Virtual Device Details
The Virtual Device Details page provides a single location for viewing all of your Network Edge devices and accessing details for each device.
Virtual Device Diagram​
The virtual device diagram illustrates your device. As you make changes to the device, the diagram changes to reflect your edits.
Details Tab​
The Details tab displays by default when you click a device in the Virtual Device Inventory.
Account Details​
The Account Details section lists the Account Name and Account Number.
Device Details​
The Device Details sections lists all of the information about your device.
Click Edit to change the Device Name, or upgrade Device Resources or the Term Length.
Compute Plane indicates the plane your VNF resides on. This information can help you design your resilient network more easily.
Ordering Contact​
The Ordering Contact section lists the name and email address of the person responsible for the order.
Notification Details​
The Notification Details section lists the email address(es) of anyone who should receive notifications regarding the device.
License Information​
The License Information section indicates the license type and status.
Activity Log​
The Activity Log section displays the date of the last device update as well as which user updated the device. The date the device was create as well as the user who created the device also display.
Connections Tab​
Click Connections to view all the connections that have been created from this device to other destinations, including Equinix Fabric.
Interfaces Tab​
Click Interfaces to view the interfaces tied to your device.
Interface Traffic​
To monitor you device utilization traffic:
  1. In your Virtual Device Inventory, click on the device you want to monitor.
  2. In the Device Details, click the Interfaces tab.
  3. Expand the arrow next to the port you want to monitor and a graph will display showing Inbound and Outbound traffic for the last 7 days.
Refresh the graph by clicking Refresh.
Change the duration using the drop-down. Choose Last 7 days or Last 24 hours.
Additional Services Tab​
Click Additional Services to add more Network Edge services to your device.
In the Device Link section, click Add New Device Link to add a device link.
Select from your provisioned devices and provide a unique name for the device link. It may take up to 10 minutes for the devices to be linked. For more information about device links, see Device Linking.
Default and Additional Bandwidth​
All devices include 15 Mbps of internet bandwidth. For a fee, you can add additional internet bandwidth based on current service limits. At least one access control list must be provisioned before editing additional internet bandwidth.
Access Management​
The Access Management section displays any ACL template that has been applied to your device. If no template is applied, click Edit to add an existing ACL template or create a new one.
For more information about ACL templates, see Configure Access Controls on Virtual Devices.
Tools​
Click the Tools tab to access device configuration tools.
Version Control​
Version Control allows you to upgrade, downgrade, or roll back your devices to an Equinix-certified image.
Console Access​
Console Access allows you to edit your device configuration through the console. Click Open Console Session to edit your device.
For more information about console access, see SSH Key and Console Access.
Snapshot Management​
Use the Snapshot Management feature to create configuration snapshots for your active devices. Snapshots can be used to restore devices to a previous state.
Replace Virtual Device​
If you want to replace a VNF due to issues with the VNF itself (not related to the underlying infrastructure), use the self-guided device replacement process from the Network Edge portal.
For more information about console access, see Manual Device Replacement.
Reboot Device​
The Reboot Device feature allows you to reload your device in the event of a communications failure. There is no restriction on the number of times a device can be reloaded.
For more information about reloading your device, see Reload Device.
Software Version Download​
On select device types, you can download the software version and save it a location of your choosing.
