# FCR Integration with Network Edge Fabric Cloud Router (FCR) now supports connection to Network Edge devices, allowing you to connect to the Internet, service chaining services such as firewalls and SD-WAN, and others. If you have redundant Network Edge devices, FCR also supports redundancy to provide end-to-end resiliency. ![](https://docs.equinix.com/assets/images/NE-conn-FCR-integration-557c70e0d317d32ca0145aee45b3cbe6.png) See [About Equinix Fabric Cloud Router](https://docs.equinix.com/fabric-cloud-router.md) for information about FCR. To understand FCR Integration with Network Edge in detail, see [Connect to a Network Edge Virtual Device](https://docs.equinix.com/fabric-cloud-router/connections/fcr-connect-virtual-device.md) and [Redundant Connectivity Through Network Edge](https://docs.equinix.com/fabric-cloud-router/use-cases/fcr-redundant-ne-use.md).
