# Device Statuses Device status indicates the current lifecycle stage of a virtual device on the Network Edge platform. Statuses appear in the Virtual Device Inventory and Device Details views. An icon represents each status; hover over the icon to view a short description. Most statuses are transitional during provisioning, updates, or deletion. Some statuses are terminal or require user action. ## Status Definitions[​](#status-definitions "Direct link to Status Definitions") ### DRAFT[​](#draft "Direct link to DRAFT") **Expected:** Yes
**Duration:** Indefinite
**Description:** The device order is created but not submitted. No resources are allocated and no processing occurs.
**Action:** Submit the order to begin provisioning. ### PENDING\_SIGNATURE[​](#pending_signature "Direct link to PENDING_SIGNATURE") **Expected:** Yes
**Duration:** Customer-controlled
**Description:** The order is awaiting customer acceptance and signature. Provisioning does not begin until completed.
**Action:** Complete the signature step. If signed but unchanged, contact support. ### PENDING\_ORDER[​](#pending_order "Direct link to PENDING_ORDER") **Expected:** Yes
**Description:** The order has been submitted outside the portal and is awaiting confirmation.
**Action:** Contact support if the status does not progress. ### CANCEL\_ORDER[​](#cancel_order "Direct link to CANCEL_ORDER") **Expected:** Yes (terminal)
**Duration:** Persistent
**Description:** The order was canceled before provisioning. No resources were created.
**Action:** Create a new order if needed. ### INITIALIZING[​](#initializing "Direct link to INITIALIZING") **Expected:** Yes
**Duration:** Short
**Description:** The system is validating inputs and preparing resources before provisioning.
**Action:** Contact support if this persists unusually long. ### PROVISIONING[​](#provisioning "Direct link to PROVISIONING") **Expected:** Yes
**Duration:** Medium
**Description:** The device is being created and configured.
**Action:** No action required unless delayed. ### PROVISIONING\_ONHOLD[​](#provisioning_onhold "Direct link to PROVISIONING_ONHOLD") **Expected:** Yes
**Duration:** Variable
**Description:** Provisioning is paused pending account or prerequisite completion.
**Action:** Ensure account setup is complete or contact support. ### WAITING\_FOR\_SECONDARY[​](#waiting_for_secondary "Direct link to WAITING_FOR_SECONDARY") **Expected:** Yes (HA only)
**Duration:** Short
**Description:** The primary device is ready; the system is waiting for the secondary device.
**Action:** Contact support if delayed. ### WAITING\_FOR\_REPLICA\_CLUSTER\_NODES[​](#waiting_for_replica_cluster_nodes "Direct link to WAITING_FOR_REPLICA_CLUSTER_NODES") **Expected:** Yes (cluster only)
**Description:** Cluster nodes are waiting for all nodes to reach readiness before setup.
**Action:** Contact support if stalled. ### CLUSTER\_SETUP\_IN\_PROGRESS[​](#cluster_setup_in_progress "Direct link to CLUSTER_SETUP_IN_PROGRESS") **Expected:** Yes
**Description:** Cluster configuration is being applied across all nodes.
**Action:** No action unless delayed. ### CLUSTER\_SETUP\_FAILED[​](#cluster_setup_failed "Direct link to CLUSTER_SETUP_FAILED") **Expected:** No
**Duration:** Persistent until resolved
**Description:** Cluster configuration failed.
**Action:** Retry setup from the portal or contact support. ### PROVISIONED[​](#provisioned "Direct link to PROVISIONED") **Expected:** Yes (target state)
**Description:** The device is fully operational and ready for use.
**Action:** None. ### LICENSE\_FAILED[​](#license_failed "Direct link to LICENSE_FAILED") **Expected:** No
**Description:** Device licensing could not be completed.
**Action:** Verify licensing details or contact support. ### FAILED[​](#failed "Direct link to FAILED") **Expected:** No
**Description:** Device provisioning failed due to a system error.
**Action:** Contact support or recreate the device. ### REBOOT\_IN\_PROGRESS[​](#reboot_in_progress "Direct link to REBOOT_IN_PROGRESS") **Expected:** Yes
**Duration:** Short
**Description:** The device is rebooting.
**Action:** Wait for completion; contact support if delayed. ### DEVICE\_BACKUP\_RESTORE\_IN\_PROGRESS[​](#device_backup_restore_in_progress "Direct link to DEVICE_BACKUP_RESTORE_IN_PROGRESS") **Expected:** Yes
**Description:** A configuration restore operation is underway.
**Action:** No action unless delayed. ### NETWORK\_VNI\_UPDATE\_IN\_PROGRESS[​](#network_vni_update_in_progress "Direct link to NETWORK_VNI_UPDATE_IN_PROGRESS") **Expected:** Yes
**Duration:** Short
**Description:** Network interface configuration is being updated.
**Action:** Contact support if delayed. ### REINSTANTIATION\_IN\_PROGRESS[​](#reinstantiation_in_progress "Direct link to REINSTANTIATION_IN_PROGRESS") **Expected:** Yes
**Duration:** Short
**Description:** The device is being rebuilt or replaced as part of a recovery workflow.
**Action:** No action unless delayed. ### TO\_BE\_DISABLED / DISABLE\_IN\_PROGRESS[​](#to_be_disabled--disable_in_progress "Direct link to TO_BE_DISABLED / DISABLE_IN_PROGRESS") **Expected:** Yes
**Duration:** Short
**Description:** The device is being stopped due to administrative or billing conditions.
**Action:** Resolve billing or contact support if unexpected. ### DISABLED[​](#disabled "Direct link to DISABLED") **Expected:** Yes
**Description:** The device is inactive and not operational.
**Action:** Resolve the underlying condition (billing, subscription, or admin action). ### RECOVERY\_INITIATED[​](#recovery_initiated "Direct link to RECOVERY_INITIATED") **Expected:** No (automatic recovery)
**Description:** The system is attempting automatic recovery of an unreachable device.
**Action:** Wait for completion or contact support if unsuccessful. ### DEPROVISIONING[​](#deprovisioning "Direct link to DEPROVISIONING") **Expected:** Yes
**Duration:** Short
**Description:** The device and associated resources are being deleted.
**Action:** No action. ### DEPROVISIONED[​](#deprovisioned "Direct link to DEPROVISIONED") **Expected:** Yes (terminal)
**Description:** The device has been fully removed.
**Action:** Create a new device if needed. ## How to Resolve Stuck Device Statuses[​](#how-to-resolve-stuck-device-statuses "Direct link to How to Resolve Stuck Device Statuses") Use this guide when a device remains in a status longer than expected. Follow the steps for the category that matches your current status. ### Before you begin[​](#before-you-begin "Direct link to Before you begin") 1. Confirm the device status on the Device Details page 2. Check how long the device has been in that status 3. Compare with expected durations in the Device Status reference If the status duration is within the normal range, no action is required. ### Step 1: Identify your status category[​](#step-1-identify-your-status-category "Direct link to Step 1: Identify your status category") Match your device status to one of the categories below: | Category | Statuses | | --------------------------- | ------------------------------------------------------------------------------------------------------------------------------ | | Order / Pre-provisioning | DRAFT, PENDING\_SIGNATURE, PENDING\_ORDER | | Provisioning (in progress) | INITIALIZING, PROVISIONING, PROVISIONING\_ONHOLD | | High Availability / Cluster | WAITING\_FOR\_SECONDARY, WAITING\_FOR\_REPLICA\_CLUSTER\_NODES, CLUSTER\_SETUP\_IN\_PROGRESS | | Operational transitions | REBOOT\_IN\_PROGRESS, NETWORK\_VNI\_UPDATE\_IN\_PROGRESS, REINSTANTIATION\_IN\_PROGRESS, DEVICE\_BACKUP\_RESTORE\_IN\_PROGRESS | | Error states | FAILED, LICENSE\_FAILED, CLUSTER\_SETUP\_FAILED | | System recovery | RECOVERY\_INITIATED | | Disabled / billing states | TO\_BE\_DISABLED, DISABLE\_IN\_PROGRESS, DISABLED | | Deletion | DEPROVISIONING | ### Step 2: Follow the resolution steps[​](#step-2-follow-the-resolution-steps "Direct link to Step 2: Follow the resolution steps") #### Order / Pre-provisioning Issues[​](#order--pre-provisioning-issues "Direct link to Order / Pre-provisioning Issues") * Symptoms: * Device not progressing beyond early states * Actions: * DRAFT → Submit the order * PENDING\_SIGNATURE → Complete signature step * PENDING\_ORDER → Confirm order with your sales contact * If still stuck: * Contact support and provide: * Device name / UUID * Order confirmation details #### Provisioning Delays[​](#provisioning-delays "Direct link to Provisioning Delays") * Symptoms: * Device stuck in INITIALIZING, PROVISIONING, or PROVISIONING\_ONHOLD * Actions: * Wait for the expected duration * If beyond expected duration: * Verify account setup (for ONHOLD cases) * Ensure all required inputs were provided correctly * If still stuck: * Contact support and provide: * Device name / UUID #### HA / Cluster issues[​](#ha--cluster-issues "Direct link to HA / Cluster issues") * Symptoms * Secondary device or cluster nodes not completing * Actions: * Check if all related devices are progressing: Secondary device (HA), All nodes (cluster) * If beyond expected duration: * Look for any node in: * FAILED * PROVISIONING (stalled) * If still stuck: * Contact support and provide: * Device name / UUID #### Operational transitions stuck[​](#operational-transitions-stuck "Direct link to Operational transitions stuck") * Symptoms: * Device stuck during reboot, updates, or maintenance * Actions * Wait for completion (most are short-lived) * If beyond expected: * Refresh device status * Confirm no concurrent operations are running * If still stuck: * Contact support and provide: * Device name / UUID #### Error states[​](#error-states "Direct link to Error states") * FAILED * Meaning: Provisioning failed * Action: * Deprovision the device * Create a new device * If still failed: * Contact support and provide: * Device name / UUID * LICENSE\_FAILED * Meaning: Licensing issue * Action: * Verify: * License validity (BYOL) * License availability (subscription) * Retry if possible * If still failed: * Contact support and provide: * Device name / UUID * CLUSTER\_SETUP\_FAILED * Meaning: Cluster configuration failed * Action: * Retry cluster setup from the portal * Or proceed with manual configuration if supported * If still failed: * Contact support and provide: * Device name / UUID #### System Recovery[​](#system-recovery "Direct link to System Recovery") * RECOVERY\_INITIATED * Meaning: Automatic recovery in progress * Actions: * Wait for completion * If recovery fails: * The device may transition to an error state * Contact support and provide: * Device name / UUID #### Disabled devices[​](#disabled-devices "Direct link to Disabled devices") * Symptoms: * Device not operational * Actions: * Billing issue → Resolve payment or subscription * Trial expired → Upgrade to paid subscription * Disabled in error → Contact support * If still stuck: * Contact support and provide: * Device name / UUID * Order confirmation detail #### Deletion issues[​](#deletion-issues "Direct link to Deletion issues") * DEPROVISIONING * Actions * Wait for process completion * If still stuck: * Contact support and provide: * Device name / UUID * Order confirmation detail ### What to Include in a Support Request[​](#what-to-include-in-a-support-request "Direct link to What to Include in a Support Request") To speed up resolution, provide: * Device UUID or name * Current status * Time in current status * Any recent actions (create, reboot, update, etc.) ## Notes[​](#notes "Direct link to Notes") * Some internal or transitional platform states are not exposed in the portal. * Duration varies based on device type, configuration, and workload. * For any state that persists longer than expected, contact support.
