Device Statuses
Device status indicates the current lifecycle stage of a virtual device on the Network Edge platform. Statuses appear in the Virtual Device Inventory and Device Details views. An icon represents each status; hover over the icon to view a short description. Most statuses are transitional during provisioning, updates, or deletion. Some statuses are terminal or require user action.
Status Definitions​
DRAFT​
Expected: Yes
Duration: Indefinite
Description: The device order is created but not submitted. No resources are allocated and no processing occurs.
Action: Submit the order to begin provisioning.
PENDING_SIGNATURE​
Expected: Yes
Duration: Customer-controlled
Description: The order is awaiting customer acceptance and signature. Provisioning does not begin until completed.
Action: Complete the signature step. If signed but unchanged, contact support.
PENDING_ORDER​
Expected: Yes
Description: The order has been submitted outside the portal and is awaiting confirmation.
Action: Contact support if the status does not progress.
CANCEL_ORDER​
Expected: Yes (terminal)
Duration: Persistent
Description: The order was canceled before provisioning. No resources were created.
Action: Create a new order if needed.
INITIALIZING​
Expected: Yes
Duration: Short
Description: The system is validating inputs and preparing resources before provisioning.
Action: Contact support if this persists unusually long.
PROVISIONING​
Expected: Yes
Duration: Medium
Description: The device is being created and configured.
Action: No action required unless delayed.
PROVISIONING_ONHOLD​
Expected: Yes
Duration: Variable
Description: Provisioning is paused pending account or prerequisite completion.
Action: Ensure account setup is complete or contact support.
WAITING_FOR_SECONDARY​
Expected: Yes (HA only)
Duration: Short
Description: The primary device is ready; the system is waiting for the secondary device.
Action: Contact support if delayed.
WAITING_FOR_REPLICA_CLUSTER_NODES​
Expected: Yes (cluster only)
Duration: Medium
Description: Cluster nodes are waiting for all nodes to reach readiness before setup.
Action: Contact support if stalled.
CLUSTER_SETUP_IN_PROGRESS​
Expected: Yes
Duration: Medium
Description: Cluster configuration is being applied across all nodes.
Action: No action unless delayed.
CLUSTER_SETUP_FAILED​
Expected: No
Duration: Persistent until resolved
Description: Cluster configuration failed.
Action: Retry setup from the portal or contact support.
PROVISIONED​
Expected: Yes (target state)
Description: The device is fully operational and ready for use.
Action: None.
LICENSE_FAILED​
Expected: No
Description: Device licensing could not be completed.
Action: Verify licensing details or contact support.
FAILED​
Expected: No
Description: Device provisioning failed due to a system error.
Action: Contact support or recreate the device.
REBOOT_IN_PROGRESS​
Expected: Yes
Duration: Short
Description: The device is rebooting.
Action: Wait for completion; contact support if delayed.
DEVICE_BACKUP_RESTORE_IN_PROGRESS​
Expected: Yes
Duration: Medium
Description: A configuration restore operation is underway.
NETWORK_VNI_UPDATE_IN_PROGRESS​
Expected: Yes
Duration: Short
Description: Network interface configuration is being updated.
REINSTANTIATION_IN_PROGRESS​
Expected: Yes
Duration: Short
Description: The device is being rebuilt or replaced as part of a recovery workflow.
TO_BE_DISABLED / DISABLE_IN_PROGRESS​
Expected: Yes
Duration: Short
Description: The device is being stopped due to administrative or billing conditions.
Action: Resolve billing or contact support if unexpected.
DISABLED​
Expected: Yes
Description: The device is inactive and not operational.
Action: Resolve the underlying condition (billing, subscription, or admin action).
RECOVERY_INITIATED​
Expected: No (automatic recovery)
Duration: Medium
Description: The system is attempting automatic recovery of an unreachable device.
Action: Wait for completion or contact support if unsuccessful.
DEPROVISIONING​
Expected: Yes
Duration: Short
Description: The device and associated resources are being deleted.
Action: No action.
DEPROVISIONED​
Description: The device has been fully removed.
Action: Create a new device if needed.
How to Resolve Stuck Device Statuses​
Use this guide when a device remains in a status longer than expected. Follow the steps for the category that matches your current status.
Before you begin​
  1. Confirm the device status on the Device Details page
  2. Check how long the device has been in that status
  3. Compare with expected durations in the Device Status reference
If the status duration is within the normal range, no action is required.
Step 1: Identify your status category​
Match your device status to one of the categories below:
CategoryStatuses
Order / Pre-provisioningDRAFT, PENDING_SIGNATURE, PENDING_ORDER
Provisioning (in progress)INITIALIZING, PROVISIONING, PROVISIONING_ONHOLD
High Availability / ClusterWAITING_FOR_SECONDARY, WAITING_FOR_REPLICA_CLUSTER_NODES, CLUSTER_SETUP_IN_PROGRESS
Operational transitionsREBOOT_IN_PROGRESS, NETWORK_VNI_UPDATE_IN_PROGRESS, REINSTANTIATION_IN_PROGRESS, DEVICE_BACKUP_RESTORE_IN_PROGRESS
Error statesFAILED, LICENSE_FAILED, CLUSTER_SETUP_FAILED
System recoveryRECOVERY_INITIATED
Disabled / billing statesTO_BE_DISABLED, DISABLE_IN_PROGRESS, DISABLED
DeletionDEPROVISIONING
Step 2: Follow the resolution steps​
Order / Pre-provisioning Issues​
  • Symptoms:
    • Device not progressing beyond early states
  • Actions:
    • DRAFT → Submit the order
    • PENDING_SIGNATURE → Complete signature step
    • PENDING_ORDER → Confirm order with your sales contact
  • If still stuck:
    • Contact support and provide:
      • Device name / UUID
      • Order confirmation details
Provisioning Delays​
  • Symptoms:
    • Device stuck in INITIALIZING, PROVISIONING, or PROVISIONING_ONHOLD
  • Actions:
    • Wait for the expected duration
  • If beyond expected duration:
    • Verify account setup (for ONHOLD cases)
    • Ensure all required inputs were provided correctly
  • If still stuck:
HA / Cluster issues​
  • Symptoms
    • Secondary device or cluster nodes not completing
  • Actions:
    • Check if all related devices are progressing: Secondary device (HA), All nodes (cluster)
    • Look for any node in:
      • FAILED
      • PROVISIONING (stalled)
  • If still stuck:
Operational transitions stuck​
  • Symptoms:
    • Device stuck during reboot, updates, or maintenance
  • Actions
    • Wait for completion (most are short-lived)
  • If beyond expected:
    • Refresh device status
    • Confirm no concurrent operations are running
  • If still stuck:
Error states​
  • FAILED
    • Meaning: Provisioning failed
    • Action:
      • Deprovision the device
      • Create a new device
    • If still failed:
  • LICENSE_FAILED
    • Meaning: Licensing issue
    • Action:
      • Verify:
        • License validity (BYOL)
        • License availability (subscription)
      • Retry if possible
    • If still failed:
  • CLUSTER_SETUP_FAILED
    • Meaning: Cluster configuration failed
    • Action:
      • Retry cluster setup from the portal
      • Or proceed with manual configuration if supported
    • If still failed:
System Recovery​
  • RECOVERY_INITIATED
    • Meaning: Automatic recovery in progress
    • Actions:
    • If recovery fails:
      • The device may transition to an error state
Disabled devices​
  • Symptoms:
    • Device not operational
  • Actions:
    • Billing issue → Resolve payment or subscription
    • Trial expired → Upgrade to paid subscription
    • Disabled in error → Contact support
  • If still stuck:
Deletion issues​
  • DEPROVISIONING
    • Actions
      • Wait for process completion
    • If still stuck:
What to Include in a Support Request​
To speed up resolution, provide:
  • Device UUID or name
  • Current status
  • Time in current status
  • Any recent actions (create, reboot, update, etc.)
Notes​
  • Some internal or transitional platform states are not exposed in the portal.
  • Duration varies based on device type, configuration, and workload.
  • For any state that persists longer than expected, contact support.
