Traffic Mirroring
The Traffic Mirroring feature clones and encapsulates ingress or egress traffic from a virtual device network interface. The system then routes this mirrored traffic to another virtual device within your Equinix deployment, or delivers it over Equinix Fabric to external destinations like a colocation facility or a connected cloud service provider.
Prerequisites​
  • A mirror device
  • A virtual connection between the mirror device and the mirror target
Create a Mirror Session​
  1. Sign in to the Equinix Customer Portal and go to Network Edge.
  2. From the Network Edge menu, select Traffic Mirroring.
  3. Click Start Traffic Mirroring.
    Start Traffic Mirroring button
  4. In the Traffic Mirroring Session Details section, enter:
    • Session Name
    • Session Description
    • ERSPAN Session ID
  5. Click Select the Mirror Source.
    Select the Mirror Source button
  6. Select a device and click Select Mirroring Source.
    Select Mirroring Source button
  7. Select a Mirror Interface and click Next.
    Select mirror interface
  8. In the Traffic Mirroring Device section, choose whether to mirror an existing device or a newly created device.
    Traffic Mirroring Device selection
    • If you have an existing device to mirror, select Existing Virtual Device, select a device, and then click Select Mirroring Source.
    • If you want to mirror a new device, select Create a New Network Edge Virtual Device, enter a name for the new device, a tunnel source IP address, and a tunnel destination IP address.
  9. Click Next.
  10. In the Configure the Traffic Mirroring section, set the schedule:
    Create mirror schedule
    • Enter Start Date and Start Time.
    • Enter End Date and End Time.
    • Select the Time Zone.
  11. In the Filters section, define the mirror filters by selecting:
    Define mirror filters as None
    • None
    • Select Existing Filter - select an existing filter from the drop-down menu.
    Define mirror filters as Select Existing Filter
    • Add a New Filter - enter a filter name and set the rule parameters.
    Add a new filters
  12. Click Next.
  13. In the Review and Start the Traffic Mirroring section, review your session and click Submit.
    Review Order page
