# EIA Integration with Network Edge Equinix Internet Access (EIA) can be ordered on any available data interface on a Network Edge Virtual Device over Equinix Fabric. EIA integration with Network Edge currently supports: * Single and dual connections on Network Edge devices, including a single independent connection for each device in a cluster pair or a redundant pair. * 10 Gbps and 25 Gbps virtual connections. Support for 25 Gbps connections is dependent on the virtual device's capabilities and licensing. * The option for you to bring your own IP address blocks or use Equinix provided IP blocks. * Reseller and sub-account support and permissions. > **Note** > > Only virtual devices with an Equinix Public IP Address are entitled to the default 15 Mbps internet bandwidth. Also note the [Additional Bandwidth](https://docs.equinix.com/network-edge/manage-devices/ne-additional-internet-bandwidth.md) feature will continue to be available for architectures that may require it. To understand EIA Integration with Network Edge in detail, see [Supported Network Edge Configurations](https://docs.equinix.com/internet-access.md#network-edge). See [About Equinix Internet Access](https://docs.equinix.com/internet-access.md) for information about EIA.
