired throughput. ### Security[​](#security "Direct link to Security") Private interconnections on the Fabric to the cloud provider are not encrypted. An application that requires encryption must encrypt either at the application layer, or at the network layer where IPSEC tunnels can be built between the Network Edge device and a cloud gateway. IPSEC tunnels involve overhead, which also affects the device selection. ### Equinix Costs[​](#equinix-costs "Direct link to Equinix Costs") * Device instance – The cost for the virtual device (does not include the license cost). * License for the virtual device – Customers can purchase a subscription license for some vendors. Bring Your Own License (BYOL) is available for all vendors. * Virtual circuits – Monthly recurring charges are based on the size of the circuits. Connections between metros across the Equinix Fabric, incur an additional surcharge for the remote connection. * Equinix Fabric port – Charged if BYOC is used to connect to NSPs/ISPs. ### CSP Costs[​](#csp-costs "Direct link to CSP Costs") * Egress Charges – Charged by some service providers based on the amount of data that is transmitted over the private interconnection. These charges vary based on the provider. Using a private interconnection reduces the egress charges when compared to the Internet. * Private Connectivity Charges – Charged monthly by some providers for the private circuit into their environment. Both egress and private connectivity charges factor into your application design. ### NSP Costs[​](#nsp-costs "Direct link to NSP Costs") Any charge incurred by the NSP will be billed directly from the cloud service provider (CSP). ### Scalability[​](#scalability "Direct link to Scalability") * Even though this reference architecture focuses on two different CSP environments, the virtual appliance in Network Edge can connect to any destination on Equinix Fabric. This allows for additional destinations to be connected using the same model highlighted above. * The limiting factor for the scalability of a single appliance is the number of virtual interfaces supported, as well as the throughput for high bandwidth environments. Related Topics * [Network Edge Architecting for Resiliency](https://docs.equinix.com/network-edge/ne-architecting-resiliency.md) * [Verizon Software Defined Interconnect](https://www.verizon.com/about/news/verizon-software-defined-interconnect-private-ip) * [Tech Talk – Bring Your Own Connection (Part 1)](https://youtu.be/U0c92yUAsb8) * [Tech Talk – Bring Your Own Connection (Part 2)](https://youtu.be/BUbsTrx3lV4)
