# Create a Device ![](https://docs.equinix.com/assets/images/LaunchVirtualDevice-48c8825b5fcf89576c1c90b5a92ad0cc.png) ## Prerequisites[​](#prerequisites "Direct link to Prerequisites") Authenticate - Submit your user credentials, Client ID, and Client Secret for OAuth2 authentication. Refer to [API Authentication](https://docs.equinix.com/equinix-api/api-authentication.md) for instructions on how to call the OAuth API to validate and authenticate your credentials. ## Step 2: Get Device Details[​](#step-2-get-device-details "Direct link to Step 2: Get Device Details") * Call [Get Device Types](https://docs.equinix.com/api-catalog/networkedgev1/availability-and-metros/getvirtualdevicetypes.md) to find out which self-configured device (e.g., router or firewall) you want to launch on the NE platform. You will learn about the metro regions where virtual devices are available, vendors of devices, the available number of cores, and the software packages and their versions. Select `deviceTypeCode`, `metroCode`, `core`, `packageCode`, and `version`. * Call [Get Allowed Interfaces](https://docs.equinix.com/api-catalog/networkedgev1/availability-and-metros/getallowedinterfaces.md) to find out the allowed number of interfaces for your selected core. You may select any available device interface as `sshInterfaceId`. Otherwise, Equinix will choose the first available interface. * Call [Get Accounts {metro}](https://docs.equinix.com/api-catalog/networkedgev1/availability-and-metros/getaccountswithstatus.md) to check your account number (or `accountReferenceId`) and status in the metro where you want a virtual device. For billing reasons, you must have an account in the metro where you want a virtual device, either in the Active or Pending state. Create an [account](https://docs.equinix.com/en-us/Content/Interconnection/NE/user-guide/NE-billing-account-creation.htm) if you do not have one. If you are a **reseller** trying to create a device for your customer, you must ensure that the customer's and your (reseller's) accounts are both in the Active or Pending status. Your account will get billed, however, you must send the customer's account number to the API to create a device for your customer. ## Step 3: Licensing Options[​](#step-3-licensing-options "Direct link to Step 3: Licensing Options") We offer BYOL (Bring Your Own Licensing) as a licensing option for most devices. Upload a license file or a code/token/ID, depending on what your vendor offers. For Cisco 8000V, you have the Subscription licensing option. * Arista: We don't support uploading a license for Arista device. However, you can log in to your device after it is created to upload a license to increase your throughput. * Cisco and Palo Alto provide license tokens. Enter the license token in the `licenseToken` field. * Juniper provides license files. To bring your own license (BYOL) for a Juniper device, use [Post License File](https://docs.equinix.com/api-catalog/networkedgev1/availability-and-metros/uploadlicense.md) to upload a license file. You will get a file ID that you can use to create a virtual device. In case you have a redundant Juniper device, you can use the same fileId for both the primary and secondary devices. * Fortinet: License is not mandatory for Fortinet devices at the time of device creation. If you have a token, enter it in the `licenseToken` field. To configure a license file for a Fortinet device, you must do the following: * Generate a license file on the Fortinet portal. * Upload the license file on the Equinix portal by calling [Post License File](https://docs.equinix.com/api-catalog/networkedgev1/availability-and-metros/uploadlicense.md). You'll get a `fileId` that you can use to create a virtual device. - Log in to the device to check your license status. ## Step 4: Create Self-Configured Device[​](#step-4-create-self-configured-device "Direct link to Step 4: Create Self-Configured Device") | | POST /ne/v1/devices | | ---------------- | ------------------------------------- | | Method | `POST` | | URL or End Point | `/ne/v1/devices` | | Headers | `Authorization` token, `Content-Type` | | Query Parameters | `draft`, `draftUuid` | To create a redundant device that has primary and secondary devices: * Set parameters of the secondary object * If you are a **reseller** trying to create a redundant device for your customer, make sure both the primary and secondary metros are in the same country. Both the primary and secondary account numbers must be the same. Although the reseller's account will get billed, this API accepts the customer's account number to create devices for the customer. The above restrictions are necessary as each customer is associated with a reseller's billing account. * In the case of Cisco FTD devices, the management type for both the primary and the secondary devices must be the same. > **Note** > > By creating a virtual device, you accept the Order Terms. Call [Get Order Terms](https://docs.equinix.com/api-catalog/networkedgev1/availability-and-metros/getorderterms.md) to review the details. To save a device draft, you must provide `deviceTypeCode`, `accountNumber` or `accountReferenceId`, and `metroCode`. ## Example Requests[​](#example-requests "Direct link to Example Requests") A sample curl request to create a single device. ``` curl -X POST "https://api.equinix.com/ne/v1/devices?draft=false" -H "content-type: application/json" -H "Authorization: Bearer " -d ' {     "metroCode": "SV",     "deviceTypeCode": "VSRX",     "agreeOrderTerms": true,     "termLength": "1",     "licenseMode": "BYOL",     "packageCode": "STD",     "virtualDeviceName": "Test-device-001-SROY",     "notifications": [         "test@equinix.com"     ],     "hostNamePrefix": "TC12",     "aclDetails": [         {             "uuid": "fb2e69bb-cbd7-40c4-bc01-8bcc5fa741c2",             "interfaceType": "WAN"         }     ],     "accountNumber": "200541",     "version": "23.2R1.13",     "interfaceCount": 8,     "deviceManagementType": "SELF-CONFIGURED",     "core": 2,     "userPublicKey": {         "username": "userName",         "keyName": "keyName"     },     "additionalBandwidth": "100" } ' ``` A sample curl request to create a redundant device. ``` curl -X POST "https://api.equinix.com/ne/v1/devices?draft=false" -H "content-type: application/json" -H "Authorization: Bearer " -d ' {     "metroCode": "DC",     "deviceTypeCode": "C8000V",     "agreeOrderTerms": true,     "termLength": "1",     "licenseMode": "BYOL",     "packageCode": "network-advantage",     "virtualDeviceName": "Test-device-001-SROY - primary",     "notifications": [         "test@equinix.com"     ],     "hostNamePrefix": "TC01",         "aclDetails": [         {             "uuid": "fb2e69bb-cbd7-40c4-bc01-8bcc5fa741c2",             "interfaceType": "WAN"         }     ],     "accountNumber": "201148",     "version": "17.06.06a",     "interfaceCount": 10,     "deviceManagementType": "SELF-CONFIGURED",     "core": 2,     "userPublicKey": {         "username": "sroy",         "keyName": "keyWIQzB"     },     "sshInterfaceId": "3",     "channelPartner": "SDCI",     "secondary": {         "metroCode": "DC",         "hostNamePrefix": "TC02",         "notifications": [             "test@equinix.com"         ],         "virtualDeviceName": "Test-device-002-SROY - secondary",         "additionalBandwidth": "100",             "aclDetails": [         {             "uuid": "fb2e69bb-cbd7-40c4-bc01-8bcc5fa741c2",             "interfaceType": "WAN"         }     ],         "accountNumber": "201148",         "sshInterfaceId": "4"     } } ' ``` A sample curl request to create a Cisco FTD secondary device with no internet access. ``` curl -X POST "https://api.equinix.com/ne/v1/devices?draft=false" -H "content-type: application/json" -H "Authorization: Bearer " -d ' {     "deviceTypeCode": "Cisco_NGFW",     "licenseMode": "BYOL",     "packageCode": "FTDv5",     "virtualDeviceName": "NEAut-",     "metroCode": "DC",     "notifications": [         "t@t.com"     ],     "hostNamePrefix": "test",     "interfaceCount": 10,     "deviceManagementType": "SELF-CONFIGURED",     "core": 4,     "version": "7.0.4-55",     "vendorConfig": {         "managementType": "FDM"     },     "connectivity": "PRIVATE",     "secondary": {         "hostNamePrefix": "test-123",         "metroCode": "DC",         "notifications": [             "t@t.com"         ],         "virtualDeviceName": "test-secondary",         "vendorConfig": {             "managementType": "FDM"         }     } } ' ``` For a complete list of parameters and options, see the [API Reference](https://docs.equinix.com/api-catalog/networkedgev1/virtual-device/createvirtualdevice.md). ## Example Responses[​](#example-responses "Direct link to Example Responses") Sample response for a single device. 202: Request accepted. ``` {     "uuid": "74d8c6b6-3153-4271-9f0e-45bdc7094dec" } ``` Sample response for a redundant device. 202: Request accepted. ``` {     "uuid": "74d8c6b6-3153-4271-9f0e-45bdc7094dec",     "secondaryUuid": "de5cf79b-3d16-4ccd-841b-3b68ecda2142" } ``` ## Device Status[​](#device-status "Direct link to Device Status") Monitor the status of your device by calling [Get Virtual Device {uuid}](https://docs.equinix.com/api-catalog/networkedgev1/virtual-device/getvirtualdevicebyuuid.md). Your device must be provisioned and your license must be registered before you can connect to cloud service providers. | **Virtual device "status"** | **Description** | | --------------------------- | ----------------------------------------------------------------------------------------------------------------------------------------- | | `INITIALIZING` | Equinix is in the process of reserving resources and creating the device. | | `PROVISIONING` | The device is booting. | | `PENDING_ORDER` | The order has come to NE from Siebel. Customers need to log in to the NE portal and submit the order. | | `PENDING_SIGNATURE` | The customer has signed up for the offline acceptance of NE terms but has not yet accepted the terms. | | `CANCEL_ORDER` | The order from Siebel to NE is canceled. | | `WAITING_FOR_PRIMARY` | The secondary device is ready but the primary is not. This state might appear only if you have created a secondary device for redundancy. | | `WAITING_FOR_SECONDARY` | The primary device is ready but the secondary is not. This state might appear only if you have created a secondary device for redundancy. | | `FAILED` | The device creation failed. | | `PROVISIONED` | The device is ready. | ![](https://docs.equinix.com/assets/images/LaunchSelfConfiguredDeviceStatus-d63f23898d5988482946da4824869a64.png) When end-users delete a device using the [Delete Virtual Devices](https://docs.equinix.com/api-catalog/networkedgev1/virtual-device/deletevirtualdevicebyuuid.md) API, the device transitions through the following states within the Equinix infrastructure. | Virtual device "status" under /ne/v1/devices/{uuid} | Description | | --------------------------------------------------- | ------------------------------------------------------------------- | | DEPROVISIONING | Equinix accepted the customer's request to delete a virtual device. | | DEPROVISIONED | The device is de-provisioned/deleted. |
