# Connect Network Edge Device to Remote Port Establish an untagged connection between your Network Edge virtual device and a remote Fabric Port using the [Fabric API](https://docs.equinix.com/api-catalog/fabricv4.md). ![](https://docs.equinix.com/assets/images/connect-device-to-port-38be28b711622d05580c53afacf60921.png) ## Fabric API Prerequisites[​](#fabric-api-prerequisites "Direct link to Fabric API Prerequisites") 1. Authenticate - Submit your user credentials, Client ID, and Client Secret for OAuth2 authentication. Refer to [API Authentication](https://docs.equinix.com/equinix-api/api-authentication.md) for instructions on how to call OAuth API to validate and authenticate your credentials. 2. Determine Your A-side Information. Retrieve your Network Edge devices information using the [Get Virtual Devices](https://docs.equinix.com/api-catalog/networkedgev1/virtual-device/getvirtualdevices.md) or [Get Virtual Device {uuid}](https://docs.equinix.com/api-catalog/networkedgev1/virtual-device/getvirtualdevicebyuuid.md). You may choose any available interface on the device for your connection. However, Equinix will select an interface if you do not specify one. 3. Retrieve your Equinix Fabric ports information using the [Get All Ports](https://docs.equinix.com/api-catalog/fabricv4/ports/getports.md) API request. ## Connecting to an Untagged Remote Port[​](#connecting-to-an-untagged-remote-port "Direct link to Connecting to an Untagged Remote Port") To create a connection from a Network Edge device to a remote port with untagged traffic, send a `POST` request to the [`/fabric/v4/connections`](https://docs.equinix.com/api-catalog/fabricv4/connections/createconnection.md) endpoint. Specify your connection's configuration details in the body of the request. > **Note** > > You can create only a single untagged connection from a Network Edge virtual device to a remote port. | | **POST /fabric/v4/connections** | | ---------------- | ---------------------------------------------------------------------------------- | | Method | `POST` | | Endpoint | `/fabric/v4/connections` | | Headers | `Authorization`, `Content-Type` | | Path Parameters | Not applicable | | Query Parameters | Not applicable | | Body Parameters | `type`, `name`, `order`, `bandwidth`, `aSide`, `zSide`, `project`, `notifications` | Sample cURL Request: ``` curl -X POST 'https://api.equinix.com/fabric/v4/connections' -H 'content-type: application/json' -H 'authorization: Bearer ' -d '{     "type": "EVPL_VC",     "bandwidth": 100,     "redundancy": {         "priority": "PRIMARY"     },     "name": "ConnectionName-1",     "order": {         "purchaseOrderNumber": "1-3232923"     },     "aSide": {         "accessPoint": {             "type": "VD",             "virtualDevice": {                 "type": "EDGE",                 "uuid": "fd5342f3-d067-4683-a24f-be952279630b"             },             "interface": {                 "type": "NETWORK",                 "id": 45645             }         }     },     "zSide": {         "accessPoint": {             "type": "COLO",             "port": {                 "uuid": "20d32a80-0d61-4333-bc03-707b591ae2f4"             },             "linkProtocol": {                 "type": "UNTAGGED"             }         }     },     "project": {         "projectId": 567     },     "notifications": [         {             "type": "ALL",             "emails": [                 "test@equinix.com",                 "test1@equinix.com"             ]         }     ] }' ``` The parameters included in the request body are specific to this example. For a full list of parameters and their descriptions, see the [API Reference](https://docs.equinix.com/api-catalog/fabricv4/connections/createconnection.md). ## Connecting to a DOT1Q Remote Port[​](#connecting-to-a-dot1q-remote-port "Direct link to Connecting to a DOT1Q Remote Port") To create a connection from a Network Edge device to a DOT1Q remote port, send a `POST` request to the [`/fabric/v4/connections`](https://docs.equinix.com/api-catalog/fabricv4/connections/createconnection.md) endpoint. Specify your connection's configuration details in the body of the request. Sample cURL Request: ``` curl -X POST 'https://api.equinix.com/fabric/v4/connections' -H 'content-type: application/json' -H 'authorization: Bearer ' -d ' {     "type": "EVPL_VC",     "bandwidth": 1000,     "name": "vd to COLO",     "aSide": {     "accessPoint": {         "type": "VD",         "virtualDevice": {         "type": "EDGE",         "uuid": "20d32a80-0d61-4333-bc03-707b591ae2f4"         },         "interface": {         "type": "NETWORK",         "id": 45645         }     }     },     "zSide": {     "accessPoint": {         "type": "COLO",         "port": {         "uuid": "20d32a80-0d61-4333-bc03-707b591ae2f4"         },         "linkProtocol": {         "type": "DOT1Q",         "vlanTag": 300         }     }     },     "order": {     "purchaseOrderNumber": "1-129105284100"     },     "notifications": [     {         "type": "ALL",         "emails": [         "test@equinix.com",         "test1@equinix.com"         ]     }     ] }' ``` Sample Response: ``` {     "type": "EVPL_VC",     "href": "https://api.equinix.com/fabric/v4/connections/c193c1c4-2c7e-472d-8c91-0283bc3b5a71",     "uuid": "c193c1c4-2c7e-472d-8c91-0283bc3b5a71",     "name": "ConnectionName-1",     "state": "PROVISIONING",     "operation": {         "providerStatus": "NOT_AVAILABLE",         "equinixStatus": "PROVISIONING"     },     "order": {         "purchaseOrderNumber": "1-3232923"     },     "project": {         "projectId": 567     },     "notifications": [         {             "type": "ALL",             "emails": [                 "testqq@equinix.com"             ]         }     ],     "account": {         "accountNumber": 270217,         "orgId": 92287,         "globalOrgId": "0016u000003JZ53AAG"     },     "changeLog": {         "createdBy": "eqxnfvuser",         "createdDateTime": "2022-03-22T23:14:23.546Z"     },     "bandwidth": 100,     "redundancy": {         "group": "79a0e626-55fe-4fe1-89a5-4d7ca52214db",         "priority": "PRIMARY"     },     "isRemote": true,     "direction": "INTERNAL",     "aSide": {         "accessPoint": {             "interface": {                 "uuid": "bf8a606b-32b2-4a53-a450-6eabd7d9ccab",                 "id": 45645,                 "type": "CLOUD"             },             "type": "VD",             "account": {                 "accountNumber": 270217,                 "orgId": 92287,                 "organizationName": "eqx-nfv",                 "globalOrgId": "0016u000003JZ53AAG"             },             "location": {                 "href": "https://api.equinix.com/fabric/v4/metros/DC",                 "region": "AMER",                 "metroName": "Ashburn",                 "metroCode": "DC"             },             "virtualDevice": {                 "href": "https://api.equinix.com/ne/v1/devices/fd5342f3-d067-4683-a24f-be952279630b",                 "uuid": "fd5342f3-d067-4683-a24f-be952279630b",                 "name": "ha-json",                 "type": "EDGE"             }         }     },     "zSide": {         "accessPoint": {             "type": "COLO",             "account": {                 "accountNumber": 270224,                 "orgId": 92287,                 "organizationName": "eqx-nfv",                 "globalOrgId": "0016u000003JZ53AAG"             },             "location": {                 "href": "https://api.equinix.com/fabric/v4/metros/SY",                 "region": "APAC",                 "metroName": "Sydney",                 "metroCode": "SY"             },             "port": {                 "href": "https://api.equinix.com/fabric/v4/ports/c791f8cb-5d73-d730-8ce0-306a5c00a4ee",                 "uuid": "c791f8cb-5d73-d730-8ce0-306a5c00a4ee",                 "name": "eqx-nfv-SY1-L-Dot1q-BO-PRI-10G-JN-1147"             },             "linkProtocol": {                 "type": "DOT1Q"             }         }     },     "additionalInfo": [] } ``` Response payload includes configuration parameters defined in the request body. For a full list of possible parameters and their descriptions, see the [API Reference](https://docs.equinix.com/api-catalog/fabricv4/connections/createconnection.md). ## Connecting to a QinQ Remote Port[​](#connecting-to-a-qinq-remote-port "Direct link to Connecting to a QinQ Remote Port") To create a connection from a Network Edge device to a QinQ remote port, send a `POST` request to the [`/fabric/v4/connections`](https://docs.equinix.com/api-catalog/fabricv4/connections/createconnection.md) endpoint. Specify your connection's configuration details in the body of the request. Sample cURL Request: ``` curl -X POST 'https://api.equinix.com/fabric/v4/connections' -H 'content-type: application/json' -H 'authorization: Bearer ' -d ' {     "type": "EVPL_VC",     "bandwidth": 1000,     "name": "vd to COLO",     "aSide": {     "accessPoint": {         "type": "VD",         "virtualDevice": {         "type": "EDGE",         "uuid": "20d32a80-0d61-4333-bc03-707b591ae2f4"         },         "interface": {         "type": "NETWORK",         "id": 45645         }     }     },     "zSide": {     "accessPoint": {         "type": "COLO",         "port": {         "uuid": "20d32a80-0d61-4333-bc03-707b591ae2f4"         },         "linkProtocol": {         "type": "QINQ",         "vlanSTag": 300,         "vlanCTag": 400         }     }     },     "order": {     "purchaseOrderNumber": "1-129105284100"     },     "notifications": [     {         "type": "ALL",         "emails": [         "test@equinix.com",         "test1@equinix.com"         ]     }     ] } ' ``` ## Monitoring Your Connection[​](#monitoring-your-connection "Direct link to Monitoring Your Connection") Use the [Get Specified Connection](https://docs.equinix.com/api-catalog/fabricv4/connections/getconnectionbyuuid.md) API endpoint to monitor connection status.
