Connect Network Edge Device Using Service Token
Establish a connection between your Network Edge Device and a network resource on Fabric using the Fabric API using a Service Token.
Fabric API Prerequisites​
  1. Authenticate - Submit your user credentials, Client ID, and Client Secret for OAuth2 authentication. Refer to API Authentication for instructions on how to call OAuth API to validate and authenticate your credentials.
  2. Retrieve your Network Edge devices information using the Get Virtual Devices or Get Virtual Device {uuid}. In case of a redundant device, choose the unique ID of the primary or the secondary device. Similarly, for a cluster device, choose the unique Id of node0 or node1. There will be just one connection even if your device is redundant/cluster.
  3. Call the Get All Service Tokens endpoint to get available service tokens along with the allowed connection settings.
Connecting Using a Service Token​
To create a connection between your Network Edge virtual device and another network location on Fabric using a Service Token, send a POST request to the /fabric/v4/connections endpoint. Specify which virtual device, service token, and connection configuration in the body of the request. The details of the network location are provided by the service token.
A service token can be dispatched to a number of recipients, and it's valid for a single use by any of them.
POST /fabric/v4/connections
MethodPOST
Path ParametersNot applicable
Body Parameterstype, name, order, redundancy, bandwidth, aSide, zSide, notifications
In this example the a-side is the Network Edge device, and the Service Token is for the z-side destination.
Sample cURL Request:
curl -X
    "type": "EVPL_VC",
    "name": "Conn-1",
    "order": {
    "bandwidth": 1000,
    "aSide": {
        "accessPoint": {
            "type": "VD",
            "virtualDevice": {
                "type": "EDGE",
            "interface": {
                "type": "NETWORK",
                "id": 5
    "zSide": {
        "serviceToken": {
    "notifications": [
            "type": "ALL",
            "emails": [
                "test@equinix.com",
                "test2@equinix.com"
The parameters included in the request body are specific to this example. For a full list of parameters and their descriptions, see the API Reference.
Sample Response:
    "type": "EVPL_VC",
    "href": "https://api.equinix.com/fabric/v4/connections/ebc37e2e-c36b-4e93-86a4-fc4efce7abc8",
    "uuid": "ebc37e2e-c36b-4e93-86a4-fc4efce7abc8",
    "name": "Test ST",
    "state": "ACTIVE",
    "operation": {
        "providerStatus": "AVAILABLE",
        "equinixStatus": "PROVISIONED"
    "notifications": [
            "type": "ALL",
            "emails": [
                "testNEuser2@equinix.com"
    "account": {
        "accountNumber": 270235,
        "orgId": 92794,
        "globalOrgId": "0016u000003JZ55AAG"
    "changeLog": {
        "createdBy": "testNEuser2",
        "createdDateTime": "2022-10-05T19:37:12.748Z",
        "updatedBy": "testNEuser2",
        "updatedDateTime": "2022-10-05T19:37:12.748Z"
    "bandwidth": 50,
    "redundancy": {
        "group": "b64dad2a-2763-4084-bc50-b36ef4f67137",
        "priority": "PRIMARY"
    "isRemote": true,
    "direction": "INTERNAL",
    "aSide": {
        "accessPoint": {
            "interface": {
                "uuid": "11fd6067-149f-4142-a5b4-54a8dd6f53fe",
                "id": 6,
                "type": "CLOUD"
            "type": "VD",
            "account": {
                "accountNumber": 270217,
                "organizationName": "eqx-nfv"
            "location": {
                "region": "AMER",
                "metroName": "Ashburn",
                "metroCode": "DC"
            "virtualDevice": {
                "href": "https://api.equinix.com/ne/v1/devices/3539f96c-7f67-4696-90f3-7b6d2fdcde5f",
                "uuid": "3539f96c-7f67-4696-90f3-7b6d2fdcde5f",
                "name": "testing1234",
                "type": "EDGE"
    "zSide": {
        "serviceToken": {
            "uuid": "e05f4f23-d098-4d7c-a9ca-c2897b465107",
            "account": {
                "orgId": 92794
        "accessPoint": {
            "type": "COLO",
            "account": {
                "organizationName": "testNEuser2-270235"
            "location": {
                "region": "AMER",
                "metroCode": "DC"
            "port": {
                "href": "https://qa3api.corp.equinix.com/fabric/v4/ports/c791f8cb-59d0-9d00-8ce0-306a5c00a4ee",
                "uuid": "c791f8cb-59d0-9d00-8ce0-306a5c00a4ee",
                "name": "testNEuser2-DC6-NL-Dot1q-STD-SEC-10G-JN-216"
            "linkProtocol": {
                "type": "DOT1Q",
                "vlanTag": 553
Response payload includes configuration parameters defined in the request body. For a full list of possible parameters and their descriptions, see the API Reference.
Monitoring Your Connection​
Use the Get Specified Connection API endpoint to monitor connection status.
