Connect a Virtual Device to Colt On Demand
Connect your Network Edgevirtual device to Colt On Demand network services through Equinix Fabric to gain access to enterprise or branch locations, cloud providers, partners, and suppliers from a single access point.
Colt On Demand network services can be reached from Equinix Fabric locally in several metros and remotely from any Equinix Fabric locations.
Prerequisites
Connect to Colt On Demand
  1. Sign in to the Equinix Customer Portal and navigate to Network Edge.
  2. From the Connections menu, select Create Connection.
  3. On the A Service Provider card, click Connect to a Service Provider.
  4. Enter Colt in the search field.
  5. On the Colt card, click Select.
  6. On the Colt On Demand Interconnect card, click Create Connection.
  7. In the Origin section, click Virtual Device. (For information about connecting an Equinix Fabric port, see Colt on Demand in the Equinix Fabric documentation.)
  8. Select an origin location.
  9. From the available device types for the location you selected, select a Virtual Device type.
  10. From the available devices for the device type and location you selected, select a device.
  11. In the Destination section, select the destination location and click Next.
  12. Click Next. A Remote Connection message will display.
  13. Click OK.
  14. In the Connection Information section, enter a name for your connection.
  15. In the Interface Selection section, indicate whether you want the next available interface automatically selected for you, or if you want to select the interface yourself.
  16. (Optional) In the Purchase Order Number field, enter your PO number.
  17. In the Connection Speed section, select a Billing Tier and Speed combination.
  18. Click Next.
  19. Review your order. Click Design Summary to download a PDF.
  20. In the Notifications section, enter the email address(es) of any additional recipients to which you want email notifications about this connection sent.
  21. Click Submit Order.
  22. On the order confirmation screen, copy the connection ID for use in the Colt Portal when enabling on-demand services.
From the Connections menu, select Connections Inventory to view the status of your connection or get your connection ID if necessary.
Add a Cloud Port to Equinix Fabric
After you create the connection in the Equinix Customer Portal, access the Colt On Demand portal to add a cloud port to Equinix Fabric.
  1. Sign in to Colt On Demand.
  2. Select Ports and click + Add Cloud Port.
  3. On the list of cloud providers, select Equinix, then click Continue.
  4. In the Add a Cloud Port window:
    • Port Name – Enter a name for the port.
    • Service Key – Paste the connection ID obtained upon submission of your order in Equinix Fabric.
    • Metro – Select the same metro region used when creating the connection in Equinix Fabric.
    • Location – Select a specific location within the metro region.
  5. Click Continue.
  6. Review your order and click Accept Charges & Submit.
    Once the order is completed, the cloud port is displayed under Equinix.
  7. To add the cloud connection to your network, select Connections and click + Cloud.
  8. On the list of cloud providers, select Equinix, then click Continue.
  9. In the Add Cloud Connection window:
    • Enter Name – Enter a name for the connection.
    • Cloud Port – Select the Equinix cloud port you created.
    • Bandwidth – Select a connection bandwidth option.
    • To Primary Port – Select the port facing your network.
    • VLAN – Select Open port for port-based handover, or select Add VLAN to tag traffic with a VLAN.
    • Commitment – Select a contract term.
  10. Click Continue.
  11. Review your order and click Accept changes & submit.
The connection is automatically provisioned on the network.
