Virtual Device Inventory
The Virtual Device Inventory page provides a single location for viewing all Network Edge devices in a project.
To access your Virtual Device Inventory:
  1. Sign in to the Customer Portal and navigate to Network Edge.
  2. From the Network Edge drop-down menu, select Virtual Device Inventory.
The devices in the inventory display in a table.
Columns include:
  • Device Status
  • Device Type
  • Virtual Device Name
  • Project
  • Project ID
  • Vendor
  • Model
  • Location
  • Last Modified
  • License Type
  • Bandwidth
  • Virtual Device UUID
  • Service ID
  • IP Address
  • Term Length
  • Account Name
  • Account Number
  • Created By
  • Created Date
  • Order Number
The columns that display in the table can be customized by clicking the settings icon and selecting or deselecting columns.
Select a device to view the details of that device. For more information about virtual device details, see Virtual Device Details.
Search Filters​
Use the search fields and filtering options to narrow your search to specific devices or criteria.
The Search field is a free-form text field that can be used to match on any of the available fields. A common search pattern is for a device name or part of the name to locate specific devices.
Location​
Use the Location drop-down to search for devices by location. Only locations in which you have devices will display in the drop-down.
Virtual Device Status​
Use the Virtual Device Status drop-down to search for devices that are in a specific state, such as Provisioned, Draft, or Initializing.
Select Vendor​
Use the Select Vendor drop-down to search for devices belonging to one or more vendors.
Order Number​
Enter the order number of the device to return devices associated with that order number.
Hide Draft Devices​
Exclude devices in Draft status from the search results.
Download Device Details​
Click Download as .csv file to download a spreadsheet containing all the details for your virtual devices.
