# Launch Cluster Device ![](https://docs.equinix.com/assets/images/LaunchClusterDevice-8cbbed9f9cbc2854ae5a7b777f1f7935.png) ## Prerequisites[​](#prerequisites "Direct link to Prerequisites") 1. Authenticate - Submit your user credentials, Client ID, and Client Secret for OAuth2 authentication. Refer to [API Authentication](https://docs.equinix.com/equinix-api/api-authentication.md) for instructions on how to call the OAuth API to validate and authenticate your credentials. 2. Call [Get Device Types](https://docs.equinix.com/api-catalog/network-edgev1/availability-and-metros/getvirtualdevicetypes.md) to find out which cluster device (e.g., router or firewall) you want to launch on the NE platform. You will learn about the metro regions where virtual device are available, vendors of devices, the available number of cores, and the software packages and their versions. Select `deviceTypeCode`, `metroCode`, `core`, `packageCode`, and `version`. 3. Call [Get Allowed Interfaces](https://docs.equinix.com/api-catalog/network-edgev1/availability-and-metros/getallowedinterfaces.md) to find out the allowed number of interfaces for your selected core. You may select any available device interface as sshInterfaceId. Otherwise, Equinix will choose the first available interface. 4. Call [Get Accounts {metro}](https://docs.equinix.com/api-catalog/network-edgev1/availability-and-metros/getaccountswithstatus.md) to check your `account number` (or `acountReferenceId`) and status in the metro where you want a virtual device. For billing reasons, you must have an account in the metro where you want a virtual device, either in the Active or Pending state. Create an [account](https://docs.equinix.com/network-edge/billing/ne-billing-account-creation.md) if you do not have one. If you are a **reseller** trying to create a device for your customer, you must ensure that the customer's and your (reseller's) accounts are both in the Active or Pending status. Your account will get billed, however, you must send the customer's account number to the POST API to create a device for your customer. ## Licensing Options[​](#licensing-options "Direct link to Licensing Options") As of now, we only offer the BYOL (bring your own licensing) option for clusters. * **Juniper Cluster** - It is not necessary to upload license files for a Juniper Cluster. However, you may upload two license files. To upload two license files, call [Post License File](https://docs.equinix.com/api-catalog/network-edgev1/availability-and-metros/uploadlicense.md) twice. You will get license file IDs in the response that you can use to create a cluster. * **Palo Alto Cluster** - You must upload two license tokens from the vendor. The license tokens can be the same or different. * **Fortinet Cluster** - You don't need to enter a token or license. If you want to upload license files, you must upload two different license files. To upload two license files, call [Post License File](https://docs.equinix.com/api-catalog/network-edgev1/availability-and-metros/uploadlicense.md) twice. You will get license file IDs in the response that you can use to create a cluster. * **Arista VeloCloud SD-WAN Edge Cluster** You do not need to upload a license file or token. However, you must provide your activation key. If your license fails to register after your device is created, you must log in to the device and upload the license. Then, call [Update Virtual Device](https://docs.equinix.com/api-catalog/network-edgev1/virtual-device/updatevirtualdevicebyuuid.md) with the status value `PROVISIONED`. ## Create Cluster Device[​](#create-cluster-device "Direct link to Create Cluster Device") | | POST /ne/v1/devices | | ---------------- | ------------------------------------- | | Method | `POST` | | URL or End Point | `/ne/v1/devices` | | Headers | `Authorization` token, `Content-Type` | | Query Parameters | `draft`, `draftUuid` | Note: By creating a virtual device, you accept the Order Terms. Call [Get Order Terms](https://docs.equinix.com/api-catalog/network-edgev1/availability-and-metros/getorderterms.md) to review the details. To save a device draft, you must provide a `deviceTypeCode`, an `accountNumber` or `accountReferenceId`, and a `metroCode`. A sample curl request to create a vSRX cluster: ``` curl -X POST "https://api.equinix.com/ne/v1/devices?draft=false" -H "content-type: application/json" -H "Authorization: Bearer " -d ' {     "deviceTypeCode": "VSRX",     "clusterDetails": {         "clusterName": "sroy-juniper",         "clusterNodeDetails": {             "node0": {                 "vendorConfig": {                     "hostname": "sr012"                 },                 "licenseFileId": "1274fe9f-511c-436f-bc0c-14c876ec55da"             },             "node1": {                 "vendorConfig": {                     "hostname": "sr123"                 },                 "licenseFileId": "65a9be3f-57fb-4c4d-a15b-40950951bc13"             }         }     },     "metroCode": "SV",     "termLength": "1",     "licenseMode": "BYOL",     "packageCode": "STD",     "virtualDeviceName": "Test-device-001-SROY",     "notifications": [         "test@equinix.com"     ],     "hostname": "sr012",     "aclDetails": [        {          "uuid": "fb2e69bb-cbd7-40c4-bc01-8bcc5fa741c2",          "interfaceType": "WAN"        }     ],     "accountNumber": "201148",     "version": "18.4R3-S2",     "interfaceCount": 8,     "agreeOrderTerms": true,     "deviceManagementType": "SELF-CONFIGURED",     "core": 5,     "userPublicKey": {         "username": "sroy",         "keyName": "keyLlhzL"     },     "additionalBandwidth": "100" } ' ``` A sample curl request to create an Arista Velocloud SDWAN cluster: ``` curl -X POST "https://api.equinix.com/ne/v1/devices?draft=false" -H "content-type: application/json" -H "Authorization: Bearer " -d ' {     "metroCode": "SY",     "deviceTypeCode": "VELOCLOUD-SDWAN",     "termLength": "1",     "clusterDetails": {         "clusterName": "sroy-velo-cluster",         "vendorConfig": {             "node0": {                 "activationKey": "GJUK-JM2X-59BJ-SAMPLE",                 "controllerFqdn": "demo.velocloud.net",                 "rootPassword": "TestPassword!"             },             "node1": {                 "rootPassword": "TestPassword#"             }         }     },     "licenseMode": "BYOL",     "packageCode": "VeloCloud-4",     "virtualDeviceName": "velo-cluster",     "notifications": [         "test@equinix.com"     ],     "aclDetails": [        {          "uuid": "fb2e69bb-cbd7-40c4-bc01-8bcc5fa741c2",          "interfaceType": "WAN"        }     ],     "accountNumber": "2393479",     "version": "3.4.2",     "interfaceCount": 8,     "deviceManagementType": "SELF-CONFIGURED",     "agreeOrderTerms": true,     "core": 4,     "userPublicKey": {         "username": "sroy",         "keyName": "key7YFfL"     },     "additionalBandwidth": "200" } ' ``` A sample curl request to create a PANW cluster with no internet access: ``` curl -X POST "https://api.equinix.com/ne/v1/devices?draft=false" -H "content-type: application/json" -H "Authorization: Bearer " -d ' {     "deviceTypeCode": "PA-VM",     "clusterDetails": {         "clusterName": "NEAut-",         "clusterNodeDetails": {             "node0": {             "vendorConfig": {                 "hostname": "PANCluster"             }             },             "node1": {             "vendorConfig": {                 "hostname": "PANCluster"             }             }         }     },     "metroCode": "#(supportedMetro)",     "zoneCode": "Zone1",     "termLength": "1",     "licenseMode": "BYOL",     "packageCode": "VM100",     "virtualDeviceName": "NEAut-",     "notifications": [         "t@t.com"     ],     "version": "10.1.3",     "interfaceCount": 10,     "deviceManagementType": "SELF-CONFIGURED",     "core": 2,     "connectivity": "PRIVATE" } ' ``` For a complete list of parameters and options, see the [API Reference](https://docs.equinix.com/api-catalog/network-edgev1/virtual-device/createvirtualdevice.md). ## Sample Response[​](#sample-response "Direct link to Sample Response") Sample response 202: Request accepted. ``` {     "uuid": "34b7838c-ec82-4166-ac19-efa03b4e34fe",     "deviceIds": {         "node0": "34b7838c-ec82-4166-ac19-efa03b4e34fe",         "node1": "f27f1475-3c7f-447f-b0db-e3bb3af3de16"     },     "clusterId": "27eea9aa-327b-431b-bf62-3cee4d880f2e" } ``` ## Device Status[​](#device-status "Direct link to Device Status") When a cluster is created, the self-configured cluster transitions through various states within the Equinix infrastructure. These states can be monitored using the `status` response attribute of the [Get Virtual Device {uuid}](https://docs.equinix.com/api-catalog/network-edgev1/virtual-device/getvirtualdevicebyuuid.md) method. Your cluster must be provisioned and your license must be registered before you can use this cluster to connect to cloud service providers. | **Virtual device states** | **Description** | | ------------------------- | ---------------------------------------------------------------------------------------------------------------------------------------------- | | `INITIALIZING` | Equinix is in the process of reserving resources and creating the device. | | `PENDING_ACCOUNT` | Customer's account is not approved. The device creation will continue once the account gets approved. | | `PROVISIONING` | The device is booting. | | `PENDING_ORDER` | This status only applies to orders coming to NE from Siebel. Customers need to log in to the Network Edge portal and submit the pending order. | | `PENDING_SIGNATURE` | The customer has not yet accepted Network Edge terms. | | `CANCEL_ORDER` | The order from Siebel to NE is canceled. This status only applies to orders coming to Network Edge from Siebel. | | `WAITING_FOR_PRIMARY` | The secondary device is ready but the primary is not. This state may appear if you have requested a redundant device. | | `WAITING_FOR_SECONDARY` | The primary device is ready but the secondary is not. This state may appear if you have requested a redundant device. | | `FAILED` | The device creation failed. | | `PROVISIONED` | The device is ready. | | `DEPROVISIONING` | Equinix accepted the customer's request to delete the virtual device. | | `DEPROVISIONED` | The device is de-provisioned/deleted. | ![](https://docs.equinix.com/assets/images/LaunchClusterDeviceStatus-c01747a2fac38f81e3e43d32810dbc59.png) When an end-user deletes a device using the [Delete Virtual Devices](https://docs.equinix.com/api-catalog/network-edgev1/virtual-device/deletevirtualdevicebyuuid.md) API, the device transitions through the following states within the Equinix infrastructure. | status | Description | | ---------------- | --------------------------------------------------------------------- | | `DEPROVISIONING` | Equinix accepted the customer's request to delete the virtual device. | | `DEPROVISIONED` | The device is de-provisioned/deleted. |
