# Create an Untagged BYOC Connection with an Existing Port If you already have an existing port, you can create a single untagged connection over a Dot1q port. There is no requirement to order a new port. To create the BYOC connection to your existing port: 1. Sign in to the [Equinix Customer Portal](https://portal.equinix.com/ne/new-virtual-device) and navigate to *Network Edge*. 2. Click **Create Connection**. 3. In the **My Own Assets** card, click **Connect to My Own Assets**. ![](https://docs.equinix.com/assets/images/NE-UnBYOC-my-own-assets-b2e4502f38c70b945938ac4e733e6d1e.png) 4. In the *Connect My Assets as E-Line* card, click **Create Connection**. 5. In the *Origin* section, click **Virtual Device**. 6. Select a location. 7. Click **Virtual Devices**. 8. Select a device in the location you selected. 9. In the *Destination* section, select a location. 10. Select an existing port and Click **Next**. 11. In the *Virtual Connection Name* field, enter a name for your connection. 12. In the *Connection Type* section, click **Untagged**. ![](https://docs.equinix.com/assets/images/NE-UnBYOC-untagged-2973d52452f0b9f0e2fdffc7be3ca89c.png) > **Info** > > Because only one untagged connection is allowed, a warning will display informing you that attempting to add more than one will cause an error. 13. Select a **Connection Speed**. 14. Click **Next**. 15. In the **Notifications** section, enter the email address(es) of anyone who should receive notification regarding this connection. 16. Click **Submit Order**.
