EBC Flex Operational Activities
Responsibilities​
Provisioning​
Provisioning of the Following ComponentsEquinixCustomer
Delivery of the virtual EBC data centers in accordance with the designRACI¹
Delivery of the agreed compute capacity in accordance with the designRACI¹
Delivery of the agreed storage capacity in accordance with the designRACI¹
Delivery of the agreed backup capacity according to the design (optional)RACI¹
Delivering the agreed network functionality in accordance with the design (optional)RACI¹
Delivery of the EBC management consoleRACI¹
Creating 2 virtual routers per VDC in size "M"RACI¹
Create 1 virtual router in the Inter-vApp network for each size "S"RACI
Single Sign-On
Configure password complexityI²RAC
Configure external authentication sourcesI²RAC
Set two-factor authenticationRACI
Self-service password recoveryI²RAC
Full control over identities and assigned roles
Standard Installation and Configuration​
Installation and ConfigurationEquinixCustomer
Initial configuration of the purchased EBC solution in accordance with the designRACI¹
Initial configuration of the management layer for the EBC customer solutionRACI¹
Initial configuration of the Equinix backup/snapshot for the IaaS layer under the EBC customer solutionRACI¹
Create, import, and manage VMs and vAppsRACRAC
Scale VMs up and downI²RACI
Manage VM SnapshotsRACI
Manage access to VMs with the consoleRACI
Request performance statisticsRACI
Create and fill "Library" with your own ISO/OVA filesRACI
Manage extensive EBC data centers with extensive scripting & automation capabilitiesRACI
Separate or group VMs for availability or performanceI²RAC
NFV
Virtual L2 networksI²RAC
Standard firewallingI²RAC
Routing (static)I²RAC
Routing (dynamic OSPF / BGP)I²RAC
NATI²RAC
DHCPI²RAC
Load BalancingI²RAC
VPN (IPSec, Client)I²RAC
Operational Standard Management Processes​
Operational Standard Management ProcessesEquinixCustomer
Technical management of the service (overall)RACI¹
Functional management of the customer environment within the service (overall)I²RAC
Monitoring of the underlying IaaS components of the service providedRACI¹
Management of the Equinix backup/snapshot solution for relevant underlying IaaS components of the service providedRACI¹
Management of the Shared Management layer of the serviceRACI¹
Notes:
  • Informing is only mandatory for tasks that have an impact on the functioning of the user environment.
  • Informing is only required for tasks that have an impact on the operation and/or management of the service.
