FCR Integration with Network Edge
Fabric Cloud Router (FCR) now supports connection to Network Edge devices, allowing you to connect to the Internet, service chaining services such as firewalls and SD-WAN, and others. If you have redundant Network Edge devices, FCR also supports redundancy to provide end-to-end resiliency.
See About Equinix Fabric Cloud Router for information about FCR.
To understand FCR Integration with Network Edge in detail, see Connect to a Network Edge Virtual Device and Redundant Connectivity Through Network Edge.
