# Virtual Device Inventory The *Virtual Device Inventory* page provides a single location for viewing all Network Edge devices in a project. To access your Virtual Device Inventory: 1. Sign in to the [Customer Portal](https://portal.equinix.com) and navigate to *Network Edge*. 2. From the *Network Edge* drop-down menu, select **Virtual Device Inventory**. The devices in the inventory display in a table. ![](https://docs.equinix.com/assets/images/NE-View-Inventory-ec3a8b4ef284a47f194eefe9db97e852.png) Columns include: * Device Status * Device Type * Virtual Device Name * Project * Project ID * Vendor * Model * Location * Last Modified * License Type * Bandwidth * Virtual Device UUID * Service ID * IP Address * Term Length * Account Name * Account Number * Created By * Created Date * Order Number The columns that display in the table can be customized by clicking the settings icon and selecting or deselecting columns. ![](https://docs.equinix.com/assets/images/NE-View-Inventory-settingscogwheel-98f1b6d1e16f39397ff588e271e71574.png) ![](https://docs.equinix.com/assets/images/NE-View-Inventory-settings-9584a7cb1a11532a06c8279d5286288c.png) Select a device to view the details of that device. For more information about virtual device details, see [Virtual Device Details](https://docs.equinix.com/network-edge/manage-devices/ne-device-details.md). ## Search Filters[​](#search-filters "Direct link to Search Filters") Use the search fields and filtering options to narrow your search to specific devices or criteria. ![](https://docs.equinix.com/assets/images/NE-View-Inventory-filters-05223fd5f14790c2da5daa640bc27965.png) ### Search[​](#search "Direct link to Search") The *Search* field is a free-form text field that can be used to match on any of the available fields. A common search pattern is for a device name or part of the name to locate specific devices. ![](https://docs.equinix.com/assets/images/NE-View-Inventory-search-80fc673315ccea792ee537497fcf4080.png) ### Location[​](#location "Direct link to Location") Use the *Location* drop-down to search for devices by location. Only locations in which you have devices will display in the drop-down. ![](https://docs.equinix.com/assets/images/NE-View-Inventory-locdd-a86565f15afb3e861e5e2c09400592e1.png) ### Virtual Device Status[​](#virtual-device-status "Direct link to Virtual Device Status") Use the *Virtual Device Status* drop-down to search for devices that are in a specific state, such as `Provisioned`, `Draft`, or `Initializing`. ![](https://docs.equinix.com/assets/images/NE-View-Inventory-status-2d79a2c09072f826bc15eba0054218fc.png) ### Select Vendor[​](#select-vendor "Direct link to Select Vendor") Use the *Select Vendor* drop-down to search for devices belonging to one or more vendors. ![](https://docs.equinix.com/assets/images/NE-View-Inventory-vendor-f56853f749ad77319295ae0443bc923d.png) ### Order Number[​](#order-number "Direct link to Order Number") Enter the order number of the device to return devices associated with that order number. ### Hide Draft Devices[​](#hide-draft-devices "Direct link to Hide Draft Devices") Exclude devices in `Draft` status from the search results. ## Download Device Details[​](#download-device-details "Direct link to Download Device Details") Click **Download as .csv file** to download a spreadsheet containing all the details for your virtual devices. ![](https://docs.equinix.com/assets/images/NE-View-Inventory-downloadcsv-51aeaa08fd85a3982aac89b2e98cefc1.png)
