# Issue a Digital Letter of Authorization
## New Digital LOA Manager[​](#new-digital-loa-manager "への直接リンクNew Digital LOA Manager")
In the new Digital LOA Manager, **Requestors** request LOAs and **Issuers** issue and authorize them.
1. Sign in to the [Customer Portal](https://portal.equinix.com/).
2. Go to the *Orders and Tickets* menu and select **Digital LOA Manager**.
   ![](/ja/assets/images/xc-ecp-digital-loa-c65754e32820848afaa287567b16da72.png)
3. When prompted, click **Yes, Try New Digital LOA Manager** to switch to the new experience.
### Issue a Digital LOA to a Requestor[​](#issue-a-digital-loa-to-a-requestor "への直接リンクIssue a Digital LOA to a Requestor")
To issue and send a Digital LOA to a Requestor, follow these steps:
1. Look for the *Issue LOA (Z-side)* card and click **Issue LOA**.
   ![](/ja/assets/images/new-DLOA-issue-a84fe837d56c21f02378075c313ec4bb.png)
2. Enter a name for the LOA and select a product from the Product list
   ![](/ja/assets/images/new-DLOA-name-product-bc694cbc442f2549896d37c32c01592c.png)
3. The Authorization Level determines the equipment the LOA authorizes. For instance, a cage authorization grants access to an entire cage, while patch panel and port authorizations grant access to a specific patch panel or port.
   ![](/ja/assets/images/new-DLOA-authorization-level-253b60df358f7a38f790b5b85a6f7918.png)
4. Select the IBX and select or add a Requestor.
   * Click **Add a New Requestor** to enter the Requestor Name and Email.
   ![](/ja/assets/images/new-DLOA-add-requestor-b11205211d7f8191f4acccf49d82c954.png)
5. Under *Issuer Connection Details*, click **Add Connection** to specify cage, cabinet, patch panel and port information to which the requestor will connect.
   ![](/ja/assets/images/new-DLOA-add-issuer-details-ad2694fa2ef7453aa0074238b7acc7d9.png)
6. In *Review Your Digital LOA Details*, verify that the connection details and contact information is accurate.
   * Click **Create and Send to Requestor**.
   ![](/ja/assets/images/new-DLOA-review-finalize-28819ac8c21b84c58dc2fcae6c4d5397.png)
7. In the *Confirm Issue LOA* card, click **Issue LOA**.
   ![](/ja/assets/images/new-DLOA-confirm-47c7ecb7a556b0300c59fcc04a8c96c1.png)
8. The *LOA Summary* contains the LOA Token number which is a unique ID for the Digital LOA across the PDF, email, and in the Customer Portal. Your Requestor receives an email notification that includes the new Digital LOA as a PDF attachment.
   * Click **Track LOA** to view this new LOA in the Digital LOA Manager. The Digital LOA enters Processing (Pending) while the system generates the document and link. Because the success page appears before processing is complete, a newly created LOA may remain in Processing for a few seconds in the inventory.
![](/ja/assets/images/new-DLOA-summary-60d23e329496dfffcc8b1f6e0f840f50.png)
## Legacy Digital LOA Manager[​](#legacy-digital-loa-manager "への直接リンクLegacy Digital LOA Manager")
In the Legacy Digital LOA Manager, the **A-side** partner requests an LOA to establish a Cross Connect, and the **Z-side** partner issues the LOA to authorize the connection.
To create a Digital LOA as a **Z-side** partner, follow these steps:
3. When prompted, click **No, Thank You** to use the legacy experience.
### Create an LOA (Z-side)[​](#create-an-loa-z-side "への直接リンクCreate an LOA (Z-side)")
1. Look for the *Create LOA (Z-side)* card and click **Create LOA**.
   * If you received an email request from an A-side partner, the link in the email takes you directly to this step.
   ![](/ja/assets/images/xc-loa-manager-create-434959a28ce192d8948e48bcb75c61be.png)
メモ
The Digital LOA Manager filters your options based on the assets that are assigned to your organization and account.
1. Choose a Z-side IBX and an A-side partner from the drop-down lists.
2. (*Optional*) If your A-side partner isn’t listed, select **Add a New Partner** and enter their name.
   ![](/ja/assets/images/xc-loa-create-add-aside-partner-e0118553fc4a5c9f9e418957aea8cb09.png)
3. Type the new name in the A-side partner name field.
   ![](/ja/assets/images/xc-loa-create-add-aside-auth-12e81a77338525c29aea72da908bcf9a.png)
   メモ
   Adding a new partner requires two-step authentication.
   * The A-side partner receives email that contains an authentication request. The A-side partner must verify via email and sign in to the Customer Portal before the LOA can be finalized.
   * After the A-side partner is authenticated, you receive email with details and a link to sign in to the Customer Portal to make the LOA ready for use.
4. Enter an expiration date for the LOA in the *LOA Expiry Date* field within 100 days to allow enough time for approval and ordering.
   ![](/ja/assets/images/xc-loa-expiry-date-6b42983f43f07c0114679812c776317c.png)
   チップ
   Setting an expiration date ensures that the reserved ports and patch panel assets are protected for a limited time. Ports of the selected patch panel are reserved and cannot be used for any other purpose. If the DLOA is not used before the expiry, the assets are automatically released and made available for other connections.
5. In the *Z-side Connection Details* section, click **Add Connection**.
   ![](/ja/assets/images/xc-loa-add-connection-29904f656eaa810cb0b813adee1f248c.png)
6. Fill in your connection details: IBX, cage, cabinet, patch panel, ports, and other connection attributes. The Digital LOA reserves the specified assets. This ensures that the ports are available to complete the connection process.
   * If the patch panel identification number is available, enter it in the *Search by Patch Panel* field. This auto-populates the fields for IBX, cage, patch panel, and port information.
   * If you do not know the patch panel number, from the drop-down lists, choose a Cage, Cabinet, Patch Panel, Connection Service, Media Type, Protocol Type, Connector Type, and ports A and B.
   * Enter a Circuit ID.
     ![](/ja/assets/images/xc-loa-add-side-form-186127f581e08d6dab398d53fa52581b.png)
   メモ
   Once you reserve a port using this form, it is removed from the drop-down list for future LOA selections. As a result, the number of available ports in the Patch Panel drop-down decreases.
7. Click **Add**. The new Z-side Connection Details are listed.
   ![](/ja/assets/images/xc-loa-add-z-details-58b7a7e7032d6c870e1fee8f544ba7a4.png)
8. Repeat steps to create up to 10 additional connections.
9. Enter any *Additional Details* that might be helpful to an Equinix technician.
10. Click **Next**.
    メモ
    When creating a DLOA to order multiple Cross Connects, the IBX, cage, and cabinet assigned to the first A-side connection is used for all subsequent A-side connections. These settings are fixed during the order creation process and cannot be modified.
11. In the *A-side Contact List* section, add the A-side contact’s email address. If you need to add more than one contact, click **Add Additional Email** to include multiple A-side contacts. Once the LOA is created, it is emailed to all listed A-side contacts.
    ![](/ja/assets/images/xc-loa-add-email-aside-b3830c3396baecc93b4682ed18fe4240.png)
12. In *Review Your Digital LOA Details*, verify that the *Z-side Connection Details* and the *Contact Information* sections are correct.
    To edit this information, hover over the blue progress bar at the top of the page. In the drop-down list, click *Prepare LOA* or *Prepare LOA Contacts* to return to the previous step and make your changes.
    * Click **Create and Send to A-side**.
    ![](/ja/assets/images/xc-loa-progress-review-2fa3028e76e4ec04efe4ddebfc21df01.png)
13. In the *Confirm Create LOA with port allocation* window, click **Create Authorization**.
    ![](/ja/assets/images/xc-loa-create-authorization-40f315b8df27a4beeb260d5c7fb3afbc.png)
14. The *LOA Summary* contains the *LOA Token* number which is a unique ID for the Digital LOA across the PDF, email, and in the Customer Portal. Your A-side contacts receive an email notification that includes the new Digital LOA as a PDF attachment.
    * Click **Track LOA** to view this new LOA in the *Digital LOA Manager* under Z-side Authorization. Depending on the output, the Digital LOA status is set to `Ready for use` or `Pending Requestor Acceptance`.
    ![](/ja/assets/images/xc-loa-create-summary-9711c675579412dceb200f9867857d08.png)
15. A blue progress bar is displayed across the top of the page during the LOA creation process. At any time, you can hover over the bar to view a drop-down list showing your current step and overall progress. A check mark shows that you completed the previous page, *Prepare LOA*. To return to that step and make edits, click **Prepare LOA** in the drop-down list.
![](/ja/assets/images/xc-loa-progress-bar-1b6d79bc705dd1b864b59631f6cbde2b.png)
### Partner Selection Information[​](#partner-selection-information "への直接リンクPartner Selection Information")
When selecting an A-side partner from the drop-down list, you may notice company names that you don't currently have connections with. This is intentional, as the Digital LOA strategy is designed to authorize future connections between partners.
Equinix doesn't limit this list to current connections because we don't know which companies you may want to connect with in the future. If the A-side partners list doesn't contain the name of the company you'd like to authorize for a future connection, you can use the "Add a New Partner" option to include them.
