# Snapshot and Restore This topic describes the Snapshot and Restore function that allows you to take a snapshot of your device image, then restore the VNF by re-provisioning the image with a backup. A maximum of 3 snapshots are allowed per VNF. The backup image cannot be downloaded and it is only available to restore in the Network Edge infrastructure. ## Image Snapshot and Restore[​](#image-snapshot-and-restore "Direct link to Image Snapshot and Restore") The following conditions for successful Snapshot and Restore apply: * Only 3 snapshots can be saved as backup per VNF. Older backups need to be deleted before creating a new one if the limit is reached. * For cluster deployments, 3 backups per node will be allowed. Both nodes need to be backed up at the same time. * The restore function requires deletion of the current VNF. If any resources such as Connection and Device Link Group are deleted after the image snapshot is taken, the device will not be restored. Feature availability is based on the VNF type and the IBX in which the VNFs are provisioned. Refer to the following table to see if your VNF supports snapshot and restore features. For some VNFs, you need to disable and then re-register the license due to the internal identifier changes during restoration process. | VNF Type | Snapshot and Restore Support | Required User Action | | ----------------------------------------------------------------------- | ---------------------------- | --------------------------------------------------------------------------- | | Any VNF provisioned in the AM4, FR6, LD6, CH1, DA1, DC11, SV5, SG3, SY4 | No | N/A | | Aruba EdgeConnect | Yes | No action required | | Arista CloudEOS | Yes (BYOL) | No action required. VNF should retain the license after restoring | | Arista VeloCloud SD-WAN Edge | Yes | No action required | | Aviatrix Edge | Yes | No action required | | BlueCat | Yes | No action required | | Check Point Firewall | Yes (BYOL) | No action required. VNF should retain the license after restoring | | Cisco Catalyst 8000V (Autonomous Mode) | Yes (BYOL) | User should de-register and register with the smart license after restoring | | Cisco Catalyst 8000V (Controller Mode) | Yes (BYOL) | User should de-register and register with the smart license after restoring | | Cisco FTDv | Yes (BYOL) | User should de-register and register with the smart license after restoring | | Cisco ASAv | Yes (BYOL) | User should de-register and register with the smart license after restoring | | F5 | Yes | No action required | | Fortinet FortiGate vFW / SD-WAN | Yes (BYOL) | No action required. VNF should retain the license after restoring | | Infoblox NIOS | Yes | No action required | | Infoblox Grid Manager | No | N/A | | Gigamon V-Series | No | N/A | | Juniper vSRX | Yes (BYOL) | No action required. VNF should retain the license after restoring | | NGINX Plus | Yes (Subscription) | No action required. VNF should retain the license after restoring | | Palo Alto Networks VM-Series Firewall | Yes (BYOL) | User should de-register and register their license after restoring | | Palo Alto Networks Prisma SD-WAN | No | N/A | | Prisma SD-WAN | No | N/A | | Check Point Firewall | Yes (BYOL) | No action required. VNF should retain the license after restoring | | VERSA | Yes (BYOL) | No action required. VNF should retain the license after restoring | | VyOS | Yes (Subscription) | No action required. VNF should retain the license after restoring | ## Create a Snapshot of VNF Image[​](#create-a-snapshot-of-vnf-image "Direct link to Create a Snapshot of VNF Image") 1. From the *Network Edge* menu, select *Virtual Device Inventory*. 2. Select the device you want to create a snapshot for and then click **Tools**. 3. In the *Snapshot Management* card, click **Create Snapshot**. ![](https://docs.equinix.com/assets/images/NE-snapshot1-06f69aea4427b8aba69386105202afe7.png) 4. In the **Create Image Snapshot** prompt, enter a **Name** for this backup image and select **I am aware that device operations will be limited during this process**. Be aware that estimated time to complete the snapshot may vary based on the size of the VNF. ![](https://docs.equinix.com/assets/images/ne-snapshot2-ngts-a44a4ad016310b0d486837fdab6645a9.png) 5. Click **Submit** to start the snapshot process. Another prompt displays indicating that the image back up is in progress. Click **Back to Device Detail** or **X** to close this prompt. ![](https://docs.equinix.com/assets/images/NE-snapshot3-480bf3b60ee4f2bb4648119b21588f1c.png) In the **Tools** section, the **Snapshot Management** card indicates that the Image Snapshot is in progress, and shows an estimated time for completion. Device status indicates **Image snapshot is in progress**. 6. In the **Snapshot Management** card, click **Manage and Restore from Snapshot** to manage your backups. ![](https://docs.equinix.com/assets/images/NE-snapshot4-646e0b7e59e3360d3d827776dff94695.png) 7. Rename or delete your snapshot by selecting the image and then clicking the edit icon to make a selection. ![](https://docs.equinix.com/assets/images/NE-snapshot5-da3e0a6208bb970220a5fc9f16362521.png) ## Restore VNF[​](#restore-vnf "Direct link to Restore VNF") > **Warning** > > Once the restoration process begins, it cannot be undone. We recommend you create a backup of the current state of the device in case any change to the VNF needs to be saved. 1. From the *Network Edge* menu, select *Virtual Device Inventory*. 2. Select the device that you want to restore from a backup image, then click **Tools**. 3. In the *Snapshot Management* card, click **Manage and Restore from Snapshot**. All of the snapshots will display. 4. Select the image you want to use to restore and click **Restore Device from this Snapshot**. 5. Click **Restore Now** in the *Create a Snapshot Before Restoring (Recommended)* prompt. ![](https://docs.equinix.com/assets/images/NE-snapshot-restoring-device-d45b41260c097affb7105885fc002622.png) After you start the restoration process, your device is not operational for 15 to 20 minutes. The device status indicates that the restoration is in progress.
