# Edit Device Details This topic explains which device details can be edited and demonstrates how to do so. Once a device is ordered using Network Edge, you can edit the following attributes: * **Device Name** – Change your device name any time after the order is placed. The changes will reflect immediately. * **Device Resources** – Change your virtual device resource to a higher resource size without deleting the existing device and creating a new one. Changing the device resource size changes the price of the virtual device. * **Term Length** – Increase the device's term length after the device is provisioned and the license is registered. Term length can only be increased; it can't be reduced once the order is placed. * **Notification Emails** – Delete existing notification emails or add new ones. At least one notification email is required for the device status notifications. Notifications are also available in the *Notification Center* in the Equinix Customer Portal. 1. Sign in to the [Equinix Customer Portal](https://portal.equinix.com/ne/new-virtual-device) and navigate to Network Edge. 2. In the *Network Edge* drop-down, select *Virtual Device Inventory*. ![](https://docs.equinix.com/assets/images/NE-edit-View-Virtual-Devices-110c609eccfa2b71bc087935d33f1a02.png) 3. Click the device to be edited. 4. In the Device Details pane, scroll to **Virtual Device Name** and click **Edit** to change the device name. ![](https://docs.equinix.com/assets/images/NE-edit-Virtual-Device-Name-96e10d4b94a5b5106399118e4edf4465.png) 5. To edit the device resources size, scroll to **Device Resources** and click **Edit**. ![](https://docs.equinix.com/assets/images/NE-edit-Virtual-Device-resource-0800ef8505dc7324bb2b13f82c04a013.png) 6. To edit the term length, scroll to **Term Length** and click **Edit**. ![](https://docs.equinix.com/assets/images/NE-edit-Term-Length-7ac266700148968c13306f99bc95ae4b.png) > **Note** > > In addition to changing your term length, you can also opt out of auto-renewal of your device terms and choose a month-to-month option effective upon expiration of the original term length. 1. To change the notification emails, scroll to the **Notification Details** pane and click **Edit**. ![](data:image/png;base64,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)
