# Traffic Usage Monitoring You can troubleshoot network problems by using the Equinix Connect and Internet Access: Traffic Usage window to monitor and analyze the internet traffic that passes through a port. View a summary of the traffic usage for a single port, or export a detailed report for each port that your organization has purchased. Summaries of inbound and outbound traffic usage are available for the past three months. 1. Sign in to the [Customer Portal](https://portal.equinix.com). 2. Click *Network Management* and select *Equinix Connect and Internet Access*. ![](https://docs.equinix.com/assets/images/eia-traffic-usage-60b5892f62c0bb95c966b35faa809d48.png) 3. To display a summary of traffic usage for a single port, use the *Select Port* fields to specify the port. ![](https://docs.equinix.com/assets/images/eia-traffic-summary-053c057220057e4a93eb07af04ed6de2.png) * Search for a port – Type the name, or click the magnifying glass to choose a port from the drop-down list. * Metro – Click the drop-down list to choose a client metro location. * IBX – Click the drop-down list to choose the IBX. * Port – Click the drop-down list to choose the port. The bottom of the window displays the *Traffic Usage Summary* for the past three months. The summary includes the speed of 95% of the inbound and outbound traffic in Mbps. 4. To export a full report of traffic details for a port, scroll down to *Generate Traffic Report*. Select a month, then select *Download*. A detailed report is exported. ![](https://docs.equinix.com/assets/images/ec-traffic-report-c674b7ccd42966d929627faf1eb80a17.png)
