# Network Edge Dashboard
The Network Edge Dashboard provides a clear overview of your setup and simplifies the process of initiating and managing various ordering options.
To access the Network Edge Dashboard, log in to the [Customer Portal](https://portal.equinix.com) and navigate to Network Edge.
![Network Edge Dashboard](/ja/assets/images/NE-dashboard-full-56a2f79c5e4f6e50e7850b7d0547801c.png)
## Network Edge Services[​](#network-edge-services "への直接リンクNetwork Edge Services")
The Network Edge Services section provides quick access to the most popular actions and connection options, as well as the Solution Builder.
![Network Edge Services](/ja/assets/images/NE-dashboard-services-3296763d4ffdabf33fd9f6f2194bed9e.png)
## Your Equinix Services at a Glance[​](#your-equinix-services-at-a-glance "への直接リンクYour Equinix Services at a Glance")
The *Your Equinix Services at a Glance* section provides an overview of your Network Edge assets and provides quick access to your device inventories.
![Services at a Glance](/ja/assets/images/NE-dashboard-your-services-e30d22550ae577ebaac2caaa9d02bf59.png)
* Virtual Devices in `PROVISIONED` state.
* Connections in `ACTIVE` and `PROVISIONING` states.
* Device Link Groups in `ACTIVE` and `PROVISIONING` states.
* Bring Your Own Connections in `ACTIVE` state.
## Support Center[​](#support-center "への直接リンクSupport Center")
View your support requests statistics, open a support case, or access the support center.
![Support Center](/ja/assets/images/NE-dash-support-5a655af3d2a3883a4990635e0a6874f2.png)
## Metros[​](#metros "への直接リンクMetros")
Click **View Metros** to see an up-to-date list of all the global metros available to host Network Edge devices.
![View Available Metros for Network Edge](/ja/assets/images/NE-dash-avail-metros-913d6934cd425b2d2346623aa6a672ec.png)
