EIA Integration with Network Edge
Equinix Internet Access (EIA) can be ordered on any available data interface on a Network Edge Virtual Device over Equinix Fabric. EIA integration with Network Edge currently supports:
- Single and dual connections on Network Edge devices, including a single independent connection for each device in a cluster pair or a redundant pair.
- 10 Gbps and 25 Gbps virtual connections. Support for 25 Gbps connections is dependent on the virtual device's capabilities and licensing.
- The option for you to bring your own IP address blocks or use Equinix provided IP blocks.
- Reseller and sub-account support and permissions.
Only virtual devices with an Equinix Public IP Address are entitled to the default 15 Mbps internet bandwidth. Also note the Additional Bandwidth feature will continue to be available for architectures that may require it.
To understand EIA Integration with Network Edge in detail, see Supported Network Edge Configurations.
See About Equinix Internet Access for information about EIA.
