# Create a Redundant Device Link Group for Resiliency ### Create a Redundant Device Link Group[​](#create-a-redundant-device-link-group "Direct link to Create a Redundant Device Link Group") When the first Device Link Group (DLG) is created and multiple devices are added from multiple metros to this group, the traffic is routed through the primary Fabric plane by default. In case of a service impacting incident with primary Fabric plane, or service-impacting maintenance, this primary Device Link will be also impacted. A secondary DLG is highly recommended to increase availability of your device connectivity. For more information about DLG resiliency, see [Device Link Resiliency.](https://docs.equinix.com/network-edge/device-link/ne-device-link-redundancy.md) ## Create a Secondary DLG (for a Cluster Device)[​](#create-a-secondary-dlg-for-a-cluster-device "Direct link to Create a Secondary DLG (for a Cluster Device)") A secondary DLG can be created as follows: 1. Sign in to the [Equinix Customer Portal](https://portal.equinix.com/ne/new-virtual-device) and go to the *Network Edge Dashboard*. 2. From the *Network Edge* menu, select **Device Link Inventory**. 3. Click **Create New Device Link Group** to start the DLG creation workflow. ![](https://docs.equinix.com/assets/images/NE-DLG-create-new-93f69c02b1b601f7e4519d21441b88ba.png) 4. All of your devices will display. Click the devices you want to link. 5. Click **Next: Device Link Details**. 6. In the Device Link Details section enter a link name in the Device Link Name field. 7. Select **Secondary** to create a secondary DLG connection through the secondary Fabric plane. 8. Select a **Connection Bandwidth**. 9. In the **Term Length** section, select a [term length](https://docs.equinix.com/network-edge/billing/ne-pricing-terms-billing.md). ![](https://docs.equinix.com/assets/images/ne-dlg-term-length-d70e2586d795c6c2b1df700e44369b26.png) > **Note** > > All Device Link Groups have independent term lengths regardless of the individual device term lengths. 10. In the **Interfaces** section, select: * **Automatically select the next available interface on my device(s)** if you want to use the next available interface. * **I will select an interface** if you want to specify an interface, and then select a primary interface and a secondary interface. 11. Click **Next: Review** and review your order. 12. Click **Submit**. > **Note** > > As a best practice, it is recommended that you keep the primary DLG routed through the primary Fabric plane and the secondary DLG routed through the secondary Fabric plane to simplify the design for troubleshooting.
