# Create a Device Link Group A device link group can include any virtual device that is provisioned and registered unless the device interfaces are already full. To learn more about device links, see the Network Edge [guide](https://docs.equinix.com/network-edge/device-link/ne-device-link.md). To create a device link group using APIs, you must have the following: * At least two provisioned virtual devices with registered licenses. You must have the `deviceUuids` and the `metroCodes` where the devices are located. * You need to provide ASNs for the devices if the ASNs have not been set. If a device already has an ASN, retrieve the ASN by calling [Get Virtual Device](https://docs.equinix.com/api-catalog/network-edgev1/virtual-device/getvirtualdevices.md). * Equinix billing account number. Your account must be in the Active or Pending status. You must provide an account number for every link you create. * Choose a subnet for the group. You must choose a subnet keeping in mind the number of devices you wish to add to the group. This is not a mandatory field at the time you try to create a linking group; however, you must provide this to have a functional linking group. * Provide `metroLinks` information (account number, throughput, metroCode) unless the devices are in the same metro. ## Prerequisites[​](#prerequisites "Direct link to Prerequisites") Authenticate - Submit your user credentials, Client ID, and Client Secret for OAuth2 authentication. Refer to [API Authentication](https://docs.equinix.com/equinix-api/api-authentication.md) for instructions on how to call the OAuth API to validate and authenticate your credentials. ## Step 2: Get Virtual Devices[​](#step-2-get-virtual-devices "Direct link to Step 2: Get Virtual Devices") To get details of your virtual devices, call [Get Virtual Devices](https://docs.equinix.com/api-catalog/network-edgev1/virtual-device/getvirtualdevices.md). The response will include: * `virtualDeviceUuids` * `metroCodes`, * `ASNs` * `accountNumbers`. ## Step 3: Create Device Link[​](#step-3-create-device-link "Direct link to Step 3: Create Device Link") | | `POST /ne/v1/links` | | ---------------- | ----------------------------------------------------------------------------------------------------------------------------------------------------------- | | Method | `POST` | | URL or End Point | `/ne/v1/links` | | Headers | `Authorization`, `Content-Type` | | Path Parameters | NA | | Body Parameters | `groupName`, `subnet`, `redundancyType`, `linkDevices[deviceUuid, asn, interfaceId]`, `metroLinks[ {accountNumber, throughput, throughputUnit, metroCode}]` | A sample curl request to create a device link group between two devices in two different metros. ``` curl -X POST "https://api.equinix.com/ne/v1/links" -H "content-type: application/json" -H "Authorization: Bearer " -d '{   "groupName": "test-link",   "subnet": "10.0.0.0/27",     "redundancyType": "SECONDARY",   "linkDevices": [     {       "deviceUuid": "d186dc1a-29e7-4829-bb5e-50fa57aca923",       "asn": 65414,       "interfaceId": 6     },     {       "deviceUuid": "ea128600-1875-4f7a-80e9-307a5bbeac51",       "asn": 100,       "interfaceId": 6     }   ],   "metroLinks": [     {       "accountNumber": "23945678",       "metroCode": "SV",       "throughput": 1000,       "throughputUnit": "Mbps"     },     {       "accountNumber": "2395123",       "metroCode": "SY",       "throughput": 1000,       "throughputUnit": "Mbps"     }   ]   }' ``` A sample curl request to create a device link between two devices within a metro. ``` curl -X POST "https://api.equinix.com/ne/v1/links" -H "content-type: application/json" -H "Authorization: Bearer " -d '{     "groupName": "test-link",     "subnet": "10.0.0.0/27",     "redundancyType": "SECONDARY",     "linkDevices": [     {         "deviceUuid": "d186dc1a-29e7-4829-bb5e-50fa57aca923",         "asn": 65414,         "interfaceId": 6     },     {         "deviceUuid": "ea128600-1875-4f7a-80e9-307a5bbeac51",         "asn": 100,         "interfaceId": 6     }     ],     "metroLinks": []      }' ``` For a complete list of parameters and options, see the [API Reference](https://docs.equinix.com/api-catalog/network-edgev1/device-link-groups-and-connections/createdevicelinkgroup.md). ## Sample Response[​](#sample-response "Direct link to Sample Response") ``` {     "uuid": "85ebe7b7-6182-45a1-be51-cb194f2f1e39" } ``` Response payload: | Field | Type | Example Values | Description | | ----- | ------ | ------------------------------------ | --------------------------------------- | | uuid | string | b43ba509-a7d9-4334-8dee-dc4f29bf2e77 | The unique ID of the device link group. | ## Device Status[​](#device-status "Direct link to Device Status") When a device link group is created, it transitions through various states that can be monitored using the `status` response attribute of the [Get Device Link](https://docs.equinix.com/api-catalog/network-edgev1/device-link-groups-and-connections/getdevicelinkgroups.md) method. Your link group must be provisioned before you can begin to perform other operations like adding or removing devices. | Status | Description | | ---------------- | ---------------------------------------------- | | `PROVISIONING` | The device link group is booting. | | `FAILED` | Link creation failed. | | `PROVISIONED` | The device link group is ready. | | `DEPROVISIONING` | The device link group is being de-provisioned. | | `DEPROVISIONED` | The device link group is de-provisioned. | ![](data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAoYAAAH+CAMAAAA2zT96AAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAC6UExURQAAAAAAAAAAAP8AAAAAAAAAAAAAAAAAAP8AAAAAAAAAAP8AAAAAAAAAAP8AAAAAAAAAAP8AAAAAAAAAAP8AAAAAAP8AAAAAAAAAAP8AAAAAAAAAAP8AAAAAAAAAAP8AAAAAAP8AAAAAAAAAAP8AAAAAAAAAAP8AAAAAAAAAAP8AAAAAAAAAAP8AAAAAAAAAAAAhDwAsFABNIwBYKABuMgCaRgClSwCwUEAAAFAAAL8AAM8AAN8AAP8AANh3dpAAAAAvdFJOUwAQEx0gIi8wMjxAREpQU1hgYmdwcHZ+gIWMj5aZn6ior7e4v8TLz9Tc3+Lu7/H3HyDdFwAAAAlwSFlzAAAXEQAAFxEByibzPwAAGRRJREFUeF7tnQub0zabQM3QUEKhAUqAkq8DDbfAwHp3u/t1b/P//9a+N9nOkCvzJH5tznmYkSzLshKdvJKdDKkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB64eP19evIdrn/9fr6WeQBTs319fW7yHb5Vcp/jzzAqUFD6Itn766vv/4pk65MycZnKXzyWrc+/uNuVd31Upuvn/neqvoc0/Svf8qE/e65VAO4Ba9Dsl80FjpV9Y/IXX+9b7HQkED5uyR2lKQaH0VL47kVAnwnT0Kk61+70VACZPB6LRre0LDZxZQNt0LE+ny/uvvs8y+yIUL52vDPj89l+76I+VW22rXhDQ11x6+i8juiIdwK1zBoNAzCun0aAtwSXd19fR0uST40vP/8nVx7KLKxVcP7WkGvbgBuh68IP5uIknENn4WDgmxt1TAuZb4yJ8Nt+d2VUw8lMQ3vthbu1rB68lnrxF6AW/BEL4z/lIwkpqHO1K9lxbhvbaj8ond89EIG4Jb86XpJaDMNi22R6hKw1fCJpOppEwGfywYXKnAbXr97ctfuzOi7I/p+yv3qFxPreXVXpTMdJXl3966ER73L+PH+Xd2vGj77/Ox+dVfDYXOxDfAdNDeqNbjFOyp+BRxoJV8ASqDsLhrlAPNU8QsbgO+kvJf3Ud8W/sXzzZt5Kp1WsuhnrsW7dx+lgkZD37r+qve+Ab6bu//QePgu7v39KhufNS4+02n6tQQ/v/h4LpsfdVFYPdHcMxVQ79LY3cWPv/PJBgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABgCdx68ePvpy798evPqQZQAnJk7Lz7VLa+iFOCcPOhKKHx5HDsAzsarsK8DARHOzB+h3hpvYyfAWdgQC5U3sRvgDDwK7b7hUVQAODl3PoR13/DlTlQBODUvQroNvIgqAKfmxq2aLl+iCsCJ2boyVLh7COdhx5xc139EJYDT8iaM28iHqARwWnYsDVkcwrn4EsZtJioBnBY0hATs1PBTVAI4LW/DuI1wiQLnYcvnGhw+7QXnYeftaz7cAGdi15t5fLYBzgQfbYAE3NkaDgmGcD62rg5/iwoAZ2Djn6JwmQxnZuO9wzdMyXBeNv2BKBbCuXl84z29L6wLoQ9+CwGVLy9+ilKAM/Pola4Rv3x49Zj5GPqFj3ZBAtAQEoCGkAA0hASgISQADSEBaAgJQENIABpCAtAQEoCGkAA0hASgISQADSEBaAgJQENIABpCAtAQeqX7n4jwv4ZAT9wJBQX+1xDojTYcEgyhN5pwSDCEHinhkGAIPRLhkGAIveLhkGAIvWLhkGAIPaPhkGAIPSPhkGAIvfOCYAj9c4dgCAngPzaEA/l7oET3YRzEqA6O6D6MgxjVwRHdh3EQozo4ovswDoY4pGg4OtAQEoCGkAA0hASgISQADSEBaAgJQENIABpCAtAQEoCGkAA0hASgISQADSEBaAgJOGJIF/oH8HPJaFpPrUxzy6qa1DPbXC71X1WtpFj3am3bWGlmadtad6qHexuzemKFilY6ADQcHUcMqQo2FZPMubnaMzOvVqLPSuUTs2ZWS7dmC9dwWktGDJTq4qNki4Zinh5kGs5N45k3shc0HB1HalgtVq6hKWYWSrIQjzSjSkmtEhtt/0otdDNXCy1oNVxoONRjpuWAw0DD0XGshvOOhj6fdtRcSA2tZQFQkDo2/Qrq6WqhMbTVcLaUuVob0eOOAA1Hx7EalmC3EK08BHpqO3WHZmQVaTs6qmoqgVEE7WioUdB2eFQ9FDQcHUdqOBNx7HJCrZPIaMxCSU3dx6lfb5iGWkNLTEMJhx0NKwmHqqHO1fNo9ADQcHQco6HqJ1OseySBrxsNtdDmVtNQtRNHv42G8tPVUH6KhsKhczMajo5jNAxL1B9dDzaKaV73anlTS00TvTRRVFXVUMJpR0OZvrWROAYNf1i+V0MXyaOYJeqXbtzQsFyueCTUzLKr4aTWWzkzdxUNf1i+V0O7A+O3+/zedFW7cFLL7v/pftWwvbfoGsqysaOhLgklpEpQlHw5wT7QcHR8t4Z2/1ovRSIkytJRi62Wvt+ilW2XXdGYoaah1Jt2NBR79bc1FFc8e0HD0THEIUXD0YGGkAA0hASgISQADSEBaAgJQENIABpCAtAQEoCGkAA0hASgISQADSEBaAgJQENIgA7pEInuwziIUR0c0X0YBzGqJ+Hf/yMyJyC6D+MgRvUk1P8WmRMQ3QfYR/02MgD9gYaQADSEBKAhJAANIQFoCAlAQ0gAGkIC0BASgIaQADSEBKAhJAANIQFoCAlAQ0gAGkIC0BASgIaQADSEBKAhJAANIQFoCAlAQ0gAGkIC0BASgIaQADSEBKAhJAANYTf6LdojAdeHi32l+yh4gIbDBQ0hAWgICUBDSAAaQgLQEBKAhpAANIQEoCEkAA0hAWgICUBDSAAaQgLQEBKAhpAANIQEoCEkAA2hV17EZ+eVF1E2UN7Ew1AeRBkMgzufYuDq+sudKBsoP8fjEAiJQ6MNhwMPht1wSDAcGk04HHow7IRDguHwKOFw8MGwDYcEw+ER4XD4wbAJhwTDIeLhcATBsIRDguEQsXA4hmAY4ZBgOEw0HI4iGHo4JBgOEwmH4wiGFg4Jhifl79PxV/1X5E5AdL/L9en47/p/IncCovs/NDGqp+Cf//rPyJ2A6H6XGNVT8L//FZlTEN3/oYlRPQn/GekpiO53iVE9Cf8X6SmI7v/QxKgOjuh+lxjVwRHd/6HZMqSp2aFhZAcDGjpo2Cto6KBhr6Chg4a9goYOGvYKGjpo2Cto6KBhr6Chg4a9goYOGvYKGjpo2Cto6KBhr6Chg4a9goYOGvYKGjpo2Cto6KBhr6Chc5yGK/0btWlVTTX1/7DLsvOqmtUT25a8buqXKa90r9SuJlpnYXttW+vOtExqelMz3XkoJ9Vwqd2RnuuD1b5Wy2VVLayg6bOntveWoKFznIYq2Fyef3NuqWOz0NGY1Ev5UfnEqonVUuvmKpnsnptlOrbiowyqHT6P/3bOmppa8aGcVMOVvVwE6ZNlOxqWPls68xfW7UBD53gNdaDCnalrptmZDZcPmNSKcksnHuvU00lt2n6joTVwMOfRcLGYm3zbNJSe+2O8DWjofIeGEiQaDWN8GjWrlUZC9c1io9UpgyfjKUZqDP1Ww5D4MM6jYT2bmGdbNWyrfj9o6HyHhvLL3FnJ+BR7NNWdOidbZunrq66qkoqGGvc2aFgqHcJZNJxK/yy/XcNjXjpbQEPneA0X4o2t0VVJXz5JYSipqcsqVWTsTMMYLZnjdH6WcOgaClIjNPQJ8DBOq6H2Sx6V9tp0W9PQ+xwalgd2C9DQOVJDRVL3SPwpAUFTLdQ52TXU7eWGaKg/friXhobpoqEuVm3FuqahJSUtD/4WoKFzpIYumLujA1bsscGr5zYnd2t9uzaUY+oNGpawegjn0NDvyegF/HYN7TV3O9DQuYWGOhhxtai2yWAtfZq6oWFcBUcktNs732joDRzIOTT0SKed3KphvIBuBRo6t9DQrobVKJHIxm4at6GlfG7RceF6NfcWXUMZxZsaRgMHcgYNvaOWbNNwVp6M24CGzi009PvXtmyPUKZ6aWJ62kLfo5zNcDquMbq6vvRZT0VVjoiFZ9GwRLrV0jS0B1k3ffbUa9wONHSO0zAHJ9XwvKChg4a9goYOGvYKGjpo2Cto6KBhr6Chg4a9goYOGvYKGjpo2Cto6KBhr6Chg4a9goYOGvYKGjpo2Cto6KBhr6Chg4a9goYOGvYKGjo6pEMkut9Fh3SIRPd/aGJUB0d0v0uM6uCI7v/QxKiehBN+jy0ajosY1ZNQR3oKovtdYlQHR3QfTkT8ARFAn6AhJAANIQFoCAlAQ0gAGkIC0BASgIaQADSEBKAhJAANIQFoCAlAQ0gAGkIC0BASgIaQADSEBKAhJAANIQFoCAlAQ0gAGkIC0BASgIaQADSEBNRvz8DPcTKAzTw4Ax8exMkA+uMtGkL/oCEkAA0hAWgICUBDSAAaQgI2a3hZK+9fTtqN+qqqnta1lbRFS88I0+rKM5dWo7pnG1eXs3ajrp9K5qXtltoLaWal2cnLlZxsfqHtG/esRvd0Uu+etG+NXcqRse9ipXu0qWomJ7PjrrzWxfy9tPR+EW3JEbL9fl5N/RTC0kolo1W6xeW80qTsutDeLR9qgRBdlGOj88rsUvr2fqEHxeOXavNINYE9bNaw2HWlIxobouFcbevsX9cwMqFhM67Li3bjqUgi7QgP1Sk5WmuGv3Nt3wh1uqfzNq6kLdkSCXyfvBykh2aFHmtiuQCzaNTLhIVvTm9oKIrZC6NbXM5r6YXaLGiBlylyrHdeuChPwpW4uvLHJx17r+mydRV2sFVDCVJPZShlPJrnuxmfTpENoL3w3YYGL55KTSlt6qgNFlgkvYjTyFmeSrC7NA29fWf9dNLGUivKlrRo+yTWqEJ2inn9/sr89fPqS0j9X0SfJAxfXlQPl9Zg230tjhdGW1zOW84xry5mxaa2i00jL6WNiURfe5XIhnZCXwT6kmmCP+xkh4Y2mBLb2kFrxqAt6ii2SUOreq+to+NuA3PVtCxCqlxKO8bG+umkjZnFlkZDmabtjKHhcqGTs2soQSlCaiDRt8yr3e6/rC/bPaW4nNdS8Up9KrRdLLUnEfj8gUhr+prS4CitSp/bs8J2dmpYyYTUHbR1L4I9Gsq42IIsNBRBVCV1Kpop07TQjrGxfjo5RA62o1zDh+99km40FCFkeaanapegBTn6fdN2231t0JaWSiku57VUfkmsa2j61NSWcOkvIznpsrqwV+7TWp456YHU7jqsqKBd3kS58SEKC1IUuYad9T9FufFHFDZEufEiyhq6ny14FGUNj2OH8lOUNbyIHUaUNRzYXdFwQ3c7A3JPNxR59psxaIvWNDQsv1Z8qRuKauqz1ktzT08j7jT2SvtKMbZ7OmvwnoXDoqGMtEe80PBK4pEIpceLGiFLgy7x3tvFS/vw9DUykaPc5qa4nNdSXTPUl01rTZ+a2hIEo8T6sdRHdlm/vNQYedk+toI9wg5oqOzVcKobijzXzRi0RYdouOxq6IFqZRFITyO7mqGS9pWtGk7luIeyZdbV4seahqb0hWyVRab1Mq6Yqgu7un9vwll7ykJdERddz1JczuvpPbtGiYCpZYp0sdSW1HvZ9GMiAfahvBI0LY+l4bcbPIpy43EUFqQocg0763d1qR5EYUOUGz9HWcOd2KH8FGUNXUfvRFnD2nwaZQ0Hdlc03NDd8hRL6Jq0g9aMT6fohm8tpVhmqUVbR9BZWVzUNZM2Y1NZ0LTvrJ/ONJxJ5aKhDLQvyhoNRav5TQ3bPt2TuOWbpfsXVzqf+jwqlOJy3pI+1Iai/1KmyFapLXpHp611eTwz+bmIdH2FKsTn6xrWYskfUViQosg17Kz/R5QbL6KwIcqNx1HW8FPsUB5EWUPXtJ+irGHN/ShrOLC7coYN3S1Psay+2o12XDpFezW0NXtXQ52VfU72ZiSsWbnQtO+sn840FInvNZco8mMrwFbDibSlp5K6vjZc79Nk5f0u3Z+5U4Kt/kpxOW9zfm0v2mnLOrU9mEoljZmy1JSlYaTNQ4OdrIneEE+xP7Hl+e6MQVvU+rZFQ6k6aesIEiJe+pzszfi9P6MdY2P9dNKGbM3qRaPhhVilFVoNJRyKWnIque4xs9b7VPpdum/ztGEXGaVYwqz1SKJnuTjZoaG8znxfPJDLeiVLw0jLkgB2s0NDu28o41Ce75teBDs11PuGYlxXQw2xMVlZM7JP75LfW+y/b6hbK7k0ceumWrSSxV5Hw4leuMipxCS9b9he/8wv9f5J3OGJ7stsbDFTUpvdy6OSo64eVhfShtRevpSuSjb633ax1NaLn8WkmkiUt1b01LrksLS8wGA3WzU0uu+iyJMuY6Bcdoo6ikVZjLsUO913UayijE+8t+AjqdtK+y5KDHT3dI2GOpG6dbIlQy8ilQI9Rtd/epbSVOlObPvdRD+vntiXbhLHNBPF7WStteOh+rVNOa8SO57au4yG1xGJ7TaNpZ1bPbCDzRr6bLVce09ZhiiEuewU2dPt981iNGLcZe4VVuvvKZuGegvExY23Zaf2lmznPeUY6M7ppJ60Yd2R4ZfzybJLti5s8Wo3/p56W7r8M7cmC73CtVimXLyUzZW97auu2pqteVdYtNOHEMWC9+ilanVvIS1q5xzpU6gVz4Fe49jb18unUUc2LCxKGs8F7GOzhgBnBQ0hAWgICUBDSAAaQgLQEBKAhpAANIQEoCEkAA0hAWgICUBDSAAaQgLQEBKAhpAANIReefRB+fJJf6/9NSnAGfnkHx9W1v7GD+CMPA4H6/pT92+lAc5KEw4JhtAfJRwSDKFPIhwSDKFPPBwSDKFfLBwSDKFfNBwSDKFvJBwSDOEg/h4o0X0YBzGqgyO6D+MgRnVwRPdhHMSoDo7oPoyDIQ4pGo4ONIQEoCEkAA0hAWgICUBDSAAaQgLQEBKAhpAANIQEoCEkAA0hAWgICUBDSAAaQgL2Dql/T6x+V6d9e6p+caWlk/gCV/8iS8tONbXNST2Tf37wQr9FU78Z01rSr/eUjFZarPxn5l+2ubSWrCH7Xu7toOHo2DukptBUbZvGl8CaYAspVocqc2alXs3Esal/2fSstlq2tZx6Gws9fKIN+Ze0NxqKeXqQaWgNVUtrZCtoODoO09CEWtOwEpNMQ41/EQPnUnVlkUyU0lpRbm3E0drQrF7ojlZDa0g1tPK9oOHoOFBDlWRdw1VHQ3evY55kdGMWR2gbVlmQurKpMbTVcKLRUTW0lveChqPjUA3FlzUN9Zc6ZAbZHCtIajtlTvZMLPO0DZtzBUllUwNnq6FFQRPdzrUPNBwdh2o4Vw2ViQu2FHEWuq1qaoEiEdIi41J+rJZWkbxpaEJKiWmoS8qOhiqz+ykNSKPR3hbQcHQcqqH40kZDQfQxh5aa6URDm5VVI9dQRZy7hmvRUH86GupP0VBAwx+NQzWUYLa+NhTUIdvorA31l87Ja7W0Da2s+NpQ0mVXQ4mOomE5phy6BTQcHQdqqApu1NCiXFzgmk8irM2/NzWMyxVtxJqc1RpIGw3ntTZksRUNfzwO03CqK7zNGppeNkfPvXzm60Wtpff//A6NtLFsGnKzl3pQo6EsCXXWthvbzQm2gIajY++Q+oWJi6Wsbmjo96+Xuku3rJonUktLJXHvyjstsWm3xFsNZ9aOX/bEUnMbaDg6hjikaDg60BASgIaQADSEBKAhJAANIQFoCAlAQ0gAGkIC0BASgIaQADSEBKAhJAANIQFoCAnQIR0i0X0YBzGqgyO6D+MgRvUk/BXpKYjuwziIUT0JdaSnILoPsI/44xSAPkFDSAAaQgLQEBKAhpAANIQEoCEkAA0hAWgICUBDSAAaQgLQEBKAhpAANIQEoCEkAA0hAWgICUBDSAAaQgLQEBKAhpAANIQEoCEkAA0hAWgICUBDSAAaQgLQEBKAhpAANIQEoCEkAA0hAWgICUBDSAAaQgLQEBKAhpAANIReefRCqe33oygDODM/1y0Pogzg3HwIB+v6bZQAnJ02HBIMoT9KOCQYQo+UcEgwhD7xcEgwhF7xcEgwhH7RcEgwhJ7RcEgwhL75QDCE/vmZYAgJeBUpwB7+HijRfRgHMaqDI7oP4yBGdXBE92EcxKgOjug+jIMhDikajg40hASgISQADSEBaAgJQENIABpCAtAQEoCGkAA0hASgISQADSEBaAgJQENIABpCAg4aUvvL94XmVpatqqUms6qa2PZEd1lWKk3rqW5Wq4X+s4NXuldqe0tL22vbWneqZXKgNzXXnXtAw9FxyJC6QmpfVTRRwWZSbM4tdM/cK4lxLuxE9mgt3ZrPvY2ZHb6yhrSmHT5zi72piRXvAQ1Hx+EamlBdDavlsrgzK3UmUmFhJs1FNqllFWyH7I+jraGFFnyjoTWwDzQcHUdoqGKtabjoaKg7laJmtZQaUqtopXWKcOppPdcY+q2GIfFO0HB0HKGh+rKmYQl2SzGn2KOp7tQ52TJLn2a7qrrPKugGDUulHaDh6DhCw6lqqMiWCjYXb+z6QpWUyGjMQ0lNXdZZc4liZVZiYVXCoWuoNBrqzj2g4eg4QsO1aKjqSBRzj8SfbjTUQp2TXUM9cLkhGuqPH040/OE5QkMNZmuTsmDuyHqwsUfzstfm5KaWmKZtFOFUVW1ILq6/1bCE1R2g4eg4QkMPYFayrqGKNPU6XnW+8vn3hoblcqVpqF5+o2GcaydoODoO19AuNTZqaHdgFpqb+L3pSdyGllpzrSj7rY323qI3JMvCGxpGA7tBw9Fx0JDaRYSLZdnJDQ3t/rVdakQoW1mx1dL3WyRxle2KxhoqzWkcVXT1qEQDO0HD0THEIUXD0YGGkAA0hASgISQADSEBaAgJQENIABpCAtAQEoCGkAA0hASgISQADSEBaAgJQENIgA7pEInuwziIUR0c0X0YBzGqgyO6D+MgRnVwRPfhu6mq/wf08Eua9hfqlwAAAABJRU5ErkJggg==) You can update a link group using [Update Device Link](https://docs.equinix.com/api-catalog/network-edgev1/device-link-groups-and-connections/updatedevicelinkgroupbyuuid.md). If you delete a device link group using the [Delete Device Link](https://docs.equinix.com/api-catalog/network-edgev1/device-link-groups-and-connections/deletedevicelinkgroupbyuuid.md) method, the group transitions through the following states: | Status | Description | | ---------------- | ---------------------------------------------------------------------- | | `DEPROVISIONING` | Equinix accepted the customer's request to delete a device link group. | | `DEPROVISIONED` | The device link is deleted. |
